Dust caps needed to protect wheel bearings?
by Drew99GT
7 minutes 13 seconds ago
2014 Mazda CX5 SkyActiv
by Matt_V
19 minutes 46 seconds ago
getting rid of pwc with intermittent problem?
by motor_oil_madman
Today at 08:36 PM
Difference between silicone caulking ?
by Merkava_4
Today at 06:15 PM
The Top Dexos2 Oil Available in the USA is What?
by Best F100
Today at 05:24 PM
Virgin Puro L14006 [Cut open]
by Run
Today at 05:13 PM
The 17 year cicada is here. (locust) PIC HEAVY.
by Rand
Today at 04:23 PM
How long is sealed coolant good for?
by addyguy
Today at 04:08 PM
4T65E 2006 Buick Lucerne Normal decel gear banging
by deanm11
Today at 03:41 PM
California drought and 3" fish delta smelt
by HTSS_TR
Today at 03:18 PM
High SAPS & DPF Re-Gen
by userfriendly
Today at 02:50 PM
Decent little string trimmer
by Papa Bear
Today at 02:24 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
96 registered (901Memphis, 04SE, 29662, 2015_PSD, 2002 Maxima SE, 4WD, 7 invisible), 1411 Guests and 316 Spiders online.
58013 Members
66 Forums
249575 Topics
Page 1 of 2 1 2 >
#3095611 - 08/14/13 05:03 PM Can/Should I run a 0w oil in my car?
cyfy Offline
Loc: WA, USA
I have a question, or rather a series of questions for anyone who feels like answering.
I own a 2010 Nissan Versa with the MR18DE and 4 speed automatic transmission(not CVT) with about 56k miles on the odometer. My daily commute is only about 5-10 miles usually only getting the water up to temperature. 70% of my driving is in town, stop and go traffic, at speeds around 25-35MPH. The rest is short distance driving on the highway at 50MPH. Summer temperatures hover around 98*F and can get up to 110. Winter temps hover around 40*F and dip below 0*F. It's very windy, dry, and dusty during the summer.
My owners manual calls for SAE 5w-30. Previously I had the dealership change the oil every 4k miles since they were running a special for a nine dollar oil change. Which amounted to a cheap generic filter and what was supposedly "Mobil 1 synthetic blend". I recently changed my oil with Mobil 1 extended performance 5w-30 with a Mobil 1 filter. Already I've noticed a slight bump(1-2 MPG) in mileage and a significant reduction of lifter noise. Right now I'm just planning on changing the oil and filter every 6 months.
My question I suppose is if I would see any benefit switching from 5w-30 Mobil 1 Extended performance to 0w-30 Mobil 1 Advanced Fuel Economy? Or is there another brand of oil and filter that you guy's would recommend over Mobil 1?
Thank you for your time. I'm still trying to educate myself about the properties of oil and car maintenance in general. It's a bit more complicated than I previously thought.
#3095620 - 08/14/13 05:11 PM Re: Can/Should I run a 0w oil in my car? [Re: cyfy]
Capa Offline
Loc: Oklahoma
You are doing a short OCI with synthetic and so why not save $3 at Walmart and get the 0W-20 stuff. We get much hotter here and I run 0W-20 in both of my vehicles, which usually do a yearly OCI.
#3095621 - 08/14/13 05:11 PM Re: Can/Should I run a 0w oil in my car? [Re: cyfy]
Garak Online   content
Loc: Regina, Saskatchewan, Canada
The M1 AFE might be a tiny bit cheaper, and you may see a fuel economy bump, but that's just as likely to be buried in the noise of normal driving variations. On the positive side, XOM will stand behind the use of their 0w-30 in that 5w-30 application.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3095630 - 08/14/13 05:24 PM Re: Can/Should I run a 0w oil in my car? [Re: cyfy]
gregk24 Offline
Loc: FL, USA
Wont hurt a thing to run 0w30 where 5w30 is called for. Thats what I did in our Uplander, however, it makes a lot more noise now. Thats probably just because of the Mobil product in general.
2012 Honda Accord EX-L
Taffeta White - Ivory
38,xxx miles
PPPP 0w20 / Fram Ultra
#3095635 - 08/14/13 05:27 PM Re: Can/Should I run a 0w oil in my car? [Re: cyfy]
mattwithcats Offline
Loc: Virginia
First number is lubricity when cold, how well it flows when cold.
Second number is lubricity when hot...
Hence if 5W-30 is called for, you can use 10W-30 in the summer, and 0W-30 in the winter...
Don't change the second number....
Looks like it gets pretty cold in WA, if below zero a lot, use a 0W-30, otherwise a 5W synthetic will work...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40
Purolator Synthetic PSL 14610
175/55R15 tires...
#3095641 - 08/14/13 05:35 PM Re: Can/Should I run a 0w oil in my car? [Re: cyfy]
gregk24 Offline
Loc: FL, USA
Dont use a 10w30, you can use 0w30 year round. No need for a "thicker" first number.
38,xxx miles
#3095653 - 08/14/13 05:46 PM Re: Can/Should I run a 0w oil in my car? [Re: cyfy]
pscholte Offline
Loc: Der Schwarzwaldwesten
Run GC in my FX-35 year round. Even have driven in Phoenix summer heat. No issues
Life is a lot like oil: very slippery and doesn't (usually) have the fragrance of Gummi Bären
#3095655 - 08/14/13 05:50 PM Re: Can/Should I run a 0w oil in my car? [Re: mattwithcats]
SigQAEngineer Offline
Loc: California
Best Advice here.
[quote=mattwithcats]First number is lubricity when cold, how well it flows when cold.
Edited by SigQAEngineer (08/14/13 05:50 PM)
#3095661 - 08/14/13 05:59 PM Re: Can/Should I run a 0w oil in my car? [Re: SigQAEngineer]
pscholte Offline
Originally Posted By: SigQAEngineer
Best Advice here.
You can do it but why change the first number either
#3095673 - 08/14/13 06:11 PM Re: Can/Should I run a 0w oil in my car? [Re: mattwithcats]
Quattro Pete Offline
Loc: Great Lakes
Or you can just use 0w-30 all year long.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3095845 - 08/14/13 09:21 PM Re: Can/Should I run a 0w oil in my car? [Re: Quattro Pete]
gregk24 Offline
Loc: FL, USA
Exactly
38,xxx miles
#3095916 - 08/14/13 10:49 PM Re: Can/Should I run a 0w oil in my car? [Re: cyfy]
147_Grain Offline
Loc: USA
Welcome to the Forum!
Consider 0W-30 all year long or a 0W-20 in the winter and 0W-30 in the summer.
#3095961 - 08/15/13 12:37 AM Re: Can/Should I run a 0w oil in my car? [Re: cyfy]
Kuato Offline
Loc: In transit...
Absolutely no harm in using 0w30 year 'round.
Your oil's condition is pure speculation until you get a UOA.
13 F150 5.0, 48k mi
04 Wrangler 2.4, 197k mi
Current fills Amsoil/Amsoil
#3095969 - 08/15/13 01:47 AM Re: Can/Should I run a 0w oil in my car? [Re: pscholte]
TrevorS Offline
Loc: California
German Castrol 0w30 is not the same as most 30 weights meant for most American or Asian cars.
So for the OP I wouldn't choose it I'm trying to decide between a 20 and a 30 weight oil. The GC is nearly a 40 weight.
OP, if you're thinking about a zero weight and are tempted to go to a 20 weight even if your vehicle requires a 30 weight consider this.
Buy M1 AFE in both 0w20 and 0w30. Use 1 quart of 0w20 and balance 0w30. See if you like it and get a UOA. Take it from there to decide on what mix % is safe.
#3095971 - 08/15/13 02:12 AM Re: Can/Should I run a 0w oil in my car? [Re: TrevorS]
It's certainly heavier at operating temperatures. Nonetheless, it still is a 0w- multigrade and conforms to those standards. For the OP, as you mention, a GF-5 rated lubricant is more suitable.
Page 1 of 2 1 2 >
