Weapon Shield
by Ws6
02/11/16 12:33 AM
Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
Troy Bilt Pony
by OSUFan86
02/10/16 06:43 PM
$1.33 for a GALLON of 87!
by Vern_in_IL
02/10/16 06:30 PM
Eating out, beware you all
by CourierDriver
02/10/16 06:13 PM
BlueKelah, threeeightteen, TOADchunks, Longo9596, Roadrunner77z
56889 Registered Users
49 registered (akela, Astro14, bdcardinal, Ben Boyle, 87sammy, bbhero, 5 invisible), 756 Guests and 191 Spiders online.
56889 Members
66 Forums
244531 Topics
Page 4 of 4 < 1 2 3 4
#1609310 - 09/23/09 10:09 PM Re: MMO vs TCW3 as a fuel additive [Re: Trajan]
morris Offline
Loc: ks, wichita
been useing mmo for decades. just 5mo ago started putting tc-w3 in the mmo. no better mpg, starts just by thinking about starting it. ampco has top tube bottles, like the old mmo bottles
#3064423 - 07/13/13 07:36 PM Re: MMO vs TCW3 as a fuel additive [Re: demarpaint]
TheSitRep Offline
Loc: Puna, Hawaii
I'm sure MMO is good stuff but as far as a UCL ask yourself this:
Say you just bought a brand spanking new 600.00 dollar Stihl chainsaw and you need to use it now to save you car from a leaning tree. and the only oil you have to mix your gasoline with is MMO or some TCW3 2 stroke oil, which would you use?
#3064444 - 07/13/13 07:53 PM Re: MMO vs TCW3 as a fuel additive [Re: TheSitRep]
147_Grain Offline
Loc: USA
I'd use TCW-3. It's a better lubricant that's a little thicker that burns clean.
#3064598 - 07/13/13 09:26 PM Re: MMO vs TCW3 as a fuel additive [Re: TheSitRep]
demarpaint Offline
Loc: NY
For one time to save my car from a leaning tree? TCW3. Adding to the gas in my car, Jeep or van, MMO. I have TCW3 but I keep going back to MMO.
God Bless Our Troops
#3064612 - 07/13/13 09:32 PM Re: MMO vs TCW3 as a fuel additive [Re: demarpaint]
FXjohn Offline
Loc: NE Indiana
MMO is a mild solvent. why would I add marine two stroke oil??
#3064692 - 07/13/13 10:02 PM Re: MMO vs TCW3 as a fuel additive [Re: andyd]
Clevy Offline
Loc: Saskatoon canada
Originally Posted By: andyd
I started using MMO in my small engine fuel. Once I have the engine sorted out and have run a few tanks of fuel dosed with MMO through an engine, it starts easier and I no longer have to tear down the carb to clean out varnish. I have used it on occasion in my cars and have noticed a bit nore pep, but no improvement in MPG
I completely concur as far as carburetors and requiring no maintenance when tc-w3 is used.
I've been using a tc-w3 and either toluene/xylene/acetone mixed in everything I own that burns fuel for years now. A couple years ago I took our fuel invoices for the month and added them up,I then started adding my fankenbrew mix at various ratios,each ratio getting a month in service then again adding up my bills.
I found 6 ounces tc-w3 and a quart of acetone per 100 litres of fuel reduced my monthly fuel consumption pretty significantly.
The air compressors will last 6 hours on a tank of fuel pretty consistently,with the fankenbrew I could get over 7 hours on a tank.
Now multiply that by 12 compressors.
On months where hours worked were very close I took a real close look at fuel consumption before and after implementing adding a fuel treat and I saw differences of over 100 litres less purchased even though hours worked were very close(within 20).
So that's 125 bucks saved for an investment of less than 6 bucks per 100 litres.
I also found that the machines weren't needing any servicing,which whenever there was a significant temp change they ran roughly,but not anymore.
And no fuel leaks from the carbs anymore either.
These machines get the living heck beat out of them daily. No one cares about my tools,they start em,let em run all day,the only time they are off is to fill them with gas.
Add that to the fact they are getting bounced around in the backs of trucks to and from different sites and I'm astonished they last as long as they do.
The last year or so I've also begun using mos2 every second oil change. I've found an even greater fuel savings adding it to the oil,and in the winter they turn over much easier and the men barely ever snap a pull start cord ever now.
So I'm a believer. I didn't find that overdosing does cause a consumption increase,and any more than a quart of acetone to 100 litres fuel doesn't realize a larger fuel savings,so the ratios I've posted are after testing in my own OPE over a period of 4 months.
As far as mmo goes its only in the last few months its been available here I use it in a top end oiler and I'm happy with it thus far in the mustang I'm using it in.
Just my experience,others may have different experiences.
2006 Charger RT
Miles x 2 per oil filter
#3067814 - 07/17/13 08:16 AM Re: MMO vs TCW3 as a fuel additive [Re: demarpaint]
webfors Offline
Loc: Great White North.. eh
So the average TCW3 dosing is somewhere between 500:1 and 700:1? If my calculations serve me right 1oz per 5 gallons of gas is pretty close to 600:1.
I used it years ago at a higher dosage and noticed ill effects (loss of power, mpg, etc).
Since I've got a couple quarts I'm going to give it another try in the subie at 600:1.
15 Civic, AFE 0w20, FU OF
13 Dodge GC, VWB 5w20, Purolator OF
13 SFV650, T6 5w40, OEM OF
07 VS800, OEM 10w40, K&N OF
Small engines; RT5 10w30
#3076844 - 07/26/13 11:03 AM Re: MMO vs TCW3 as a fuel additive [Re: Trajan]
snofarmer Offline
Loc: MN
MMO lowers the LUBRICITY of diesel fuel.
MMO it's what they call a true snake oil
Read the test results for yourself.
http://www.johnfjensen.com/Diesel_fuel_additive_test.pdf
#3076890 - 07/26/13 11:32 AM Re: MMO vs TCW3 as a fuel additive [Re: snofarmer]
demarpaint Offline
Loc: NY
Old news, and a repeat post of yours from the oil additive section. Gas and diesel are two different animals, and the horse your beating is dead already. The search engine is your friend.
#3076900 - 07/26/13 11:41 AM Re: MMO vs TCW3 as a fuel additive [Re: demarpaint]
snofarmer Offline
Loc: MN
Same good info in a different thread.
so what I posted the same info in a different thread, not everyone is going to read every thread or post.
As members post up their intentions to use ATF, I will post up why not to.
The horse is up and running around as folks still think burning ATF is a good thing.
Edited by snofarmer (07/26/13 11:42 AM)
#3076913 - 07/26/13 11:50 AM Re: MMO vs TCW3 as a fuel additive [Re: snofarmer]
demarpaint Offline
Loc: NY
Search the board you'll see we've discussed burning ATF too. Still old news and a dead horse.
#3076946 - 07/26/13 12:30 PM Re: MMO vs TCW3 as a fuel additive [Re: demarpaint]
snofarmer Offline
Loc: MN
Yet the subject still comes up in new threads.
this means they did not do a search or read what "was posted" in the past.
The horse is still up and running around the pasture.
Al long as "they" still ask about atf, I'll respond with the "old" info.
thanks
#3076950 - 07/26/13 12:38 PM Re: MMO vs TCW3 as a fuel additive [Re: snofarmer]
demarpaint Offline
Loc: NY
thanks
5 seconds worth of searching about the ATF you brought up.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2980311
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1401038
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=684193
There's more. Enjoy!
BTW who recently asked about ATF?
Edited by demarpaint (07/26/13 12:41 PM)
