Video: Napa Proselect 21334 cut open
by cronk
07/24/16 01:12 PM
what viscosity on a new build? 351W/408 street
by tomcat27
07/24/16 12:14 PM
What is this plant?
by skyactiv
07/24/16 11:16 AM
Recycling
by mjoekingz28
07/24/16 10:30 AM
Craftsman Action Bypass Lopper ~$11.70
by Sayjac
07/24/16 09:51 AM
2017 Fusion Hybrid
by AirgunSavant
07/24/16 09:50 AM
Grease that's universal on ALL aspects of car care
by NattyBoh
07/24/16 09:45 AM
Oil made from natural gas?
by Sealbilly
07/24/16 09:18 AM
Rotella line upgraded
by Sealbilly
07/24/16 09:13 AM
Kendall VersaTrans LV for Toyota WS?
by Slick17601
07/24/16 08:03 AM
Clutch problem
by chrisri
07/24/16 07:49 AM
Peppers: do you grow them?
by car51
07/24/16 07:29 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
83 registered (andrewp1998, alanwayne1908, AirgunSavant, 41 Plymouth, 182RG, Al, 9 invisible), 2051 Guests and 14 Spiders online.
58578 Members
66 Forums
252188 Topics
#3017396 - 05/30/13 03:46 AM DOT 3 Brake Fluid at O'Reilly
EType Offline
Loc: CA
So I need a quart of Dot 3 and have $5 to spend at O'Reilly.
Which one of these should I buy:
Valvoline Dot 3/4
O'Reilly
Pure Guard Super Heavy Duty
Peak
Prestone
Gunk
Wagner
Gunk ABS which passes GM4653M and is the most expensive
"Experience by itself teaches nothing"
William Edwards Deming
#3017397 - 05/30/13 04:03 AM Re: DOT 3 Brake Fluid at O'Reilly [Re: EType]
david_ES2 Offline
Loc: Fresno, CA
If all you need is dot3 ...Oreilly brake fluid will work well or the same as others.
2004 Honda Civic EX K20Z1 5w30 PP WIX XP
#3017425 - 05/30/13 06:01 AM Re: DOT 3 Brake Fluid at O'Reilly [Re: EType]
229 Offline
Loc: Mid Atlantic
Eneos Dealer
#3017624 - 05/30/13 10:48 AM Re: DOT 3 Brake Fluid at O'Reilly [Re: EType]
tommygunn Offline
Loc: usa
Either Wagner Dot 4, or Valvoline. DOT 4 is better than DOT3 due to its higher boiling points (Dry 446, wet 311 for DOT 4 vs 401/284 for DOT 3). I also looked on O'Reilly's website, and Wagner's DOT 4 seems to be the same price as DOT 3. So for no extra cost, get the better stuff.
Prestone would be my third choice. The wet BP is 284, but the dry BP is 470.
I wish Prestone made their DOT 4 by the quart because that would be awesome. Its wet BP is 311, but the dry BP is 510.
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
#3017643 - 05/30/13 11:20 AM Re: DOT 3 Brake Fluid at O'Reilly [Re: EType]
EType Offline
Loc: CA
The vehicle this is for will not see demanding driving.
Corrosion protection and longevity are more important to me.
In that case, would Gunk ABS be best?
#3017753 - 05/30/13 01:02 PM Re: DOT 3 Brake Fluid at O'Reilly [Re: EType]
nthach Offline
Loc: California
Castrol GT LMA or Valvoline.
#3017799 - 05/30/13 01:45 PM Re: DOT 3 Brake Fluid at O'Reilly [Re: EType]
tommygunn Offline
Loc: usa
No. Gunk ABS isn't any better. It's actually inferior to Valvoline besides being more expensive.
The dry boiling point is the same, and the wet boiling point is lower.
Gunk:
Dry 450, Wet 284
Valvoline:
Dry 480, Wet 311
#3017974 - 05/30/13 04:46 PM Re: DOT 3 Brake Fluid at O'Reilly [Re: EType]
GMBoy Offline
Loc: Texas
I used to be on the DOT4 bandwagon due to the higher boiling point. However - with DOT4 it collects water faster and WILL require flushing sooner than DOT3.
You are looking for protection and long life, so go with DOT3 at the best price.
#3018139 - 05/30/13 08:13 PM Re: DOT 3 Brake Fluid at O'Reilly [Re: GMBoy]
tommygunn Offline
Loc: usa
This isn't a problem if you flush every 2-3 years like you're supposed to.
Now if the OP didn't limit himself to $5, or to O'Reilly, he could get Castrol LMA which collects water slower. It's sold at Carquest.
If it has to come from O'Reilly, check out Wagner Severe Duty DOT 5.1.
And anyway many brake fluids say DOT 3&4, including Valvoline.
#3018295 - 05/31/13 02:54 AM Re: DOT 3 Brake Fluid at O'Reilly [Re: tommygunn]
GMBoy Offline
Loc: Texas
I agree and I do flush my fluid every 2 years. I just made the comment because the poster was looking for long term use and it didn't seem like he was going to flush it again.
