Deep tranny pan worth it?
by rsylvstr
06/26/16 07:20 PM
Which oil for my old BMW and why?
by fdcg27
06/26/16 06:20 PM
Synthetic blend for a Elantra
by car51
06/26/16 05:48 PM
Camshaft Adjuster Bolts - Replacement ?
by Ndx
06/26/16 05:45 PM
STP Synthetic
by travlnman
06/26/16 04:37 PM
Myliftstand alternative jack stand
by momo
06/26/16 03:33 PM
Kmart sale on Smitty's oil and ATF
by slacktide_bitog
06/26/16 02:53 PM
Napa master pack oil filter price
by Electromotive
06/26/16 02:39 PM
Local Big Lots still has Valvoline next gen 10w30
by Electromotive
06/26/16 01:25 PM
Best Value Differential Oil 75W-90
by KevinP
06/26/16 01:02 PM
kohler 17hp . changed oil , now will not run
by chad8
06/26/16 12:32 PM
Oil change recomendations for '11 Ranger 2.3 Liter
by ryan2022
06/26/16 11:49 AM
Ruturaj, derfderfgoose, ssnead, mtrev, redtacoma
58277 Registered Users
98 registered (bchannell, bbhero, 55hambone, BigD1, 2015_PSD, bdcardinal, 11 invisible), 1712 Guests and 9 Spiders online.
58277 Members
66 Forums
250845 Topics
Page 1 of 2 1 2 >
#2996174 - 05/08/13 09:04 AM vw 505.1 spec, must have or not?
sasilverbullet Offline
Loc: San Antonio, Tx
I also hang out on a vw forum and over there they say I don't need to have oil that says 505.1 on it for my 02 Beetle and 03 Jetta, both with the same turbo diesel engine.
We filled up my sons Beetle with Rotella T-6 synthetic 5W-40. It says on the bottle:
Meets API Service CJ-4, CI-4 Plus, CI-4, CH-4, CG-4/SM
Meets the performance requirements of: ACEA E9, Caterpillar ECF-3, ECF-2, Cummins CES 20081, Mack EO-O Premium Plus, DDC 93K218, MB Approval 228.31, Volvo VDS-4, JASO DH-2, JASO MA
So is the Rotella T-6 okay for these engines?
14 Honda Civic 4dr EX-L - Mobil 1 Ext Perf 0W-20 & M1 Filter
14 Honda Accord 4dr EX-L 4cyl - Mobil 1 Ext Perf 0W-20 & M1 Filter
#2996185 - 05/08/13 09:24 AM Re: vw 505.1 spec, must have or not? [Re: sasilverbullet]
1999nick Offline
Loc: Germantown TN 38138
Yes, it is OK. 505.1 was for later model VW diesels, and it has been superseded now by 507.
#2996204 - 05/08/13 09:50 AM Re: vw 505.1 spec, must have or not? [Re: 1999nick]
Ok, but that's not 507 either.
#2996212 - 05/08/13 09:54 AM Re: vw 505.1 spec, must have or not? [Re: sasilverbullet]
AlienBug Offline
Loc: Connecticut
For those years I believe you need VW 505 not 505.01. Also your owners manual lists three specs: VW 505, API CH4 and IIRC and ILSAC rating. Oils meeting any of the three can be used. I would recommend GC.
Edited by AlienBug (05/08/13 09:55 AM)
Don
2005 Ford Freestyle SEL, 158k, Motorcraft 5w20 synblend, Motorcraft filter
2007 Ford Fusion SE 2.3l, 125k, Mobil 1 EP 0w20, Motorcraft filter
#2996217 - 05/08/13 10:03 AM Re: vw 505.1 spec, must have or not? [Re: AlienBug]
If I'm reading this right, since it's CH-4, then it's okay, yes?
#2996232 - 05/08/13 10:25 AM Re: vw 505.1 spec, must have or not? [Re: AlienBug]
dparm Offline
Loc: Chicago, IL
505 is for gasoline engines.
505.01 is for diesel engines.
2011 BMW M3 sedan ZCP
#2996284 - 05/08/13 11:32 AM Re: vw 505.1 spec, must have or not? [Re: dparm]
AlienBug Offline
Loc: Connecticut
VW 505 is the TDI spec.
VW 502 is the gasoline spec.
VW 505.01 was a spec for the PD series of TDI engines.
Don
#2996288 - 05/08/13 11:38 AM Re: vw 505.1 spec, must have or not? [Re: sasilverbullet]
scurvy Offline
Loc: Chicago IL USA
505.01 is for Pumpe-Düse engines (BEW, BHW, BRM) which you don't have; your VWs have the venerable ALH engine which was specified to take 505.00.
Regardless of what VW wants you to use, Shell Rotella T6 is an excellent oil for your cars; if the engines are healthy there's no reason to do anything less but the factory 10k mile OCI (and likely you can extend it out very easily if your driving style is appropriate).
From my experience with ALH-engined TDIs running Rotella T6, it tends to slip past the turbocharger seals a bit more easily than other 5w40 lubes so keep the cars on boost and watch your oil level. Consuming 1 - 2 liters over an OCI is normal.
Mobil 1 0w40 is another fantastic oil for them but any name-brand 5w40 diesel-spec oil will work fine.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#2996298 - 05/08/13 11:51 AM Re: vw 505.1 spec, must have or not? [Re: scurvy]
Thanks for putting my mind at ease and the easy explanation!
#2997276 - 05/09/13 11:56 AM Re: vw 505.1 spec, must have or not? [Re: sasilverbullet]
adamrc Offline
Loc: Nashville, TN
Rotella T6 is a fantastic oil for your TDI. We've had 7 TDIs in our family ranging from 2001-2006 and Rotella T6 is a great oil for them all. I run mine at 10K intervals. I usually use Mann filters.
#2997389 - 05/09/13 02:05 PM Re: vw 505.1 spec, must have or not? [Re: sasilverbullet]
147_Grain Offline
Loc: USA
Recommend you also consider Mobil 1 0W-40.
TBN is 12.5 versus 9.9 of the T-6.
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-40.aspx
#2997812 - 05/09/13 09:17 PM Re: vw 505.1 spec, must have or not? [Re: sasilverbullet]
UG_Passat Offline
Loc: NJ
505.01 is not needed for the ALH motor in your 02 & 03. 04's came with the Pumpe Duse engine, which VW required 505.01
In the end... Rotella T6 is fine for the ALH engine
#3003273 - 05/15/13 06:33 PM Re: vw 505.1 spec, must have or not? [Re: 147_Grain]
NewYorkBuck Offline
Loc: NY, NY
I have owned a 2006 Jetta TDI since it was new, and have been on the VW forums consistently since I purchased it. In that time, I have learned the following about oil relative to my car:
1 - The 505.01 is not a necessary condition, and in the case of 5W-30, it is neither a sufficient one.
2 - M1 ESP Delvac, M1 TDT, and Rotella T6 (all in 5W-40) are consistently "the chalk" on recommended oils for these cars.
3 - NO ONE credible, and I mean NO ONE credible recommends the use of M1 0W-40 in these engines. In the BRM engine, cam wear is a problem, and the consensus is a light 0W oil, esp one reformulated low on Zn and Phos additives, is not going to cut it.
#3003275 - 05/15/13 06:35 PM Re: vw 505.1 spec, must have or not? [Re: sasilverbullet]
AlienBug Offline
Loc: Connecticut
Had you read the original post you would have seen that he has an ALH engine, in which many, many, MANY TDIers run M1 0w-40.
Edited by AlienBug (05/15/13 06:37 PM)
Don
#3003713 - 05/16/13 07:27 AM Re: vw 505.1 spec, must have or not? [Re: AlienBug]
NewYorkBuck Offline
Loc: NY, NY
My bad. I saw 505.01 and immediately assumed it was a BRM.
Page 1 of 2 1 2 >
