'91 Mazda B2600i transfer case and trans oil?
by Jason280
46 minutes 9 seconds ago
How to cut power to breaker box ?
by Merkava_4
Today at 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
Today at 01:07 AM
OK, before I lube it ...
by BrocLuno
Today at 12:53 AM
Toyota Japan Fluid SDS
by SXE10
Yesterday at 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
Yesterday at 11:25 PM
Considering a differential swap
by buck91
Yesterday at 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
Yesterday at 09:51 PM
Car Acronyms
by Marco620
Yesterday at 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
Yesterday at 09:41 PM
Carpet cleaning methods.
by Run
Yesterday at 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
31 registered (Char Baby, Atesz792, b1amgm47, 1foxracing, crainholio, 4 invisible), 732 Guests and 13 Spiders online.
58295 Members
66 Forums
250918 Topics
Page 1 of 2 1 2 >
#2990704 - 05/01/13 08:19 PM Which Axle should new tires be put on?
JasonTL Offline
Loc: Georgia, USA
Which axle should a pair of new tires be put on for:
2wd front drive
2wd rear drive
4wd
Awd
I'm just wondering in general. I'm going to be getting a full set so this won't be a concern for me. Just wondering which is better for certain vehicles or if they always go on a specific axle.
:: 1988 : GMC : 1/2 Ton : Suburban ::
:: 5.7L : 350CI : 209k mi. ::
Restoring to original
#2990707 - 05/01/13 08:22 PM Re: Which Axle should new tires be put on? [Re: JasonTL]
Donald Offline
Loc: Upstate NY
Usually the rear.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2990709 - 05/01/13 08:23 PM Re: Which Axle should new tires be put on? [Re: JasonTL]
Rock_Hudstone Offline
Loc: New Jersey
Generally, the best tread should be on the rear to avoid a spin out in wet conditions regardless of the drivetrain.
#2990711 - 05/01/13 08:25 PM Re: Which Axle should new tires be put on? [Re: JasonTL]
stephen9666 Offline
Loc: USA
Perform search, multiple threads on this topic.
Long story short, tire manufacturers generally say best tires on the rear.
#2990713 - 05/01/13 08:26 PM Re: Which Axle should new tires be put on? [Re: JasonTL]
Corvette Owner Offline
Loc: Waldorf, Maryland
Usually, they say the new tires should go on the rear. This is to prevent the rear from "coming around".
However, on FWD, I prefer to put them on the front since this wears them down the most. If they are GREATLY mismatched, I stop rotating them.
4WD and AWD tires should match each other closely. They should be replaced in all fours. This is to prevent wear of differentials and clutches.
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#2990714 - 05/01/13 08:30 PM Re: Which Axle should new tires be put on? [Re: JasonTL]
edwardh1 Offline
Loc: Coastal South Carolina
Michelin web site a few years ago had a video on what their choice is, and why - I cant remember- look it up. was a good video. I think they chose rear- could be wrong,
see video
http://www.michelinman.com/tires-101/buying-tires/how-to-choose/mixing-tires.page
Edited by edwardh1 (05/01/13 08:34 PM)
I know women who are always late, they do not allow travel time, they think like Star trek, you leave one place and materialize somewhere else.
#2990717 - 05/01/13 08:35 PM Re: Which Axle should new tires be put on? [Re: Corvette Owner]
RiceCake Offline
Loc: Coldtown, Canada
^ This.
#2990719 - 05/01/13 08:36 PM Re: Which Axle should new tires be put on? [Re: JasonTL]
tenderloin Offline
Loc: Huntington Beach, CA
#2990727 - 05/01/13 08:50 PM Re: Which Axle should new tires be put on? [Re: JasonTL]
KitaCam Offline
Loc: SunnySouthFlorida
Drive gingerly for the 1st 100 miles...
The following is my standard procedure as my front tires always wear at the shoulders more than the rear pair does...and I run tires 20% higher PSI than the door jamb specifications and get even wear across the tread from outer shoulder to inner shoulder.
1. 1st rotation @ 5000 miles...
the front will start wearing more on the front outer shoulders because of turns...wear increases more after 5k
2. after another 5k miles the 2 pair should now be about equal...
run them for another 5k miles and the front will now show more wear than the rear...
3. 2nd rotation @ 15000 miles
4. rotate every 5k miles beyond 15k miles to get the most tread-life from your tires.
Edited by KitaCam (05/01/13 08:56 PM)
Kitacam is an 05 Camry LE/I4/MT; 3/16 @ 137,000....MaxLife Syn Blend 5w-30...with P1 filter
#2991330 - 05/02/13 01:20 PM Re: Which Axle should new tires be put on? [Re: JasonTL]
threeputtpar Offline
Loc: Appleton, WI
Since the lawyers got involved in the question, the only correct answer is the rear.
But for those that actually know how to drive a car, it depends. For foul weather, I'd put the good ones up front because it's better to be able to turn and stop than making sure the back end doesn't come around. If you live in a nice climate, there may be an argument for either axle where each has its own reasons.
Edited by threeputtpar (05/02/13 01:21 PM)
2013 Honda Odyssey Touring Elite - M1 5W-20 / M1-101 40k miles
2008 Ford Taurus X - Resolute 5W-20 / MC FL-400S 128k miles
#2991532 - 05/02/13 04:59 PM Re: Which Axle should new tires be put on? [Re: threeputtpar]
ChrisW Offline
Loc: Central Valley, CA
FWD drive cars are more difficult to correct when over-steer occurs than a RWD car in my opinion [this is from a performance driving perspective]. With that aside, at my work, we put on the tires with the most tread on the rear, however, if the existing tires are within 2/32 of the new, we can put the new on front at request, but it is preferable to have the most tread on the rear for AWD/FWD/RWD. Proper rotation intervals and inflation will go a long way in keeping the tread wear even between the front and rear. And of course without saying the vehicle's alignment; just because it's all green does not mean it is good. Staggered tire fitments, well, that's a whole different animal.
09 Mazda6 GT 3.7 89k PYB-SN 5W20 Wix 51516
10 Mazda3 GT 2.5 40k QSUD 0W20 Wix 51348
10 Mazda3 S 2.5 28k QSUD 0W20 Wix 51348
#2991570 - 05/02/13 05:54 PM Re: Which Axle should new tires be put on? [Re: threeputtpar]
mechanicx Offline
Loc: Ohio
This. The always put the new tires on the rear is a result of lawyers and a (fivrolous) lawsuit.
#2992072 - 05/03/13 08:31 AM Re: Which Axle should new tires be put on? [Re: mechanicx]
CapriRacer Offline
Loc: Somewhere in the US
But it should also be pointed out that there is a technical basis for such a stance - and there is a ream of data supporting the "New Tires on the Rear" position, but very little (if anything) supporting contrary positions.
CapriRacer
Visit my web site: www.BarrysTireTech.com
#2992105 - 05/03/13 09:24 AM Re: Which Axle should new tires be put on? [Re: JasonTL]
cchase Offline
Loc: New England
Shouldn't stability control, now mandated on vehicles, negate any possible advantage of putting the "good" tires on the back? It seems to me that the "back coming around" should be fairly difficult, but the chances of the front needing more traction fairly common.
Just thinking aloud here.
#2992545 - 05/03/13 07:18 PM Re: Which Axle should new tires be put on? [Re: JasonTL]
Ken2 Offline
Loc: Washington St.
Stability control only works if the tires being controlled have traction.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
Page 1 of 2 1 2 >
