Amsoil announces 6% price hike
by Kuato
06/29/16 09:28 AM
737 NG
by SEMI_287
06/29/16 09:10 AM
ACDelco vs Valvoline oil filter
by mbar1
06/29/16 08:21 AM
Valvoline Premium Blue RestoreTM
by Rat407
06/29/16 08:16 AM
Dealer says 07 Highlander has strainer. Nope!
by CapitalTruck
06/29/16 08:04 AM
Trailer wiring connector.
by wolfehunter
06/29/16 07:10 AM
Oil for High Performance Turbo Application
by T_Bortz
06/29/16 06:52 AM
Walmart.com Valvoline WB 6x1Quart 10W-30 $7.22
by Farmer
06/29/16 06:41 AM
Dyade, Eurol, Ravenol Lubricants
by RaM30
06/29/16 04:46 AM
'88 Caddy Brougham - dark oil + lifters noise
by momo
06/29/16 02:57 AM
Which Oil for Duramax?
by Jamn
06/29/16 02:11 AM
Oil for Binding Foundry Sand
by smw
06/29/16 01:38 AM
dpaldino, T_Bortz, rebelx, dougsangster, CrazyCalvinW
58314 Registered Users
77 registered (Al, 69GTX, aquariuscsm, b1amgm47, bbhero, badtlc, 8 invisible), 1770 Guests and 11 Spiders online.
58314 Members
66 Forums
250975 Topics
#2984731 - 04/25/13 08:24 PM Valvoline Conventional
Realtech214 Offline
Loc: Florida
I have heard everywhere that vwb is the perfect oil for chevy engines. Is this true? What additives make a good chey oil
2015 Silverado Crew Cab 5.3 LT
2001 Suburban LT
- I NEVER THOUGHT I WOULD LIKE OIL SO MUCH -
#2984799 - 04/25/13 09:19 PM Re: Valvoline Conventional [Re: Realtech214]
jimmy87 Offline
Loc: texas
My personal experience, vwb is what I was using on my 2009 sierra with the 5.3, and one day I decided to run pp, well pp is what is currently in there (it's been a month now) with pp my truck has a slight knock I never noticed with vwb.
2013 GMC SIERRA 5.3L
2002 Toyota highlander 2.4L
#2984801 - 04/25/13 09:19 PM Re: Valvoline Conventional [Re: Realtech214]
donnyj08 Offline
Loc: Cincinnati, OH
any oil of the correct grade and API rating is perfect for most chevy engines. as long as and oil meets GM6094m and GM4718 and or is dexos approved or meets the specs for dexos approval it is suitable for chevy engines from the cavalier to the ZR1.
Almost all name brand oils meet the specs for most gm cars/trucks
and almost All the name brand synthetics meet or exceed the Dexos requirements.
VWB is more than adequate for your silverado or your suburban. check the manual and see which spec your trucks require then check the labels on the bottles to make sure it meets the spec you need. VWB will meet your engines specs.
Edited by donnyj08 (04/25/13 09:21 PM)
2008 Silverado Z71 LT 75k Kendall FS 5w30, Hastings LF613
#2984806 - 04/25/13 09:24 PM Re: Valvoline Conventional [Re: Realtech214]
Kuato Online   confused
Loc: In transit...
I used VWB on numerous vehicles for many years with OCIs up to 5000 miles, no oil related issues, no sludging, and low wear numbers in UOAs. Go for it.
Your oil's condition is pure speculation until you get an UOA.
13 F150 5.0, 50k mi - Schaeffer 9000
04 Wrangler 2.4, 198k mi - Amsoil SS 5w30
#2984825 - 04/25/13 09:41 PM Re: Valvoline Conventional [Re: Realtech214]
Gabe Offline
Loc: Indiana
With GM leaky intake gaskets, you might want to stick to an oil without a sodium add pack to make UOA easier to read.
#2993254 - 05/04/13 08:04 PM Re: Valvoline Conventional [Re: Gabe]
Ram01 Offline
Loc: New York Queens
I'm pretty sure a lot of those leaky intakes have been taken care of by now
#2993347 - 05/04/13 09:40 PM Re: Valvoline Conventional [Re: Realtech214]
KCJeep Offline
Loc: Mahzurrah!
I have owned at least one Chevy for the last 25 years, none of them have seemed picky about oil at all.
Valvoline seems to work well in just about everything, I have it in our remaining Chevy now. There are some UOA's on here using Valvoline in GM products that look absolutely fantastic.
2004 Jeep Grand 4.0 @ 133k Pennzoil HM 10w30 w/ 1 qt 10w40
Fram PH8A
KIA Sedona 60k, Ford Focus 115k, Chrysler Sebring 186k, Chrysler Concorde 115k
#2994255 - 05/05/13 11:52 PM Re: Valvoline Conventional [Re: Realtech214]
4ever4d Offline
Loc: North Carolina
VWB is the perfect oil for most engines...so long as it's used for the correct oci and in the correct sae grade. I use it and like it very much.
01 Dodge Durango 4.7 V8 5w-30
07 Honda Element 2.4 I4 5w-20
QSAD and Fram TG Filter
#2994264 - 05/06/13 12:28 AM Re: Valvoline Conventional [Re: Realtech214]
armos Offline
Loc: California
I don't know if it's any better than anything else, but for older engines I'm partial to it because of the VR1 version, which is readily available. I mix VR1 with white bottle conventional to moderate the ZDDP content. It can also help tweak the viscosity vs what's available in VR1.
Other than that they're the same oil, so they're a natural fit for mixing with each other.
86 Pontiac Fiero 2.8L
