Originally Posted By: Virtuoso
I've had a thermostat stick closed for me.
Most of the time mine have failed in the "open" position though. But don't assume they always do that.. sometimes they don't. And it sucks when they do.
Granted, but it's less common for sure.
Those failsafe t-stats are no answer to that happening anyway! Ive read so many bad things about them, it's not even funny.
Also, if a "failsafe" t-stat happens to fail when it's closed, it wont be able to reach the locked open position anyways....
A regular thermostat won't fail when it's open and then snap shut like Motorad claims, when it fails, it stops right where it is and if that happens to be in a closed state (a lot less likely from my experience), well then that's where it remains, so their locking mechanism is a joke.
Those POS t-stats if anything are more for protecting you from an overheating issue much like removing the t-stat all together would... ironically enough, but as far as protecting you from the t-stat itself failing, not happening. Motorad doesn't tell you this for some reason, they claim that the locking position protects you from the t-stat itself failing, what a crock!!
The one thing I read all too often is that they react way too easily, causing it to lock, forcing you to redo the t-stat as I mentioned in a previous post.
To the OP (wherever you may be), check out the reviews....
From a Jeep forum
look at he 2nd post, the failsafe t-stat FAILED in the closed position!
yet another lousy experience.....
here's another....
When I did a search for reviews, I did NOT put "bad failsafe t-stat review" into the search bar, I just put "failsafe t-stat review". On the very first page comes up bad review after bad review!
Gates or an OEM t-stat is the way to go! Ive had a Gates superstat in a car once, they work great and are still made in the USA!
