Interesting that your Al accumulation rate went up with the second OCI, 30ppm in 5,000 mi vs 27 ppm in 7,600 mi. My 2011 Civic did the same thing. My first change was the new Honda "Ultimate" API SN synthetic oil, and it held up pretty well, I then did two fills on the Idemitsu SM formula with high moly. Idemitsu was Honda's supplier until 2011, but I got the oil from Subaru. The Idemitsu oil did not do particularly well in my engine. I'll be interested to see how the new Idemitsu made Mazda formulation does in an R18.
Your Silicon levels are high, just like mine were with the factory air filter. I did some comparisons with aftermarket filter elements and came to the conclusion that the OEM filter element perimeter seals were to blame. I swapped it for a Napa Select (formerly Napa Silver) filter, and my Si accumulation rate dropped dramatically. I haven't made time to write up my measurements yet, but I looked at a Fram, Purolator, Napa Gold (WIX) and Napa Select (also WIX?) and came to the conclusion the Napa Select had the best seals. The filter element itself looked better on the OEM filter and the Napa Gold, but the Select had the best seals. Consider swapping out the filter early if the silicon continues to read high in your next sample. Do a search on my username for my UOAs, the latest one has commentary about Silicon and Aluminum levels.
I've got M1 0w20 in my car now, and I do mostly longer trips in an extra-urban environment with it. My trips are a bit shorter than yours, but our usage is broadly similar (few short trips). We'll see how mine comes back in a few months. Hopefully it shows less shear and fuel than yours.
To those who assume all Hondas are easy on oil, I think the J-series V6 and the R-series 4-cyl are exceptions to the rule. I've seen several R-series UOAs with pretty high fuel. I suspect the "semi-Atkinson" VTEC economy mode is to blame. Also my engine takes quite a while to warm up, something other R18 owners have noted, which may cause rich running.
