Second time losing this post. I am not losing this post again.
Super short version:
1991 Blazer. Code 43
first OBD1 vehicle/problem
Does Code 12 handshake, gives me Code 43
Did this before I melted coolant temp sensor, as per thread in General Forum
Questions:
1. Should I put in higher than 87 octane gas? Will that help or not?
2. Could it be something stupid, like a bad ground?
3. Should I change all my plugs and wires and the distributor cap too? I ask because I have them
4. I can't feel any knocking.
5. The code appears to be set, even if i I disconnect the negative for 30 minutes, it will start up with it off, then come right back on. Help?
Questions:
