2000 Jeep Cherokee 4.0L with 132k miles (currently).
Oil was Pennzoil Yellow Bottle 5w30 run for 3,500 miles
Filter was a Mopar MO-090
This Jeep sees mostly short trips. My commute is 7 miles to school. It rarely sees any highway driving.
Makeup: 1/4 quart (rear main seal leak)
Comments:
"JOSH: Thanks for the notes about the make-up oil. Even if everything's fine, 1/4 quart of makeup oil isn't a
concern for most engines, and that's not bad at all considering you had a rear main seal leak. As far as we
can see in this report, everything looks great. All wear metals are at or below average levels, which is good
since averages are based on a slightly longer ~4,300-mile oil run. We didn't find any evidence of harmful
contaminants like fuel, dirt, or moisture, and the TBN of 2.6 shows a good amount of active additive left. Try running 5,000 miles next oil. Nice Jeep!"
Code:
OIL PYB 5w30 Universal Averages
MILES IN USE 3,503 4,300
MILES 131,203
SAMPLE TAKEN 3/2/13
ALUMINUM 3 3
CHROMIUM 1 1
IRON 23 27
COPPER 2 4
LEAD 1 3
TIN 0 1
MOLYBDENUM 258 67
NICKEL 1 1
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 1 3
BORON 89 45
SILICON 11 11
SODIUM 10 35
CALCIUM 2419 2100
MAGNESIUM 18 124
PHOSPHORUS 787 723
ZINC 914 868
BARIUM 0 0
Values should be
INSOLUBLES 0.3
WATER 0
FLASHPOINT ºF 410 >365
SUS VIS 210ºF 56.2 55-62
cSt @ 212ºF 9.11 8.8-11.1
Fuel
Antifreeze 0 0
TBN 2.6 >1.0
Comments:
Code:
MILES 131,203
SAMPLE TAKEN 3/2/13
ALUMINUM 3 3
CHROMIUM 1 1
IRON 23 27
COPPER 2 4
LEAD 1 3
TIN 0 1
MOLYBDENUM 258 67
NICKEL 1 1
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 1 3
BORON 89 45
SILICON 11 11
SODIUM 10 35
CALCIUM 2419 2100
MAGNESIUM 18 124
PHOSPHORUS 787 723
ZINC 914 868
BARIUM 0 0
Values should be
INSOLUBLES 0.3
WATER 0
Fuel
Antifreeze 0 0
TBN 2.6 >1.0
