Originally Posted By: 10cent
Most labs/analysts would condemn an oil with TAN higher than TBN. But looking at the metal numbers, one couldn't tell that any harm has been done. So, is it really a harmful situation that just doesn't show up on a $20 UOA, and if so, what harm exactly is it causing?
Or is it of no concern at all, in which case, why even bother getting the TAN tested?
Diskutieren!
When I requested the TAN Blackstone actually asked if I was sure I wanted to spend the $10 and indicated that it wouldn't provide much useful information in this situation. It would seem they do not believe the TAN being slightly higher than the TBN to be an issue.
I think Doug Hillary covers it well in this post:
Originally Posted By: Doug Hillary
Hi,
mechanix - The two number are "in conflict" if you like
The TBN represents the alkalinity and the lubricant's ability to neutralise acid (D2896 or D4739). A high TBN was required with high sulphur levels in fuels. Typically as the TBN is increased the SA level rises - this is undesirable in certain engine families. So Blenders have a problem - new chemicals have somewhat solved this and we see lower levels of TBN in new products. Ideally we need a mid range TBN and a low SA level for most modern engine families
The TBN falls with use and a condemnation point of 1 D4739 or 2 D2896 is used by a number of engine Manufacturers
The TAN measures the build up of acidic contaminants and is a rising number. There may be a TAN limit in some cases and the two do not form a close and predictable ratio in use - or I have never detected it!
With diesel engine UOAs I have always used both - this has been to confirm one to the other. Lab results do vary and people make mistakes
I never set a TAN limit for my engines nor had one set by an engine Manufacturer
The typical levels at OC for me were TAN 6 and TBN 2 (D4739). I have detected many Lab errors over the years with the TBN being inconsistent in decline - this can be detected by movements with the TAN. This is why trending UOAs - especially within similar engine families - is very important
In heavy high speed diesel engines a low TBN was never a lubricant condemnation point for me - it was always soot or iron levels - or both!
