My 2008 xB is approaching 80K miles... Had my brother get me the coolant from the dealership where he works as I am planning to swap the coolant out tomorrow.
I know it is not a complex process... I just want to do it properly from those who have more knowledge than me.
I figure I will loosen the drain plug on the radiator and let it drain completely with the overflow cap OFF correct? The plug on the engine block I guess is not hard to get to, so once the radiator drained completely I would tighten it back up and then drain out the engine block. Once it stops flowing, plug it back up and I should have a completely drained out system, correct?
Fill the fluid to the "B" line on the overflow tank, squeeze some hoses and once it settles, start the car and let the thermostat open up and let coolant flow. Level will drop, let it cool off and top off fluid again. Repeat until it no longer goes down.
I think that is the process, no? Would appreciate any comments/directions if I am mistaken above on anything.
Thanks guys!
Thanks guys!
