Originally Posted By: martinq
Originally Posted By: cp3
Interesting bypass design, is the inlet in the dome end as it appears?
I don't quite follow. The first pic shows the components in their as-assembled orientation. The neck-end with the spring in it is the outlet.
Oh, I think I see what you're saying. The threaded end-plate is domed, yes. It is also two-layered steel. My guess is to help form the o-ring gap and/or to help with can-crimp. Anyway, this thing is a tank.
Not quite but yes they do look solid. What I meant was it looks like the inlet for the bypass is at the dome end of the element, not the base or outlet end. If you were to press on that black circular thing on the bottom of the element, does it open?
