2nd ever UOA sample. Owner maintained 5k mile interval using Rotella 15w40. Oil was dumped at time of test and refilled with Amsoil OE 15w40.
Make/Model: Navistar 6.4L V-8 Power Stroke Twin Turbo
Vehicle: 2008 Ford F-250
Code:
OIL Rotella 15w40 Rotella 15w40
MILES IN USE 5049 5935
MILES ON UNIT 57K 52K
SAMPLE TAKEN 2/18/13 9/8/12
MAKE UP OIL 0 0
ALUMINUM 45 28
CHROMIUM 2 2
IRON 49 47
COPPER 1 2
LEAD 1 4
TIN 1 0
MOLYBDENUM 9 17
NICKEL 2 1
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 10 10
BORON 23 24
SILICON 6 5
SODIUM 4 5
CALCIUM 1837 1531
MAGNESIUM 85 257
PHOSPHORUS 833 805
ZINC 942 912
BARIUM 0 0
SUS @ 210F 64.5 60.0
Visc @ 100C 11.46 10.21
Flashpoint 385 360
Fuel % 2.5 5.5
Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.3 0.4
Blackstone Comments:
Fuel dilution improved quite a bit this time, dropping from 5.5% to 2.5%. This level is still in the cautionary range, but hopefully it drops again next time. If you had anything fixed in that area, this could be residual fuel from before repairs were made. Aluminum didn't fare quite as well as fuel unfortunately. It increased quite a bit showing more piston wear. The other metals stayed low, which is good. If the engine sees any hard use like idling or towing that might explain some of the wear. Check back in 5,000 miles.
Code:
MAKE UP OIL 0 0
ALUMINUM 45 28
CHROMIUM 2 2
IRON 49 47
COPPER 1 2
LEAD 1 4
TIN 1 0
MOLYBDENUM 9 17
NICKEL 2 1
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 10 10
BORON 23 24
SILICON 6 5
SODIUM 4 5
CALCIUM 1837 1531
MAGNESIUM 85 257
PHOSPHORUS 833 805
ZINC 942 912
BARIUM 0 0
Flashpoint 385 360
Fuel % 2.5 5.5
Water % 0.0 0.0
