Filter was a Bosch Distance plus, Oil is 5w-30, engine has 85k on it, and there was no make-up oil. Nissan 2.0 Automatic, mostly highway driving. About 8 months since last oil change.
Blackstone Comments
We're not sure if this was the 5W/30 version of Castrol Edge or not, so the viscosity may or may not be
out of line. If this was a 5W/30, then the increase might show the oil is starting to thicken a little. That's
probably not related to the increased wear we found this time. Instead, silicon may be more of a factor if
it's from dirt, so check the air filter. We highlighted aluminum last time it read at 6 ppm, but that oil was run
just 4,100 miles. This oil has 15,000 miles on it, so a little more wear is okay. The TBN was mildly low at
1.5, so try just 16,000 miles next time.
Aluminum 6
Chromium 1
Iron 15
Copper 4
Lead 4
Tin 1
Moly 104
Nickel 0
Manganese 1
Silver 0
Titanium 0
Potassium 4
Boron 25
Silicon 42
Sodium 9
Calcium 3356
Magnesium 19
PHOSPHORUS 732
ZINC 910
BARIUM 0
cSt Viscosity @ 100°C 11.36
SUS Viscosity @ 210°F 64.1
Flashpoint in °F 375
I got nearly identical results with Pennzoil Ultra. Same OCI, same comment about silicon, same TBN, wear metals very similar, as well as viscosities. Next up: MPT Industries 30k.
Blackstone Comments
Aluminum 6
Chromium 1
Iron 15
Copper 4
Lead 4
Tin 1
Moly 104
Nickel 0
Manganese 1
Silver 0
Titanium 0
Potassium 4
Boron 25
Silicon 42
Sodium 9
Calcium 3356
Magnesium 19
PHOSPHORUS 732
ZINC 910
BARIUM 0
