Hi, here's the results from my 2008 Silverado 4.8 after 1 year and 13,000 miles of Severe Use. I drive many 1 to 2 mile drives with 1 or 2 8 to 10 miles drives daily and I always have about 1,000 lbs loaded in the bed. Most of my driving is 25 to 35 mph.
Should I change my oil more often because of the base number?, or should I change my filter in the middle of the year (it's the 15k filter from AMSOIL)?
Thanks
Comments Base Number is SIGNIFICANTLY LOW. Bearing metal is at a MODERATE LEVEL; Nickel is at a MODERATE LEVEL; Possible valve
train (valves, stems, guides etc.) metal; Abrasives (silicon/dirt) are at a MINOR LEVEL; Infrared results indicate beginning lube
oxidation; Flagged additive levels are lower than expected for the lubricant that is identified. (This does not imply that the
lubricant does not meet proper API, SAE or ISO classifications.); Replace oil filter and top off system with fresh make-up oil if
not done when oil sample was taken. Re-sample in 3,500 miles or 65 hours.
Nickel 3 -Abnormal
Lead 35 -Abnormal
Molybdenum 78 -Abnormal
Boron 35 -Abnormal
Viscosity at 100 degrees 13.1 -Abnormal
Base Number 2.38 -Critical
Thanks
Nickel 3 -Abnormal
Lead 35 -Abnormal
Boron 35 -Abnormal
