engine here (pdf): http://physics.usc.edu/Undergraduate/temporary/corolla2009/2zrfeeng.pdf
One thing caught my attention:
Quote:
The lining surface of the connecting rod bearing has been micro-grooved to realize an optimal amount of oil clearance. As a result, cold-engine cranking performance has been improved and engine vibrations have been reduced.
Quote:
The lining surface of the crankshaft bearing has been micro-grooved to realize an optimal amount of oil clearance. As a result, cold-engine cranking performance has been improved and engine vibrations have been reduced.
Can someone explain what this is all about?
IIRC, microgrooving increases oil layer thickness independently from viscosity, right?
