When Is "Too Old" To Drive????
by qwerty1234
06/01/16 01:02 AM
Where do peanuts come from ?
by Merkava_4
06/01/16 12:58 AM
Subaru V-twin engines
by oil pan 4
06/01/16 12:25 AM
Napa June 2016 sale 6/1-6/30
by slacktide_bitog
05/31/16 11:42 PM
Castrol SAF Carbon Modified SAE 75W/85
by ABomb369
05/31/16 10:44 PM
any harm done to Ranger?
by mobilaltima
05/31/16 10:17 PM
Obsolete Freeway on ramps
by jimbrewer
05/31/16 10:14 PM
Ideal-Tridon Hose Clamp Display
by Merkava_4
05/31/16 08:52 PM
Want to hear from turbo owners that go 10k + oci
by Sw296inchblue
05/31/16 08:31 PM
When you have found the right combo
by bbhero
05/31/16 08:25 PM
High Mileage diesel oil?
by Hysilver
05/31/16 08:23 PM
Barium
by Hullthumper
05/31/16 07:25 PM
alex_at, AudiTDI, Denisdog, bcs4, Bart_B
58036 Registered Users
28 registered (BigD1, bbhero, crazyoildude, Atesz792, cwing6, 69GTX, 2 invisible), 541 Guests and 99 Spiders online.
58036 Members
66 Forums
249652 Topics
Page 1 of 2 1 2 >
#2883544 - 01/25/13 10:30 AM Stuck Oil Filter on 2010 Toyota Prius, a Solution
Jac09 Offline
Loc: FL
The oil filter housing on Prius can be overtightened by shops and may be unable to remove with a standard filter wrench with a hex cap shape alone. I tried to remove it on my Prius with a standard wrench. The result was that the little round plate with the 3/8 ratchet fitting in the center that is spot welded to the filter wrench just broke right off of the wrench at the spot welds.
After looking around on the web, I found a filter wrench that grabs not only the hex top, but the entire cap including the six tabs that stand up from the base of the filter cap. This filter wrench has six slots at the edge that fit down over these tabs that make it impossible for the wrench to slip. It is well constructed; it is made from a solid cast pour not rolled thin sheet metal. It has 64.5 mm width and probably works on several model years.
The filter wrench is manufactured by Private Brand Tools or PBT, part number 71110 of Australia. It can be found on Amazon or EBay. I bought it from Amazon.com for $27 including shipping. It was well worth the money. The filter came off the first time I turned the wrench. Nothing else would get it off and I didn't have to wrap the filter housing in cloth to ensure a tight fit either.
2010 Toyota Prius
2001 Nissan Frontier SE
#2883559 - 01/25/13 10:45 AM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: Jac09]
bepperb Offline
Loc: Milwaukee, WI
You didn't want to pound a screwdriver through the filter?
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#2883560 - 01/25/13 10:47 AM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: Jac09]
Corvette Owner Offline
Loc: Waldorf, Maryland
I use a two prong, self adjusting filter wrench to remove all my filters. It has never failed. It actually grips tighter the harder you turn. Here is a three prong one from SEARS:
http://www.sears.com/shc/s/p_10153_12605...l%20Filtermv=rr
I only use it to REMOVE filters as it will deform them. I use a cap wrench or my hand to install filters.
Edited by Corvette Owner (01/25/13 10:49 AM)
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#2883561 - 01/25/13 10:47 AM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: Jac09]
Hokiefyd Offline
Loc: North Carolina
I've removed many stuck filters with driving a screwdriver through the filter and turning it. Had to do that with my co-worker's 2012 Honda Civic. I don't have a cap wrench that fits a Honda OEM filter, and the filter was too far up behind other parts (and hanging vertically) to use a strap wrench. So I had to put a screwdriver through it.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2883565 - 01/25/13 10:52 AM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: Jac09]
ZeeOSix Offline
Loc: PNW
OP is talking about a cartridge filter housing cap. Here's the tool he refereed to. Can't do the screwdriver trick on this setup. frown
http://www.amazon.com/Private-Brand-Tools-PBT71110-Cylinder/dp/B005R3SSMW
#2883572 - 01/25/13 10:56 AM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: Jac09]
Hokiefyd Offline
Loc: North Carolina
Well, my bad indeed!
Cheers,
Jason
#2883576 - 01/25/13 11:01 AM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: Hokiefyd]
The_Jake Offline
Loc: Michigan, USA
I use the Assenmacher one...never fails and you can put a 1/2" drive on it.
http://www.ebay.com/itm/Toyota-Oil-Filte...839&vxp=mtr
#2883594 - 01/25/13 11:17 AM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: ZeeOSix]
bepperb Offline
Loc: Milwaukee, WI
You just have to want it bad enough....
Kidding aside I have the assenmacher as well and it works on our Sienna. I've seen people use a big vise grips on those nubs down by the base as well. Hopefully this isn't a problem I run into, though.
2004 Highlander 2.4
Recently Gone:
1993 Kawi EX 500
#2883595 - 01/25/13 11:17 AM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: Jac09]
Jac09 Offline
Loc: FL
You would not believe these Prius oil filter housings. It is a big, solid piece of plastic that holds a paper-synthetic filter. It has male threads on the outside of the lower portion and an o-ring to seal it when it is screwed into the receiving cavity in the motor.
I have never had to apply so much pressure to an oil filter to get it off before. I used a short piece of pipe to extend my ratchet handle about 1.5 feet. It was strange, though, that using this PBT filter wrench made the job a lot less difficult. You have to have the right tool for the job.
Edited by Jac09 (01/25/13 11:21 AM)
2010 Toyota Prius
#2883611 - 01/25/13 11:26 AM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: The_Jake]
mikered30 Offline
Loc: PA
That is the one I have. Amazon has it for a few dollars cheaper.
#2883674 - 01/25/13 12:21 PM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: Jac09]
HTSS_TR Offline
Loc: Lake Forest, CA
Assenmacher oil filter end cap tool is one of the best for remove/install cartridge oil filter housing. Amazon has Toyota 640 for only $17.xx
http://www.amazon.com/Assenmacher-Specia...Assenmacher+640
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2883692 - 01/25/13 12:38 PM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: Corvette Owner]
Brybo86 Offline
Loc: Chicago, IL
+1 the craftsman universal oil filter wrench works great and will grip even if filter is covered in oil. It also works to get at the filter in tight spaces where you cant get a big channelock wrench around it.
+1 only use it to remove filters and only hand tight to install the filters.
08 Honda Accord EX-L 2.4L RP 0w20 116k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 178k
95 Yamaha Jog
86 Kawasaki 454Ltd Valvoline 20w50 18k
#2883715 - 01/25/13 12:55 PM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: Jac09]
zerosoma Offline
Loc: Omaha, NE
When we got our Prius the dealership had screwed the filter on so tight it would not budge at all. I almost pulled a muscle trying to get the sucker off.
I finally got a filter wrench (the ones that look like pliers) and gripped on it. I twisted and turned it, and got it off. When I did the thing looked like a crushed pop can but it worked.
I'd try the pliers type filter wrenches.
2004 Hyundai Santa Fe LX 3.5L V6 (125k) [Valvoline Max Life Next Gen 5w30]
#2883808 - 01/25/13 02:06 PM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: zerosoma]
The_Jake Offline
Loc: Michigan, USA
I use the assenmacher and a 1/2" cordless impact wrench. Zips those stuck on ones right off.
#2883816 - 01/25/13 02:14 PM Re: Stuck Oil Filter on 2010 Toyota Prius, a Solution [Re: HTSS_TR]
GSCJR Offline
Loc: Ontario, Canada
Recently got one free! Works great...previous filter changer forgot it on the filter housing. It was a Kia Sedona however.
03 3.0L 1MZ-FE FS 5w-20-ProSelect 21348-215 KM
10 3.5L 2GR-FE CEB 0w-20-ProSelect 27047-135 KM
Page 1 of 2 1 2 >
