Oil filtration and circulation question
by Doublehaul
13 minutes 26 seconds ago
Anyone ever replaced brake fluid on Honda Pilot?
by Islandvic
35 minutes 16 seconds ago
Unused WIX 51372-051815C2 cut & post
by WellOiled
Today at 08:37 PM
-31 this morning...without the wind chill!
by Doublehaul
Today at 08:00 PM
Cleaning Throttle body, necessary service now?
by Colt45ws
Today at 07:33 PM
[Cut Open] Ford OE (FL500S equivalent) 4948mi
by DuckRyder
Today at 07:20 PM
[Cut Open] Fram XG3600 - 9098mi
by DuckRyder
Today at 07:16 PM
T rated General Altimax tires on 2012 Corolla?
by Corollaman
Today at 07:00 PM
Best container to store tools underground ?
by Merkava_4
Today at 06:45 PM
ESET antivirus - 3 years for $20
by greenjp
Today at 06:00 PM
Fram Ultra XG9972 11k Miles
by SF0059
Today at 06:00 PM
Antonin Scalia is dead
by skyactiv
Today at 05:04 PM
Formula413, Cruzingoose, klob, beaglefet, bsmith3
56907 Registered Users
103 registered (2015_PSD, ammolab, andyd, AlienBug, anonobomber, 90crvtec, 12 invisible), 1263 Guests and 106 Spiders online.
56907 Members
66 Forums
244664 Topics
#2878018 - 01/20/13 05:13 PM AC Deco PF-46 cross references
palmer_df0130 Offline
Loc: NC
I have a question about the PF-46 and other oil filter manufactuers recommended size filters for my application. I have a 99 Chevy Silverado with the 5.3l and when you look up a filter at an autoparts store online or at the store it always has the PF-46 listed, but the other brand of oil filters have a longer filter recommened. If you cross reference a PF-46 to say a Fram for example it will give you the 3506, but the application guide will say a 3675 or the Bosch is a 3423. Why do they recommend the bigger filter instead of the PF-46 size equivalent same size filter?
#2878184 - 01/20/13 07:11 PM Re: AC Deco PF-46 cross references [Re: palmer_df0130]
Tzu Offline
Loc: near Buffalo, NY
I have a 2000 Silverado 1500 2WD with the 5.3 liter too. Originally it took the PF59 but they discontinued it for whatever reason. It's now supposed to use the PF46 but I prefer to use the larger PF61 instead because it hangs vertically and seems to work well. My daughter's 2.4 liter Grand Am 4 cylinder uses the PF46. I buy the non e-core AC's at Autozone instead of Walmart. Seems like too small of a filter for a V8?
2000 Silverado 1500, 5.3 271K
2000 Impala LS, 3800 245K
1991 Camry DX, 3sfe 318K
#2878202 - 01/20/13 07:26 PM Re: AC Deco PF-46 cross references [Re: Tzu]
GSCJR Offline
Loc: Ontario, Canada
I recently noticed that too when changing the oil on a GM Express van 4.8L
Calls for the short filter according to FRAM. Put on a Defense DL3506. Next time will use the filter in my signature.
03 3.0L 1MZ-FE GTX 5w-20-ProSelect 21393-210 KM
10 3.5L 2GR-FE CEB 0w-20-NAPA Gold 7047-130 KM
#2878502 - 01/20/13 11:18 PM Re: AC Deco PF-46 cross references [Re: GSCJR]
Loc: NC
Yeah, right now I have the Fram Ultra Guard 3506 on my truck, but got a Bosch 3423 waiting to be put on on the next oil change. I'm using Q.S. Defy 5w-30 with the ultra guard currently and noticed my oil pressures are a little higher then when I ran the PF-46 and/or longer filters with Q.S. UD 5w-30. Going to switch back to QSUD.
#2878875 - 01/21/13 11:15 AM Re: AC Deco PF-46 cross references [Re: palmer_df0130]
GSCJR Offline
Don't know what I drained out. Put in some vintage QS Q-Horsepower 5w-30 from my stash. Not sure what will be on deck by the end of this OCI. Uses about 1L between OCI according to the driver.
#2878982 - 01/21/13 01:14 PM Re: AC Deco PF-46 cross references [Re: GSCJR]
GSCJR Offline
Actually, it was some QS Advanced Engine Fully Synthetic SM...just saw the empty bottles. I love those clear bottles.
#2879164 - 01/21/13 03:40 PM Re: AC Deco PF-46 cross references [Re: palmer_df0130]
3311 Offline
Loc: Fl
Here are some other oversized filters that will work:
Wix 51045(4.8" long)
51522
Purolator
L20123
L25288(carried at Walmart)
Delco
PF59
Baldwin B30
Edited by 3311 (01/21/13 03:53 PM)
04 2500hd 6.0 278k/1k Pen HM 5w30 10w40 mix XG3675 VML ATF Dex
03 C7500 Dmax7.8l 134k ST 15w40,M1ATF Dex
06 2500hd 6.0 220k ? 5w30 ST DexVI PGL
#2879183 - 01/21/13 03:58 PM Re: AC Deco PF-46 cross references [Re: palmer_df0130]
GSCJR Offline
Thanks 3311, good to know.
#2879214 - 01/21/13 04:27 PM Re: AC Deco PF-46 cross references [Re: 3311]
Loc: NC
That is my question, why do other oil filter manufacturers recommend the longer filter instead of one the same size as the PF-46?
#2879317 - 01/21/13 06:09 PM Re: AC Deco PF-46 cross references [Re: palmer_df0130]
dailydriver Offline
Loc: Bucks County, Pa.
GM recommends the shorter filter for my engine, but I ALWAYS use the longer, truck 4.8/5.3 specced, filters for my changes in either; Amsoil, NAPA platinum, M1, or Bosch D+.
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#2879472 - 01/21/13 07:46 PM Re: AC Deco PF-46 cross references [Re: palmer_df0130]
steve20 Offline
Loc: Morris County NJ
could be the difference is due to the 2WD & 4WD platforms. With
GM usually the 4WD filter is shorter
427 Chevy Powered
