Who watches the oil co's?
by Camprunner
23 minutes 36 seconds ago
Magnetec "Edged" out?
by ARCOgraphite
33 minutes 9 seconds ago
Let's talk RUM
by car51
44 minutes 36 seconds ago
Any .257 Roberts Reloaders On The Site?
by 2015_PSD
Today at 01:18 PM
Making tacos at home
by Reddy45
Today at 12:41 PM
Wiring a new garbage disposal
by Hokiefyd
Today at 11:38 AM
Power Steering Fluid
by DWC28
Today at 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
Today at 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
Today at 08:05 AM
kohler courage 15 issues
by tomm22
Today at 07:58 AM
Small overlap crash test?
by Huie83
Today at 07:39 AM
Top Tier Fuels and Tailpipe deposits
by virginoil
Today at 07:20 AM
Ken_Clifton, HotDog15, curiousaboutoil, 01CAMRY, corndogzombie
58589 Registered Users
91 registered (4WD, Alfred_B, 182RG, AIRJAC3, 87sammy, 2015_PSD, 9 invisible), 2169 Guests and 24 Spiders online.
58589 Members
66 Forums
252234 Topics
#2851813 - 12/29/12 06:41 PM 02 Xterra V6 3.3 V6 tiny oil capacity.
6lbsoft Offline
Loc: Southern California
Not quite sure as to what the Nissan engineers were thinking when they designed the 3.3 V6 that goes in the Xterra, Pathfinder, etc... My wife's 02 Xterra has a oil capacity of 3 and a half quarts ...with the filter. The filter , I believe is a Fram Ph7317, which looks like it would be better off filtering the oil from a Briggs and Stratton engine. Since we met I have been doing the oil changes on it (currently at 135k miles), my mouth hit the ground when she said she normally had an oil change every 7k or "whenever I remembered" as she said. But to my suprise to this day the Xterra doesn't leak or burn any oil. Even after 4,000 miles it is still full on the dipstick. Pretty stout engine IMO lol... Ive decided to run Mobil Clean 5000 5w30 and a Tough Gard filter with a OCI of 3,500-4k, but im open to what you guys think with an engine that has such a small oil capacity...
03 Ford Crown Vic P71, Castrol Magnatec 5w-20, Motorcraft filter, 170k.
02 Nissan Xterra SE, 3.3L 76 Super Semi-Syn 5w-30, STP filter, 153k.
#2851829 - 12/29/12 07:02 PM Re: 02 Xterra V6 3.3 V6 tiny oil capacity. [Re: 6lbsoft]
Mr Nice Offline
Loc: Orlando, FL
Any oil will do just fine but I would simply use 4 quarts.
2007 Civic EX
2006 Accord SE
2005 RSX base
#2851839 - 12/29/12 07:10 PM Re: 02 Xterra V6 3.3 V6 tiny oil capacity. [Re: 6lbsoft]
yonyon Offline
Loc: NJ, USA
I believe they were thinking of keeping the pan up out of the way of things that could poke holes in it. If that's so they seem to have gotten it right. Somehow they also managed to avoid the "rust holes in oil pan" problem that so many other Nissans with a steel pan tended to develop. 3 and a half quarts doesn't sound like much oil to have in the sump + filter, but it's a lot better than 4 and a half on the roadway.
#2851840 - 12/29/12 07:11 PM Re: 02 Xterra V6 3.3 V6 tiny oil capacity. [Re: 6lbsoft]
simple_gifts Offline
Loc: Middlesex County CT
You have to wonder how much oil is really needed assuming it could be run 1 qt low (maybe like most engines) with no damage?
2003 Echo >392K miles; Castrol 5W-50
2006 B2300;108K;ALM
Please conserve paper; it is not like it grows on trees.
#2851854 - 12/29/12 07:23 PM Re: 02 Xterra V6 3.3 V6 tiny oil capacity. [Re: 6lbsoft]
beast3300 Offline
Loc: Ohio
Tiny capacity yes. They are very durable engines though. I believe somebody on here ran M1 for 10k with one of those. (No not Tig)
'03 Regal GS L67 3.29 GR:, PUP 5w30/TG3980, Filtermag
'99 Grand Prix L36: QS Defy 5w30/TG3387A, Filtermag
#2851895 - 12/29/12 07:54 PM Re: 02 Xterra V6 3.3 V6 tiny oil capacity. [Re: 6lbsoft]
Kiwi_ME Offline
Loc: New Zealand
Yep, a great engine. You could use a Pure One or M1 filter. I had an '00 X for 4 years in SoCal, ran M1 5W-30 @ 7,000 mile intervals, did drop to about 2/3 between changes. Sump is tall and thin to avoid front diff. Nothing wrong with the 3.5 Q capacity.
#2851962 - 12/29/12 09:13 PM Re: 02 Xterra V6 3.3 V6 tiny oil capacity. [Re: 6lbsoft]
6lbsoft Offline
Thanks for the input, makes me more at ease =)
#2852010 - 12/29/12 09:59 PM Re: 02 Xterra V6 3.3 V6 tiny oil capacity. [Re: 6lbsoft]
mechtech2 Offline
Loc: Chicago Area
5 qts was standard - very common - for American V8s.
Now, with engines half the size, why be concerned with a bit less oil?
Proportionately, now many should have even LESS than 3.5 qts.
#2852031 - 12/29/12 10:20 PM Re: 02 Xterra V6 3.3 V6 tiny oil capacity. [Re: 6lbsoft]
stang5 Offline
Loc: Reno
My 1991 Pathfinder with 3.0 V6 only takes 3.25 qts to fill the sump, I added a remote filter kit for easy accessibility and that brought the capacity to 4 qts..
2002 Mustang GT (M1 5w20)
2011 Infiniti G37x (M1 5w30)
2008 Nissan Pathfinder LE V8 (M1 5w30)
1991 Nissan Pathfinder SE (PYB 5w 30)
#2858418 - 01/04/13 05:18 PM Re: 02 Xterra V6 3.3 V6 tiny oil capacity. [Re: 6lbsoft]
6lbsoft Offline
I guess I am used to my Crown Vic and its 7 quart capacity lol.
