Autozone clearance
by docsteveg
05/25/13 04:29 PM
any advantage of 10W-30 over 5W-30 or 0W-30?
by LScowboy
05/25/13 03:39 PM
1985 ford f150 5 liter keeps shorting coil....help
by GoHeels1981
05/25/13 03:09 PM
Craiglist Selling Tips?
by Rock_Hudstone
05/25/13 03:07 PM
Craftsman 154 pc Mech.Tool Set ~$75 + Free Ship..
by sayjac
05/25/13 03:01 PM
Need assistance on oil filter brand
by Eosyn
05/25/13 02:28 PM
PENNZOIL ULTRA 0W-40 eBay.....
by Hethaerto
05/25/13 02:20 PM
Oil for 03 Camry with low miles?
by gregoron
05/25/13 01:51 PM
Pennzoil synthetic blend vs full synth
by kenpoed
05/25/13 01:03 PM
PYB stopped my Ticking!
by Realtech214
05/25/13 12:36 PM
Proposed Tesla Ban in North Carolina
by 97prizm
05/25/13 12:21 PM
1991 Indirect injection diesel / no emissions
by polux
05/25/13 11:43 AM
goodolboy, Rick_Kean, patmoetighe, ohbehave, Maritimer
45560 Registered Users
102 registered (147_Grain, AandPDan, 05LGTLtd, 04SE, 77GrandPrix, 285south, 8 invisible), 1640 Guests and 241 Spiders online.
45560 Members
64 Forums
193943 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 2 of 2 < 1 2
#2828825 - 12/09/12 01:15 AM Re: If it were yours, when would you change the ATF? [Re: martinq]
LineArrayNut Offline
Loc: East TN
Originally Posted By: martinq
Is there a pan that can be pulled? If so, you might be able to unbolt (or loosen) the valve-body from underneath and get 80-90% of the old oil out. Also pull the cooling lines and drain those too.
Then do the cooling-line flush. You might be able to see the difference from old-to-new fluid as it pumps out.
Otherwise, I'd just do a cooling-line flush and do yearly fluid analysis w particle count if possible. You need to get a baseline set and after a three or four analysis you'll have your trend going so you can setup your next flush.
AFAIK, no pan. There's a drain bolt. It has that silly 'yota type weep hole fill gauge. No dipstick. No real filter, it's a rock screen that's only accessible by pulling trans and splitting in half.
'11 Sonata SE 2.0T 2RT6 RL0W30 M1MX4T,0W40 LGBT Microgreen
'03 Honda SuperHawk VTR1000 M115W50 ST
'94 Jeep GC 5.2L GET5W30 Kreen XG
'84 S10 V8 M1HM M1
#2829186 - 12/09/12 12:07 PM Re: If it were yours, when would you change the ATF? [Re: LineArrayNut]
martinq Offline
Loc: ON, Canada
Well there ya go. Do the cooling-line flush as best you can and put in the filter. Drive it for one tank of gas and then prep two samples for analysis. One from the bottle and one from the pan.
If you are going to do analysis you might want to get a Fumoto drain valve for the tranny as it'll make it much easier & cleaner. While you're at it get one for the engine.
You want to get analysis for viscosity, TAN (or TBN) and particle count. After a year (how much do you drive in a year?) do another analysis and the picture will start to come together. This will allow you to get the best use of the D4 and will also keep you informed if there's anything unusual.
#2829225 - 12/09/12 12:56 PM Re: If it were yours, when would you change the ATF? [Re: martinq]
Loc: East TN
It has the aero belly pan, so that's why I say that AFAIK. It's got holes for oil filter and a removable door for engine oil pan bolt. I've got a fumoto on the engine oil pan, makes it whole lot easier. About 18K miles/yr.
I'm liking TallPaul's idea best so far...
Originally Posted By: TallPaul
I'm for a complete flush to get a total fill of the Redline D4 ATF. I would think if you do that every 30,000 miles you are fine.
Edited by LineArrayNut (12/09/12 12:59 PM)
'84 S10 V8 M1HM M1
#2829835 - 12/10/12 02:38 AM Re: If it were yours, when would you change the ATF? [Re: LineArrayNut]
01rangerxl Offline
Loc: Birmingham, AL
It pains me to go past 30K on trans fluid. I'm sure the trans wouldn't care that much, but in my mind, that's the cutoff for automatics. Mine has 133K and shifts beautifully despite a fair amount of abuse including towing, tire roastings, suddenly gaining traction (probably worse for the diff), and countless 5000 RPM+ shifts.
As good as I am about changing fluid before it gets to 30K miles, the filter is original, and the pan has never been off. I was going to have the filter changed, but the dealer insisted it was not necessary. I think they didn't want to pop the pan off on a trans that isn't leaking, and I didn't want to do it in my driveway, so I guess I can't blame them for avoiding that one. This truck and my old Explorer have both been happy with Mercon V flushes and no other trans maintenance. No trans repairs ever in either vehicle. I sold the Explorer at over 158K miles and it still shifted perfectly.
2002 Ford Ranger XLT
3.0 V6 / 5-Speed Automatic / 2WD
140K miles
#2830032 - 12/10/12 09:24 AM Re: If it were yours, when would you change the ATF? [Re: LineArrayNut]
Rhymingmechanic Offline
Loc: VA
If it were mine, used hard, and I had the materials on hand, I would do it as soon as it's convenient.
A drain plug makes it so easy there's no reason not to at least drain and fill, even if you don't install the filter at the same time. I changed to Mobil 1 in my easily driven Silverado around 36,000, and the original oil was sparkly. In my Vibe (bought used), it looked like motor oil with glitter mixed in at 28,000. If the pans didn't have drain plugs, both would have been a lot worse by the time I got around to dropping the pans by the old ATF bath method.
You have to disconnect or cut cooler lines to install the Magnefine, which is half the work of the flush anyway. You might check the total capacity vs. drain capacity, though. If a drain gets out most of the fluid, you could save the mess of a flush and just do a couple drains together followed by a regular change interval.
#2830108 - 12/10/12 11:03 AM Re: If it were yours, when would you change the ATF? [Re: LineArrayNut]
Eddie Offline
Loc: Florida, Cape Coral
First change at 25K then every 40K
#2831726 - 12/11/12 05:43 PM Re: If it were yours, when would you change the ATF? [Re: LineArrayNut]
artificialist Offline
Loc: Florida
I'd flush it out at 30,000 miles, and run longer intervals later on. The OEM fluid I find in Hyundai cars becomes dirty very quickly.
2010 Lancer Ralliart Sportback
#2847028 - 12/25/12 03:54 AM Re: If it were yours, when would you change the ATF? [Re: LineArrayNut]
Loc: East TN
Looks like I'm gonna do 30K; probably do a cooler line flush.
'84 S10 V8 M1HM M1
#2868948 - 01/13/13 10:32 AM Re: If it were yours, when would you change the ATF? [Re: Bandito440]
djkurious Offline
Loc: TN
Originally Posted By: Bandito440
Full flush at 30k to get the break-in metals out. Drain & fills every 15k thereafter.
This.
Page 2 of 2 < 1 2
