Looking for info on two quick spray waxes.........
by demarpaint
05/01/16 04:43 AM
The Heroin Epidemic In The U.S....
by qwerty1234
05/01/16 01:28 AM
Air filter wrap
by Duffyjr
04/30/16 10:21 PM
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
04/30/16 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
04/30/16 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
04/30/16 09:34 PM
What to use in 99 Buick Lesabre OCI?
by Duffyjr
04/30/16 09:26 PM
Help w/Transmission Drain/Fill 08 Honda CR-V 4wd
by klt1986
04/30/16 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
04/30/16 08:10 PM
Group 5 synthetic oil
by Brayden
04/30/16 08:07 PM
Pennzoil Ultra platinum at Walmart
by RubentheIowan
04/30/16 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
04/30/16 08:03 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
52 registered (Bandito440, bmod305, BobFout, bbhero, AirgunSavant, BobsArmory, 1 invisible), 801 Guests and 93 Spiders online.
57758 Members
66 Forums
248282 Topics
#2844505 - 12/22/12 06:12 PM Walmart Fuel System(?) / Injector Service
FoxS Offline
Loc: CA
So I went in to Walmart for the Fuel System Cleaning service.
When I asked for the Fuel System service, the technician asked "Fuel Injector service" and I said yes, not thinking much about the difference in wording.
So I watched the technician with brief interruptions and also went out to talk to him to ask what he was using.
He had put in Valvoline fuel injector cleaner into the tank after attaching the canister to the underside of the hood.
When he showed me the bottle and I asked what did he use in the engine compartment, he said he used the same thing.
I had missed watching him entirely so did not witness exactly what he did up front except to see him screwing a canister onto the apparatus he had attached to the underside of the good.
So I'm wondering if he used just a single bottle of Valvoline fuel injector cleaner for both the air intake and the tank.
And I'm wondering whether Walmart have downgraded the service from using something stronger ie fuel system cleaner to the weaker fuel injector cleaner
The paperwork reads "Fuel Injector Service"
The vehicle has improved performance though. Not as dramatic as when I cleaned the TB and used PEA cleaner a couple of times but it seems to have gotten rid of a "scraping" type noise I heard during harder acceleration.
#2844555 - 12/22/12 07:05 PM Re: Walmart Fuel System(?) / Injector Service [Re: FoxS]
dishdude Offline
Loc: Phoenix
You want the service where they connect a can of cleaner to the schrader valve on the fuel rail, and run the car at idle off of that for 5 mins or so. Usually these kits also follow up with an in tank cleaner and throttle body cleaner.
What kind of car? Rarely do injectors need cleaned if quality fuels have been used.
#2844612 - 12/22/12 07:57 PM Re: Walmart Fuel System(?) / Injector Service [Re: FoxS]
Colt45ws Offline
Loc: Central Washington
Its a kit with a Can of intake cleaner, which screws onto the setup which meters it into a vacuum line. It also includes a separate bottle that goes into the tank.
-Colton
2002 Ford Crown Vic PI, 180k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
#2844618 - 12/22/12 08:04 PM Re: Walmart Fuel System(?) / Injector Service [Re: FoxS]
FoxS Offline
Loc: CA
Exactly, though they call it injector service, they run it through the air intake. This is what I wanted done because all the short trips had created lots of carbon and I had only cleaned the throttle body and the combustion chamber.
The fuel injector cleaning that they do is done through the tank additive. This part I wasn't interested in as I have a stash of PEA cleaner already
The point of my post was
1) They call it fuel injector service now not fuel system cleaning service
2) They use Valvoline fuel injector cleaner in the tank
3) I don't know for sure what they used through the air intake. The tech suggested it was also the Valvoline fuel injector cleaner
4) I'm wondering whether they have downgraded the service by using fuel injector cleaner in both air intake and tank and this is reflected in the name change of the service to fuel injector service
#2844635 - 12/22/12 08:35 PM Re: Walmart Fuel System(?) / Injector Service [Re: FoxS]
dishdude Offline
Loc: Phoenix
Why would you let Wal-Mart touch your car?
#2844670 - 12/22/12 09:14 PM Re: Walmart Fuel System(?) / Injector Service [Re: dishdude]
antiqueshell Offline
Loc: chicago, Illinois
Inquiring minds want to know! eek
#2844730 - 12/22/12 10:41 PM Re: Walmart Fuel System(?) / Injector Service [Re: FoxS]
FoxS Offline
Loc: CA
Believe it or not, this is an ok Walmart, and I watched them.
Additionally, this is a pretty safe operation that I can check afterwards ie did they put the hose back correctly.
#2844910 - 12/23/12 07:17 AM Re: Walmart Fuel System(?) / Injector Service [Re: FoxS]
Eddie Offline
Loc: Florida, Cape Coral
My Walmart has very good auto service.
CX5 Touring 2.5L :-)
#2848026 - 12/26/12 11:11 AM Re: Walmart Fuel System(?) / Injector Service [Re: FoxS]
tommygunn Offline
Loc: usa
Yep, have had no issues with service at WM TLE in my area....still has some of the original employees since 4+ years ago....which is a good sign (they aren't disposable, fly by nighters.....etc....whatever you wanna call them) in my opinion.
But yes, they previously used a GumOut 2-Step Fuel System Cleaning, which was actually prettty much the same thing as the new Valvoline.....only the Valvoline is said to be a "No Smoke" Cleaner.....which I didn't quite understand......and well, my neglected 1988 Dodge K, it had it smoke alright wink LOL.....stunk really bad as well too......which I was kind of surprised....since I am fairly consistent with FIC, tank doses, etc.......typically use Berryman's CHEMTOOL once a year, and MMO every tank or so.....with varying dose amounts....
So yea, I was quite surprised with the carbon/smoke coming out of the tail pipe.
Whole process took about 30 minutes.....I got it done as a combo, where they do the Fuel Injector Cleaning, then did a High Mileage Oil Change afterwards, for 40$.....so I saved about 20$ (HM oil change is typically $40 alone......and the Fuel Injector Cleaning is $20)...
Was happy with the service.....but yes, they hook up the apparatus through the PCV valve, or other vacuum line. And then pour the other bottle through the fuel tank, so they kind of "meet in the middle" at the fuel injectors, and clean up the intake, etc....
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
#2854041 - 12/31/12 06:19 PM Re: Walmart Fuel System(?) / Injector Service [Re: FoxS]
GMBoy Offline
Loc: Texas
It does sound like a fuel system cleaning as they really are not doing any strong cleaning thru the actual fuel rail and injectors. They should not call this a fuel injector cleaning service. Rip off to me.
You could do what they did yourself for $5 and 5 minutes with a can of intake cleaner.
