my Buick 03 lesabre has a flashing radio light?
by snake123
08/31/16 10:25 PM
5000 miles in the Caprice
by ls1mike
08/31/16 10:01 PM
Copper Reactivity and BMW Blue Coolant
by TXCarGeek
08/31/16 09:24 PM
lubegard biotech xle
by mobilaltima
08/31/16 09:05 PM
Schaeffer 5w-40 in Jeep 4.0
by JeepWJ19
08/31/16 08:53 PM
PP and PU 45% off this wk at CT !!!
by ST2008
08/31/16 08:49 PM
Photographic evidence of HDEO / synth oil cleaning
by OldEuroCarLover
08/31/16 08:35 PM
Limited Slip Additive needed for G80?
by Nick1994
08/31/16 08:28 PM
4-5k will it even matter?
by Camprunner
08/31/16 08:19 PM
Purolator BOSS
by kenpoed
08/31/16 08:04 PM
Neither Key Fob Works!
by bobbob
08/31/16 07:59 PM
How long can I go?
by kenpoed
08/31/16 07:53 PM
JoeI, binarycache, MarkieB, albertson, Chevy538487
58973 Registered Users
72 registered (4WD, 01rangerxl, AIRJAC3, AirgunSavant, asiancivicmaniac, 2015_PSD, 7 invisible), 1458 Guests and 10 Spiders online.
58973 Members
66 Forums
253837 Topics
#284103 - 02/07/05 08:21 AM LubeGuard Red in 4L60E?
Islandvic Offline
Loc: South Texas
My brother has a '95 Z-71. It has never had a transmission service in its 150k mile service life.
I want to drop the pan, clean it, replace the filter, and refill, then get it flushed ( I don't think there is a TQ drain plug).
Has anyone used Lube Guard Red in a 4L60E before?
I figure it will need (2) 10 oz. bottles.
I have heard conflicting stories about servicing a trans with 150k miles with no service history.
Some say service it. Some say leave it be because sludge may dislodge and clog a valve body.
If I drop the pan, and clean it, there would be no sludge left, right? Can sludge be lurking in the trans cooler or other places that may dislodge?
What Dexron AFT fluid is a good brand?
Your opinions and observations please.
Thank you.
#284104 - 02/07/05 08:40 AM Re: LubeGuard Red in 4L60E?
MolaKule Offline
Loc: Iowegia - USA
Drop pan, clean pan, replace filter, replace gasket and refill with DexronIII/Mercon.
In my opinion, your brother is about 120 k miles overdue.
#284105 - 02/07/05 08:42 AM Re: LubeGuard Red in 4L60E?
rugerman1 Offline
Loc: .
Additives, Fuel,Oil, Cleaners SEARCH
Search Words: LUBEGARD
Search In: Subject Only
I got 19 hits.Hope there's some info in there for you.
#284106 - 02/06/05 09:13 PM Re: LubeGuard Red in 4L60E?
JHZR2 Offline
Loc: New Jersey
cant really expect something to go without service for 150k (if its specced for PR before then), and then get worked on and have flying credentials. Youve got to expect some pretty bad conditions, and thus $$$ expenditure to get it right. Just the way it goes in the automotive world.
that said, its a pretty good trans, and at some time around 95, they started putting in '100k mile fluid' in some GM trucks. So he MAY have some saving grace from that...
I like castrol dexron III, available at autozone.
I have a car that has always had its service, and some places will refuse to change fluid because of the mileage (200k+). But some places are stocked with idiots too. I have read situations where transmissions were severely undermaintained (this one may be undermaintained from 50k-120k, depending on specified fluid service life), and had the fluid changed, got all sorts of problems, had it changed, with filter a few more times, and then it was OK.
I would advise against any sort of flush, or even any special additives. Make the services very gradual... first change fluid and filter, with just dexron. Repeat after a few hundred miles. repeat again after a thousand, then drain just the fluid in the pan after another thousand. drive 1000 more, then replace fluid and filter, add the LC, lubrigard, etc.
This of course assumes not real issues. If problems arise, then I would waste no time to find a good shop and get it repaired. poor maintenance has its costs.
JMH
#284107 - 02/07/05 12:26 PM Re: LubeGuard Red in 4L60E?
BlazerLT Offline
Loc: Canada
No need for extra additive in your transmission.
The fresh fluid will have all the additive needed.
#284108 - 02/07/05 07:31 PM Re: LubeGuard Red in 4L60E?
Not the Autorx Frank Offline
Loc: So Cal
MIght consider 5 or 6 partial drain and refills to prevent any shock to the system. (after the filter change)
#284109 - 02/08/05 08:04 AM Re: LubeGuard Red in 4L60E?
Elroy the Unique Offline
Loc: California
Ask a professional transmission shop and they will probably recomend a fluid change and the lubegard.
Lubegard is a great product that can free sticky mechanisms and bring a neglected transmission back to life. That is why some manufacturers issue service bulletins recommending it by name.
#284110 - 02/07/05 10:14 PM Re: LubeGuard Red in 4L60E?
Ken2 Offline
Loc: Washington St.
I'd first clean the transmisison with Auto-Rx. I'd install an in-line transmission filter at the beginning of the Auto-Rx cleaning and a new one after the flush. Then pull the pan, renew the internal filter, refill the sump, do a complete flush. Any good brand of Dexron-III ATF will work fine. Just one bottle of Lubegard is used in a transmission that size, and probably isn't needed.
Ken
#284111 - 02/08/05 01:27 AM Re: LubeGuard Red in 4L60E?
iceberg Offline
Loc: Michigan
The first service on my 4l60e 99 blazer was at 130,000. The guy I bought it from never touched it. I was sceptical about dropping the pan but I did and changed the fluid and filter. I could not believe it all I had to do was wipe the pan a little bit and clean the magnet I was shocked. I also added a bottle of lube guard red. This was 12,000 miles ago. Then again some will say if it ain't broke don't fix it. It made it this far. It's your call...
#284112 - 02/09/05 01:39 AM Re: LubeGuard Red in 4L60E?
JohnBrowning Offline
Loc: USA
LubeGuard would be better to add after it has been serviced. If you wan tot cleanit out prior tp serviceing 6 onces of Auto-RX will do the best job!
