MicroGreen filter at 8,114 miles
by Rex
05/30/16 02:33 PM
Opinions on this 2006 Lincoln
by Milkman
05/30/16 01:40 PM
I'm sure these have been posted before but...
by Yup
05/30/16 01:24 PM
Weedeater nylon string cartridge doesn't feed out
by 69GTX
05/30/16 01:23 PM
Larger Oil Filter for 2006 Highlander 2.4 Four Cyl
by Samzone
05/30/16 01:01 PM
I bought a Stihl weed trimmer, but...
by skyactiv
05/30/16 01:01 PM
2010 Tacoma oil selection help
by bchannell
05/30/16 12:52 PM
Will this "Universal" coolant work on my Car?
by Miller88
05/30/16 11:37 AM
Repelling heat
by mjoekingz28
05/30/16 11:27 AM
Wrong Dipstick? Honda Accord 2.4 Reading Low
by ThirdeYe
05/30/16 09:09 AM
radiator hose install, 08 Matrix.
by JustinH
05/30/16 08:56 AM
Bendix CT-3 Brake Pads
by RevelationLion
05/30/16 08:38 AM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
64 registered (aquariuscsm, 60ampfuse, alan003, bbhero, 69GTX, Bebop367, 9 invisible), 1878 Guests and 331 Spiders online.
58023 Members
66 Forums
249600 Topics
Page 1 of 2 1 2 >
#283448 - 01/15/05 04:04 PM Tufoil Additive
parky Offline
Loc: western new york
Is this additive when added to oil a good product, I have used it in the past but wonder if it has a positive benefit? I looked on site and couldn't see any info on product. TUFOIL /Thanks
#283449 - 01/15/05 04:40 PM Re: Tufoil Additive
Spector Offline
Loc: Chattanooga, TN
Snake oil IMO
First of all it is teflon based I believe. Second, although I cannot prove it, I swear it ruined the main bearings of my 85 Volvo at only 88,000 miles. It did increase the mpg about 2-3 though.
IMO use at own risk!!!!!!!!!!!!!!!
#283450 - 01/15/05 05:41 PM Re: Tufoil Additive
RF Overlord Offline
Loc: Cape Cod, MA
Tufoil, Slick 50, Motor Up, zMAX, Prolong, QMI, DURALUBE, etc, etc, etc...
They all have one thing in common: they drain your wallet. Some of them can actually do more harm than good (the ones with Teflon...like Slick 50 and Tufoil), and the FTC has sucessfully sued most of these companies to stop their false advertising.
#283451 - 01/16/05 08:15 AM Re: Tufoil Additive
peterr Offline
Loc: Toronto, Canada
From http://www.tufstuff.com/tufoil/compare.html
"Tufoil is a super-suspension of micro-miniature PTFE particles and soluble Molybdenum, permanently suspended in oil. All moving parts become coated with PTFE particles which reduce friction and wear."
The above description would send me running in the other direction. If the Moly really is in solution that might be helpful, but particulate Moly and certainly Teflon (TM) or PTFE is generally agreed to not be a useful engine additive.
The MSDS at http://www.tufoil.com/tufoilms.htm indicates a revision date of June 2004 and still lists PTFE at 1%-5% and and Moly at 5%-10%.
I was a little surprised to see the PTFE, since I thought most of those products (Slick50, Duralube etc) had been forced to remove PTFE from their products by the FTC, and were just selling more harmless products on legacy marketing inertia.
The tufoil claims seem less hysteric than the traditional DuraSlickLube50 noise. Is it snake oil? Maybe. Would I put it in my engine? No way. Giving them the benefit of the doubt I could imagine that it might potentially have some use in industrial lubrication, but would it be a good idea inside an internal combustion engine? I expect it would be a terrible idea.
quote:
#283452 - 01/15/05 10:11 PM Re: Tufoil Additive
Ian Offline
Loc: Singapore
"Popular Mechanics calls Tufoil "absolutely spectacular" after their test showed a 10.3% fuel savings. "
Does this mean that Popular Mechanics cannot be trusted?
#283453 - 01/15/05 10:24 PM Re: Tufoil Additive
XS650 Offline
Loc: Northern CA
It's not wise to put much trust in any one of the popular techno magazines. I think the problem is more a combination of incompetence and unwarranted enthusiasm on their part than it is evilness. That, and the need to have articles that sell magazines sometimes clouds their judgement.
Look for multiple normally reliable sources before you consider any magic elixor article as being valid.
#283454 - 01/15/05 11:20 PM Re: Tufoil Additive
Gary Allan Offline
Loc: Pottstown, PA
Well ..I'll through my $.02 in here.. [Smile]
Teflon is a very hard product. It isn't liquid until above 500°F. It would trump any softer metal if it was contacted by it in a pressurized environment. The stuff tears up many harder alloys when you make stuff out of it (hammerlite) over time. It would make short work of lead (tin, copper, aluminum)
The only situation that I can think of where it may do something (I didn't say beneficial) is where the oil itself is subjected to higher temps. Like maybe that which makes it into the upper ring area. In this higher temp state it may actually be fluid enough to be applied to something for a little while. [I dont know]
I would imagine that if it would work that well, the manufacturers would come out with teflon coated bearings ..or maybe ceramic coated crank journals to use with them. They don't ..and looking at some of the lame stretches they pull trying to achieve fuel economy, you'ld think that they've already tried it and rejected it.
If you want to dose your engine with something that will do something, try the SynPowerŽ oil treatment. You may be over dosing it with moly ..but at least the material itself has some worthwhile properties. @ $6.99 a bottle, it's a bargain compared to most snake oils.
#283455 - 01/15/05 11:58 PM Re: Tufoil Additive
Bror Jace Offline
Loc: Saratoga, NY
parky, this has come up before. please do a search of this forum using the word "tufoil."
I wouldn't buy this stuff ... nor would I buy any PTFE based product.
--- Bror Jace
#283456 - 01/16/05 04:14 PM Re: Tufoil Additive
Spector Offline
Popular Mechanics or the marketing dept of Tufoil stated a 10% increase in MPG. I myself saw a 2-3 mpg increase, however, long term engine wear and protection seem to be ignored in the marketing. As I stated earlier, I believe it was the cause of premature bearing failure on the one engine I did use it on 12 years ago.
Popular mechanics rarely tests products, they usually just report what the marketing dept of the advertising entity wants them to print
#283457 - 01/18/05 03:00 PM Re: Tufoil Additive
parky Offline
I appreciate your replies, I had ordered a quart of Tufoil to use in my new car after breakin mileage was achieved. Am returning it to seller for refund. Is there any additive that actually helps in increasing mileage and engine life? I have a 4 cylinder engine and want to help it last longer. Thanks!
#283458 - 01/18/05 05:39 PM Re: Tufoil Additive
Spector Offline
IMO a synthetic oil will provide you 200000 miles+ As to additives, well, I use the Lube Control which is discussed on this board and it has given me better results on the used oil analysis but most additives (especialluy over the conter ones at parts stores) are snake oil so you are better off using a quality oil and filter, air and oil, and not worry about using additives. The Lube Control, Auto RX and Schaefers 132 appear to be good products and I have used all three.
#283459 - 01/18/05 05:58 PM Re: Tufoil Additive
Terry Offline
Loc: Greenville , Texas
" The Lube Control, Auto RX and Schaefers 132 appear to be good products and I have used all three "
For Spector to post the above you had better listen ! There is no more critically discerning automotive consumer !
[bowdown]
#283460 - 01/18/05 06:20 PM Re: Tufoil Additive
ekpolk Offline
The Regenerator
Loc: Pensacola FL
This horse has been pretty well beaten, but I think I can add a couple cents worth of value. The real trick is to ferret out from morass of garbage out there the few products that actually provide something in exchange for the money you give up to get them. So how do you decide? Certainly not by reading Slick-50-sytle ad hype or by watching some of those silly infomercials. Study our UOA section and search the names of some of these products and you'll able to make an informed judgment. BTW, I too have seen measurable, objective improvement in my UOAs with the use of Lube Conttrol. If you want, search the UOA section by my member number (3733) and compare my first Sequoia UOA with the last. It's just a two sample comparison, but despite pretty similar operating conditions and duration, insolubles dropped from 0.5 to 0.3. If you dig, you'll see other similar results.
#283461 - 01/19/05 10:31 AM Re: Tufoil Additive
Mystic Offline
Loc: Colorado
I once used Tufoil and I used to really believe in it. In comparison I never used Slick50. Tufoil in the past seemed to have very good documentation. And I did see that article in PM.
I don't use Tufoil anymore. I really do not believe in at least 90% of these so-called engine treatments, oil supplements, engine cleaners, etc. The one product I definitely DO believe in is Auto-RX. It seemed to work for me.
Beyond that I think we can rely on what terry says-after all he does oil analysis.
#283462 - 01/19/05 10:39 PM Re: Tufoil Additive
gumby_66 Offline
Loc: Edmonton, Alberta
I have to agree with Spector!
Also we need to know is what kind of new car and engine, the climate and how hard you will be driving it.
I use LC, Auto-RX and Fuel Power with synthetic oil and like the results.
But my vehicles are all 5+ years old and have no warranty! I run extended OCI's with Synthetic oil with the above mentioned products.
IMHO using Lube Control and Fuel Power and using good quality dino and filter following the manufacturers OCI would be the way to go.
You could drop the LC and use Auto-RX every 50K, easier to track and less hassle(adding 1oz of LC every 1000 miles) but more money.
Steve
Page 1 of 2 1 2 >
