Why do people put trash in other peoples truck bed
by motor_oil_madman
07/26/16 09:07 AM
P/S calls for Dexron II or III, Maxlife OK?
by K20FA5
07/26/16 09:04 AM
2008 Honda Civic slow to start
by InhalingBullets
07/26/16 08:45 AM
Top Search Today..........
by AirgunSavant
07/26/16 08:15 AM
Oil choice for Hyundai Veloster
by Kyonic
07/26/16 08:01 AM
Paul Simon
by Donald
07/26/16 07:57 AM
2000 Nissan Sentra cranks but will not turn over
by Rtstrider
07/26/16 07:57 AM
For Sale 12- AC Delco PF 48 oil filters
by dson
07/26/16 07:39 AM
Semis: what has changed?
by grampi
07/26/16 07:17 AM
2016 Volkswagen Tiguan Oil filter - Weird Design?
by FordBroncoVWJeta
07/26/16 02:21 AM
New old ride
by SEBZX79
07/25/16 11:25 PM
Motor Trend Visit with Valvoline
by tenderloin
07/25/16 10:46 PM
rfabrocini, Tobin28, r0k, KNA, Roanoke6370
58598 Registered Users
88 registered (adamrc, AirgunSavant, 182RG, 09_GXP, 69GTX, 4WD, 8 invisible), 1519 Guests and 18 Spiders online.
58598 Members
66 Forums
252257 Topics
#283170 - 01/05/05 04:08 AM Is Power Steering fluid basically same as ATF?
kevz Offline
Loc: oakland, CA
I read somewhere that it would be cheaper to use ATF than PS fluid. I was thinking of using M1 ATF in my power steering.
#283171 - 01/05/05 04:15 AM Re: Is Power Steering fluid basically same as ATF?
Ignatz Offline
Loc: Birdsboro Pa.
What kind of car?
#283172 - 01/05/05 05:09 AM Re: Is Power Steering fluid basically same as ATF?
kevz Offline
Loc: oakland, CA
94 saturn
#283173 - 01/05/05 05:11 AM Re: Is Power Steering fluid basically same as ATF?
JHZR2 Offline
Loc: New Jersey
Some cars spec PS fluid for their steering units. Other cars spec ATF. Some older cars carry the suggestion (based upon my readings in different forums) that although it was originally specced for ATF, that PS fluid be used because ATF can effect the seals.
I believe PS fluid is slightly more viscous, and ATF has a detergent package, while the PSF only has dispersants to ensure that aggregates dont form.
JMH
#283174 - 01/08/05 07:19 AM Re: Is Power Steering fluid basically same as ATF?
wiswind Offline
Loc: Wisconsin
Read up on what your particular car / year require. There are a lot of different requirements out there, and they can change from year to year. You want to use the correct fluid for your car.
So as you have already been advised, depends on the car, and the year.
#283175 - 01/08/05 07:38 AM Re: Is Power Steering fluid basically same as ATF?
Spector Offline
Loc: Chattanooga, TN
you need to look at the manual Most of mine are ATF and I have one 1996 with a Type F ATF for the PS.
#283176 - 01/09/05 10:26 AM Re: Is Power Steering fluid basically same as ATF?
Fuelrod Offline
Loc: Summer, Cape Cod. Winter, Mexi...
To answer your question, YES, P.S. fluid is basicly ATF. In a pinch, use it! it's sure better than nothing! It's probably BETTER than a lot of stuff labeled P.S. Fluid.
The only problem centers around the fact that ATF contains seal conditioners and detergents that MIGHT soften SOME power steering hoses. With most quality hydraulic hoses, this is NOT a problem.
#283177 - 01/11/05 03:35 AM Re: Is Power Steering fluid basically same as ATF?
GT Mike Offline
Loc: Oshkosh, WI
My dad's 2000 Dakota came factory filled with power steering fluid. That winter he had some issues with stiff steering in extreme cold, and I found a TSB that was issued regarding this, and they recommended a complete P/S flush and refill with Mopar ATF+4. I did this, and it's worked perfectly ever since.
#283178 - 01/11/05 04:56 PM Re: Is Power Steering fluid basically same as ATF?
kevm14 Offline
Loc: North Kingstown, RI
#283179 - 01/11/05 05:43 PM Re: Is Power Steering fluid basically same as ATF?
paulo57509 Offline
Loc: Tracy, CA
FWIW, GM specified ATF Type-A for my old '63 Bonneville.
#283180 - 01/17/05 08:21 AM Re: Is Power Steering fluid basically same as ATF?
Max_Tl Offline
Loc: Alberta
newb here! great forum guys.
anyhow '03 Nissan Maxima VQ3.5 60K Kilometers- want to exchange ps fluid with Amsoil ATF - any problems here? (no i don't have the manual - second owner)
#283181 - 01/17/05 12:21 AM Re: Is Power Steering fluid basically same as ATF?
kevz Offline
Loc: oakland, CA
I think it's best to stick with PS fluid... The extra additives in ATF could be bad for PS seals. Not worth risking... I wanted to replace my PS fluid with M1 ATF but, it just doesn't seem to be a great idea anymore.
I saw some Valvoline SynPower PS fluid at Pepboys...anyone ever try that?
#283182 - 01/17/05 01:00 AM Re: Is Power Steering fluid basically same as ATF?
JohnnyO Offline
Loc: Pittsburgh, PA
quote:
I changed it in my wife's old car and my van with Synpower, they didn't seem any different. Fresh stuff is good anyway.
