I installed this STP filter on an 01 Civic after I buttoned up the valve cover as shown in this thread. This STP is the equivalent app to the Puro L14459 used on majority pre 01 Hondas. Seeing as the STP OF has no 14610/7317 equivalent, the spec application, I chose it over the smaller thimble size STP spec S6607, the Puro 14612 equivalent. Based on the amount of media found this 2808, it seems a wise choice. Normally wouldn't select the STP filter but it was part of AZ Mobil Super5k/filter promo for ~$10, and I wasn't going to waste it.
The 8k oci is farther than the normal 5-6k dino oci this vehicle has seen on average, but the last 2-3k was used for a recently lenghtened commute, mostly highway driving that occured over a very short time frame.
Also used ZO6's method of wrapping media in a disposable shop towel to absorb excess oil before taking pics.
The obtained specs for the S2808 are:
46 pleats not including joining/seam pleat.
7/16" pleat depth
1&7/8" media width from endcap to endcap
And a media area of ~75.5 sq. in.
Observations:
As mentioned in title a dome end end bypass that consists of the flat protuding area of the 4 spoke retainer leaf spring covering six round holes in the dome end. Seen integrated bypass in the retainer spring like Fram, but never seen the retainer spring itself serve as part of the bypass design. Will be interested in thoughts/comments on this design.
This filter uses a rounded gasket as opposed to flat or P type gasket. And, as seems typical for Champ made the base/tapping plate is quite thick and heavy. Much moreso than other filters I have dissected in the past. Can thickness seemed about average.
7/16" pleat depth
Observations:
