Originally Posted By: Clevy
Originally Posted By: skyship
Has anyone tried Liqui Moly fuel system cleaner?:
www.liqui-moly.us/liquimoly/mediendb.nsf/gfx2/2005_Diesel%20Purge.pdf/$file/2005_Diesel%20Purge.pdf
(Cut and paste only)
This type of cleaner is fed directly into the fuel line or fuel filter housing (I think) and I would be most interested in any comments about this product.
I am very anti oil additives of any kind, except where there is a well researched, very specific problem that can't be resolved by other means, some fuel additives do help, but not the cetane boosters that are real snake oil products.
One final anti additives rant: NEVER PUT SOLVENT FLUSH OIL ADDITIVES of
the type that you drive around with (A 10 min flush at idle only just before an oil change is far less risky) in your oil.
I too am a fan of liqui-moly products. They seem to be of the highest quality and they do what they are advertised to do.
Skyship,you mention liqui-moly products so often that I would almost think you are a paid poster. At one point I thought tig was an exxon paid poster because of how he "suggests" mobil 1 for everything. Now I just think he is serious fanboy.
So are you a liqui-moly employee the skyship?
WISH I WAS!, I just use their engine oils as Castrol are far too expensive in Germany. They are a great company and good at answering tech questions, BUT THEY DO MAKE SOME SNAKE OIL PRODUCTS just to make money. Unlike other companies those products are fully tested and won't cause any harm, even if they don't work.
Some professional engineers I know do use LM idle only flush before an oil change. In a real emergency only, they will use a can of stop leak in an engine or radiator, AS for the rest of the engine oil additive range, DON'T USE THEM, just find a better quality or specialist oil etc.
If I was in the USA or UK, I would use Castrol oil and in an emergency Amsoil idle flush or stop leak. Second choice would be Mobil, then Shell. Not keen on many US oil companies due to very dubious advertising methods. They keep fooling people with filter efficiency ratings, synthetic groupings and terms designed to hide HC or part synthetics under the fully synthetic label. The Germans can't lie on their web sites due to local and EU laws.
