Child bicycle trailer?
by Quattro Pete
51 minutes 21 seconds ago
First Generation Tundra?
by Miller88
Today at 09:02 AM
dollar store oil
by bradepb
Today at 08:53 AM
2004-2006 Caravan Fac'try Serv. Man. DVD for Sale
by doitmyself
Today at 08:42 AM
Static electricity in my car - How do I stop it?
by qdeezie
Today at 07:28 AM
11 GMC Sierra 6.2L oil and filter
by wolfehunter
Today at 07:27 AM
Purolator L14476 with OPE
by SwampDweller
Today at 06:09 AM
WRX or GTI?
by GumbyJarvis
Today at 02:50 AM
Single cylinder versus twin
by mjoekingz28
Today at 01:12 AM
Mobil Super Syn vs ...others
by Yup
Today at 12:45 AM
2016 WRX
by Silver02ex
Yesterday at 11:58 PM
Class Action Lawsuit Against Oil Filter Company?
by crazyoildude
Yesterday at 11:42 PM
engus, Rob_Pol, Nick24w, SkipKaye, MikeHancho
56899 Registered Users
114 registered (aircooled, Al, 04SE, Andrei, 74Scout, AlaskaMike, 13 invisible), 1637 Guests and 192 Spiders online.
56899 Members
66 Forums
244589 Topics
#2806984 - 11/18/12 11:14 PM Grease for tie rod ends, ball joints,shifter pivot
92dx Offline
Loc: ks
Im looking for the best grease I can fill some new ball joints and tie rod ends? I was looking into schaeffers #238 or #274. I assume good moly content would be a great thing to use here. I used Amsoil and wasnt much impressed. It bleeds alot. what do you guys use/suggest?
Also looking for a great grease for a shift lever pivot. White lithium like lubriplate? I have some of that. Something better I could use?
I still have a way to go to learn what Im really looking for in a grease/oil in different applications. I have this complex where I have to research to the internets end for the best possible solution to what Im looking for. Makes things take..a while.
#2807013 - 11/19/12 01:57 AM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: 92dx]
Chris B. Offline
Loc: Colorado
The schaeffers is the best!
#2807045 - 11/19/12 04:53 AM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: 92dx]
NHGUY Offline
Loc: USA
Mopar Multi Mileage lube has been around since the 60s.Its long fiber and known to be long lasting.
#2807108 - 11/19/12 07:17 AM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: 92dx]
Trav Offline
Loc: MA, Mittelfranken.de
schaeffers #238 thumbsup
#2807135 - 11/19/12 07:59 AM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: 92dx]
bigmike Offline
Loc: Florida
Schaeffers is probably the best product you'll find.
Problem is availability, which is why I always use Valvoline Synthetic w/ moly instead.
Take care,
-Mike
2006 Chevy Silverado LT 4.8 - QS 5w30, Napa Gold
2009 Honda Accord LX-P 2.4 - QS UD 0w20, P1 14610
#2808550 - 11/20/12 01:01 PM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: 92dx]
Rob_Roy Offline
Loc: Northern, NY
A grease with moly would be a good choice for the front suspension components. A calcium or aluminum complex thickener will resist water much better than lithium complex. As you have discovered, some of the finest greases are not easy to find in small quantities. The Schaeffer's grease you mentioned would be a good choice if you can get a small quantity for a reasonable cost. Texas Refinery's 880 Crown & Chassis is another good performer, and they also offer it with moly...but the 50 tube case size probably isn't what you are looking for.
Do you have a Caterpillar dealership nearby? Their Desert Gold Grease is very good. If you only need a tube or two, the dealership markup probably won't be a deal breaker.
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10 workhorse
#2815482 - 11/27/12 12:41 AM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: 92dx]
92dx Offline
Loc: ks
So I can get the desert gold locally. I like the #238 because it has graphite and teflon as well. Then, the desert gold has more pao and the tds looks better, but man it is thick.
What should I use for the shift lever ball? Its a metal ball in a hard plastic housing. Silicone, teflon, white lithium?
#2815793 - 11/27/12 10:45 AM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: 92dx]
Tempest Offline
Loc: Las Vegas NV
For a manual transmission? The ball on mine is lubricated by the trans oil.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#2815955 - 11/27/12 01:16 PM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: Tempest]
92dx Offline
Loc: ks
yes a manual trans, but in a fwd application.
#2815975 - 11/27/12 01:29 PM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: 92dx]
Tempest Offline
Loc: Las Vegas NV
I would use silicone grease on a plastic condition.
#2819844 - 11/30/12 10:31 PM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: 92dx]
92dx Offline
Loc: ks
Well I got a tube of both 238 and cat desert gold. I wanted to check them out, as they seem very popular for my application.
I think I got an old tube of 238. I bought it online and got the cat local.
Ive never seen a Scheaffers grease before, but this has a consistency like bubble gum. It looks like it was stored with the the cap side down and the cardboard tube is a bit saturated. There was a small amount of oil in the cap when I removed it. Smells horrid lol..
The cat desert gold on the other hand.. smooth as butter. The TDS show this to be a much thicker grease but the 238 seems thicker... At least this tube.
So does this sound right?
#2883363 - 01/25/13 07:27 AM Re: Grease for tie rod ends, ball joints,shifter pivot [Re: 92dx]
97K15004WD Offline
Loc: USA
Any update on the CAT desert gold versus the Scheaffers?
