Does Anyone Remember...
by pscholte
08/30/16 10:21 PM
Oil filter for fuel filter?
by leroyd92
08/30/16 10:19 PM
YouTube search geniuses help me out!
by Vern_in_IL
08/30/16 10:00 PM
BMW i8 Could Have 750 HP All-Electric After 2020
by HTSS_TR
08/30/16 09:48 PM
1991 Audi 200 Turbo Automatic Oil Standard?
by Logos
08/30/16 09:43 PM
Chevron & Sunoco & Speedway $100 Gift card $92
by gojoneeded
08/30/16 08:41 PM
Santa's Not Going To Be Happy
by Warstud
08/30/16 08:29 PM
can someone explain the Ecoboost to me?
by columnshift
08/30/16 07:50 PM
4 dragging weak brakes (after parked for a year)
by columnshift
08/30/16 07:34 PM
New S&W Shield 9
by funflyer
08/30/16 06:42 PM
ecoboost 3.5
by boostnation
08/30/16 06:30 PM
Meijer, Mobil and the joys of Labor Day stackation
by fdcg27
08/30/16 06:25 PM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
18 registered (AnthemBassMan, Atesz792, fonecord2, c502cid, 5 invisible), 639 Guests and 8 Spiders online.
58964 Members
66 Forums
253791 Topics
#2803608 - 11/15/12 01:03 PM Best practice for preserving powder coat finish
Ddub Offline
Loc: TX
I am going to put a bull bar and some auxiliary lighting on my new Ford Explorer. Not only does the black powder coated one look better than the polished stainless steel one for my color Explorer, it is also less expensive too. Here's the deal though. The SS one would be relatively easy to maintain and has a lifetime warranty. I think the black one has a 3 or 4 year warranty and I have seen powder coating eventually flake off things like lawn furniture, etc. Does anyone recommend an especially good care technique and/or product for making the finish last as long as possible? Thanks in advance for your advice.
2010 Mazda 6i Touring (PP or Castrol Magnatec Syn)
2013 Ford Explorer V6 (company car) (Kendall Syn Blend)
2009 Caddy DTS (It's complicated)
#2803615 - 11/15/12 01:09 PM Re: Best practice for preserving powder coat finish [Re: Ddub]
dparm Offline
Loc: Chicago, IL
Powdercoating is just as strong as paint, if not moreso. Shoddy powdercoating jobs will indeed chip and flake.
I would just care for it as you do any other painted surface.
2011 BMW M3 sedan ZCP
#2803654 - 11/15/12 01:44 PM Re: Best practice for preserving powder coat finish [Re: Ddub]
kkreit01 Offline
Loc: Olathe, KS
Use the same sealant you use on your paint. Top off with spray wax often. Pay close attention to mounting brackets/bolts. That's typically where the start chipping. I once had Westin nrf bars that started chipping after the first winter. The stainless bars aren't worth it unless you prefer the look. The brackets/mount hardware are the same (non-stainless) as used on black items.
2014 Dodge Durango Limited AWD 3.6: 5w20 PU/Napa Gold filter
2015 Lincoln MKC Fwd 2.0EB: 5w30 PP/Motorcraft filter
#2803719 - 11/15/12 02:54 PM Re: Best practice for preserving powder coat finish [Re: Ddub]
Gotch Offline
Loc: Ontario Canada
Depends on the cure and the paint used. It will indeed chip, moreso if the paint was overcured by the OEM. Keep it clean, sealed and touch up any chips as soon as you notice them and it will last a long time. I've seen outdoor furniture go 25+years without chipping. Depending on the type of powder (nylon is the most chip resistant) there are varing degrees of chip resistance. If the pull bar is from a quality manufacturer, then the coating should stand up well.
In a past life, I worked for a large, non-captive, custom coater. When we did front bumpers, we laid down a coat of powder anti-chip primer over e-coat and the an acrylic powder top coat. Tested adhesion using a shot blast and we never had a fail to substrate. Very expensive process but lasts a long time.
