Hanging 3rd - Honda Automatic
by RevelationLion
07/30/16 01:31 PM
Oil Interval Mountain Driving Road Trip
by Yup
07/30/16 12:58 PM
Giant VW Beetle....
by mattwithcats
07/30/16 12:43 PM
anyone have the 12 ton HF press?
by joel95ex
07/30/16 12:27 PM
BMW final drive 75W90 GL5. Supertech semisyn OK?
by David_g
07/30/16 12:00 PM
Shuffle your feet!
by Stelth
07/30/16 11:44 AM
BMW Hexhead gearbox oil? Redline shockproof?
by David_g
07/30/16 11:11 AM
Meg's Ultimate vs Collinite 845/476s?
by MisterBen
07/30/16 10:17 AM
Why do factory filters get such a bad rep?
by MisterBen
07/30/16 10:09 AM
Strange oil filter experiance. I'm stumped.
by callbay
07/30/16 10:06 AM
WiFi Extenders
by GGorman04
07/30/16 09:54 AM
Need Help getting on track/ 07 Honda Pilot
by 07Piloteer
07/30/16 09:23 AM
RM53119, Ctanke, jractk, LatitudeDancer, AKN
58647 Registered Users
66 registered (4WD, Bandito440, bdcardinal, andrewp1998, Blang, Astro_Guy, 5 invisible), 2133 Guests and 7 Spiders online.
58647 Members
66 Forums
252449 Topics
#2795610 - 11/07/12 01:17 PM 2004 mach 1
wjli Offline
Loc: georgia
any recommendation of an additive for this vehicle? it has 120,000 miles and has developed a "hot idle" ticking/tapping noise. it is quiet when cold and it is quiet once hot and reved above idle, but the noise returns a few seconds after its back to idle.
i have went from 5w20 - 10w30 and am using motorcraft filters.
the Lucas oil rep recommended 5w20 and a quart of the LOS.
#2795621 - 11/07/12 01:30 PM Re: 2004 mach 1 [Re: wjli]
ARCOgraphite Offline
Loc: N.H, U.S.A.
No additives! I noticed the EDGE with TI 0w20 is a quiet oil, but a bit thick for my honda. Note that water pumps, belt tensioners and chain tensioners can tick.
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#2795649 - 11/07/12 01:52 PM Re: 2004 mach 1 [Re: wjli]
bdcardinal Online   content
Loc: Santa Barbara, CA
Is the ticking coming form the back of the drivers side head? If so there is no additive that will fix that, you have work valve guides from getting too hot. Only real fix is a new head, ford has updated that number for the head a bunch of times. You can install the cooling mod that knocks out the rear core plug on the head and taps a heater line.
Look up "the tick" on SVTPerformance. It usually applies to 03-04 Terminator Cobras, but the Mach 1s, Aviators, and Marauders use the same part number cylinder heads.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#2795677 - 11/07/12 02:31 PM Re: 2004 mach 1 [Re: bdcardinal]
wjli Offline
Loc: georgia
I read up about the tick. This is the passenger side which still may not negate a possible bad valve guide. wonder how long a car can go like that ? there is definately no cash for a repair at the moment. what is the causing the sound? the valve stem tapping the side of the guide ?
#2795750 - 11/07/12 04:17 PM Re: 2004 mach 1 [Re: wjli]
Trav Offline
Loc: MA, Mittelfranken.de
Put some Kreen in it. If its something sticking this stuff will free it up in short order. If the noise remains then you know you have a mechanical issue.
I would definitely try this before i started tearing into it.
16oz in with the 10w30 you have in there will be good and run it for 1K.
#2795770 - 11/07/12 04:41 PM Re: 2004 mach 1 [Re: wjli]
SteveSRT8 Offline
Loc: Sunny Florida
^^^Good advice. Who's to say this isn't carbon knock? What about a spec of crud in a follower? Even a valve guide can get sludged up.
Kreen will eliminate the chance that this is just crud, and it may also help the engine in many other ways as well.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2796601 - 11/08/12 12:17 PM Re: 2004 mach 1 [Re: wjli]
MaxZX Offline
Loc: VA
This may sound silly, but check your spark plugs. The 4.6 modulars are known for them coming loose (only 4 or 5 threads hold them in) if they aren't torqued properly and the motor will blow them out, stripping the threads in the process. Tons of info on this online. Loose plugs in that engine tick, sometimes a lot, sometimes a little, sometimes they seat themselves briefly and the ticking stops for a while, but it's a warning sign to check.
I learned this the hard way. I have an 03 GT, and was experiencing a ticking for a while at various speeds and at idle. Couldn't seem to find where it was coming from at first when it was quieter. One morning driving to work the #7 plug blew out. Bottom line, loose plugs will make a ticking sound, looser = louder usually. Make sure they are all torqued to factory spec (I think 14 lb/ft).
#2798333 - 11/10/12 08:00 AM Re: 2004 mach 1 [Re: Trav]
Boss302fan Offline
Loc: Oconomowoc Wi
Bingo... I had a 2003 Mach 1 and it ran very smooth with Mobil 1. I did use Redline SL-1 fuel cleaner in it every 1K miles.
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
