Installing a dish washer.
by ram_man
02/09/16 10:37 PM
Strangest Three Wheel Car Ever
by Fsharp
02/09/16 09:57 PM
Remove Gasoilne and other Blowby Gasses
by landtoy80
02/09/16 09:48 PM
Trans Am said goodbye to his battery today.
by ls1mike
02/09/16 09:39 PM
Lil Big Rig - I want one
by montero1
02/09/16 09:01 PM
[Cut Open] Champ PH2808 - Torn Pleat
by Bud_One
02/09/16 08:41 PM
2015 silverado dealer oil change
by Realtech214
02/09/16 08:27 PM
delo 400 $17/gallon at walmart now?
by motor_oil_madman
02/09/16 08:23 PM
Looks like Classics are going bye,bye at WM
by chainblu
02/09/16 08:18 PM
acdelco ph64
by gabriel9766
02/09/16 08:11 PM
Using USED oil as a top off?
by Vern_in_IL
02/09/16 07:57 PM
Question-Buying from a rental agency
by powayroger
02/09/16 07:31 PM
TrogDorInjection, wytenow, maxud, OrchardAuto, Moredoor
56874 Registered Users
83 registered (BigD1, 2015_PSD, BigCahuna, bdcardinal, Basshead, 7 invisible), 1095 Guests and 201 Spiders online.
56874 Members
66 Forums
244475 Topics
#2767398 - 10/09/12 09:26 AM Symptoms of a bad gas cap?
wolf_06 Offline
Loc: Atlantic, Canada
Any of you experience a bad gas cap? If this can affect engine performance, fuel trim or fuel pressure? fuel economy?
Thanks!
2011 Chevy Cruze 1.8L 6AT
Castrol Edge Syntec w/ Titanium 5w30 - OEM filter
#2767401 - 10/09/12 09:30 AM Re: Symptoms of a bad gas cap? [Re: wolf_06]
Quest Offline
Loc: beaver land EH?
on OBD-II cars: a bad (not sealing properly) gas cap will throw you a code.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#2767404 - 10/09/12 09:32 AM Re: Symptoms of a bad gas cap? [Re: Quest]
Charlie1935 Offline
Loc: DuQuoin, Illinois
It will give a code for evaporation system leak usually.
Charlie
#2767417 - 10/09/12 09:53 AM Re: Symptoms of a bad gas cap? [Re: wolf_06]
440Magnum Offline
Loc: Texas
Electric fuel pumps for EFI generate pressures on the order of 50 psi, the gas cap holds a pressure of 2-3 pounds. So at most its going to make a few percent difference in fuel pressure, and most likely not even that since the fuel pressure is usually regulated. So I'd say you'd never see a difference in performance at all, just the code for an evaporative emissions fault.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#2767479 - 10/09/12 11:19 AM Re: Symptoms of a bad gas cap? [Re: wolf_06]
WishIhadatruck Offline
Loc: Grand Rapids, MI
The only thing I've ever noticed is that my check engine light comes on. I've never noticed a change in how the vehicle performs.
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
#2767495 - 10/09/12 11:39 AM Re: Symptoms of a bad gas cap? [Re: wolf_06]
Donald Offline
Loc: Upstate NY
I drove for a few miles with the gas cap held neatly in the gas flap. No code or anything.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#2767501 - 10/09/12 11:43 AM Re: Symptoms of a bad gas cap? [Re: Donald]
Trav Offline
Loc: MA, Mittelfranken.de
It wont until the system runs an EVAP test.
