Hard starting LCT snow engine..
by JTK
02/12/16 02:34 PM
low-temperature oil gelling reversible?
by DrRoughneck
02/12/16 12:51 PM
I HAD to do it!
by Kuato
02/12/16 12:24 PM
Why Erin Esurance vanished from TV
by Benzadmiral
02/12/16 11:39 AM
Engine Light Advice
by coopns
02/12/16 11:14 AM
Caution UOA - PP 10W30 6881m on 2001 Jeep 4.0
by Donald
02/12/16 11:09 AM
What happened to the thin oil movement?
by camrydriver111
02/12/16 10:57 AM
Mastercraft Strategy tires (I'm cheap)
by Bgallagher
02/12/16 10:41 AM
Mobil Delvac ATF in a regular car transmission
by SuperValue
02/12/16 10:35 AM
Dumped the smartphone!
by andrewg
02/12/16 10:27 AM
Need to replace plugs - cooper,Iridium, or Plat?
by MoreCowbellAz
02/12/16 10:25 AM
Child bicycle trailer?
by Quattro Pete
02/12/16 09:19 AM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
102 registered (Alvaro, 05LGTLtd, 19kj57, akela, 87sammy, Al, 10 invisible), 1802 Guests and 194 Spiders online.
56901 Members
66 Forums
244603 Topics
Page 1 of 2 1 2 >
#2762106 - 10/03/12 05:06 PM GM 4L60E Fluid and Filter change (with Pictures)
SnPb Offline
Loc: Arizona
I had some time off from work today, so I decided to change the transmission fluid and filter in my 2003 Trailblazer that currently has about 130K miles on it. It is a 4L60E transmission and began experiencing a hard 1-2 shift at about 114K miles. The fluid was previously changed by the dealer at about 30K and 70K miles but this is the first time that the pan has ever been off for a filter change. I added Lubeguard Red at about 119K miles and it has helped, but not cured, the shift issue. It is intermittent now, sometimes it shifts the way that it used to before the issue developed but most of the time it shifts firmly; although not as hard as it did before the addition of Lubguard Red.
I dropped the pan and was surprised at how clean it was. What I could see of the filter material also didn't look bad. The fluid still had some red color to it and didn't smell burnt, but was considerably darker than new fluid. I removed the 1-2 accumulator for inspection to see if it wasn't the cause of the overly firm 1-2 shift. It appeared fine to my eye. There were no cracks in the piston or springs and the piston seal was in good shape. I wasn't brave enough to remove the valve body for inspection.
I installed the new filter, replaced the pan, and filled it with Valvoline Dex VI with a bottle of Lubguard Red. I disconnected a line to the transmission cooler and started the engine to pump out the remaining old fluid in the torque converter.
I haven't had a chance to take it out for a good test drive yet to see if there is any noticeable difference in shift quality.
Cheers,
Jeff
#2762114 - 10/03/12 05:12 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
Donald Online   content
Loc: Upstate NY
Looks spotless to me. Thanks for the pics. As I am sure you are aware color is not a great sign of the condition of ATF. However if it looks like driverway sealer it might be best to replace it.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#2762148 - 10/03/12 05:58 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
Turk Offline
Loc: MN
Great!
I got 183k on mine with 2 Syn flushes. Back up a 3,000Lb. Boat up a hill with it cold a lot & tow a lot. No issues!!
Ya gotta report back with the results.
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#2762170 - 10/03/12 06:34 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
wirelessF Offline
Loc: Oahu, Hawaii
Did you replace the filter seal? It was a PITA to remove though.
#2762199 - 10/03/12 07:03 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
Shannow Offline
Loc: Oz
I don't know anyone who replaces the seal, unless they stuff the seal before they realise that they should have left it.
One thing that amazed me when I did the 4L60E on my Caprice was that the filter and gasket kit was less than $15...amazing in this country.
#2762207 - 10/03/12 07:17 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: Shannow]
SnPb Offline
Loc: Arizona
I did not replace the seal for the filter. The old one still felt compliant and was a tight fit on the new filter, so I left good enough alone. I tried replacing the seal on a GM transmission several years ago and decided that I wasn't going to do that again. I would guess that the mechanics at the dealer must have a special tool to remove it. Either that, or they don't change them either.
#2762215 - 10/03/12 07:32 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
Rat407 Offline
Loc: North Carolina
I replace the seal. No problems at all. It is easy to do. It is a soft material and you just work at it with a small screw driver and bend it in then pull it out with pliers. Easy!
#2762240 - 10/03/12 07:55 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
WishIhadatruck Offline
Loc: Grand Rapids, MI
I haven't replaced a seal in years, too easy to damage the aluminum it is pressed into.
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
#2762282 - 10/03/12 09:05 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: Shannow]
HTSS_TR Offline
Loc: Lake Forest, CA
I paid around $10-12 for my MB E430 gasket and filter kit.
'94 Lexus LS400
'00 MB E430
'04 Honda S2000
'06 Volvo V70
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2762293 - 10/03/12 09:14 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
yonyon Offline
Loc: NJ, USA
I've always just used a ladies foot pry bar for the seal. I think this tool is also known as a "spike thing" or "pokey thing" or any other of many names. A steady light push with the bar pops the seal right out every time.
#2762299 - 10/03/12 09:24 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
Warstud Offline
Loc: MIchigan
No need for the Lubegard!
#2762448 - 10/04/12 05:00 AM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
SteveSRT8 Offline
Loc: Sunny Florida
I sure hope you reused the original rubber gasket. They are nearly permanent and usually better than anything in the kits.
BTW, that is very clean for the miles. Shows that flushes do work. And Lubegard is a fantastic additive that really does work.
Edited by SteveSRT8 (10/04/12 05:01 AM)
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2762547 - 10/04/12 08:01 AM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
JTK Online   content
Loc: Buffalo, NY
Great work Jeff!
I would expect it to be spotless @ 119K, if it had been serviced at 30K and 70K miles though. Those are about perfect service intervals. Way more than your average owner would do.
Back when I owned my 2005 Trailblazer, I did a cooler line drain and refilled through the dipstick tube when it had under 40K miles on it. Made a heck of a mess too. I didn't expect this 4L60E to fill a gallon jug in less than 10sec.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2764279 - 10/05/12 09:46 PM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
Ram01 Offline
Loc: New York Queens
I was told by a GM master Technician. That those tranny's only need 3-4 flushes or drain and fill in there lifetime
#2764492 - 10/06/12 08:05 AM Re: GM 4L60E Fluid and Filter change (with Pictures) [Re: SnPb]
SteveSRT8 Offline
Loc: Sunny Florida
That's true only under a specific set of operating parameters.
Everybody is different, hence differing recommendations.
No single interval is right for everyone.
Page 1 of 2 1 2 >
