Streaks left after using leather seat wipes.
by jigen
05/24/16 07:57 AM
Poulan Pro 5020AV carburetor adjustment
by jstutz
05/24/16 07:57 AM
Winchester firearms - 15% rebate until May 30
by mjk
05/24/16 07:29 AM
Redskins name offensive
by grampi
05/24/16 07:20 AM
Rear Disk Brake Question
by NibbanaBanana
05/24/16 06:58 AM
anybody good in theorycrafting mathematic?
by yvon_la
05/24/16 06:51 AM
Aeroshell 22 v Mobil 28
by rooflessVW
05/24/16 06:36 AM
QSAD 5W20 VOA Bottled 2/25/16
by dustyroads
05/24/16 06:29 AM
What polish/wax to apply before Collinite 845
by pennzoil_guru
05/24/16 05:46 AM
Native American Advertising
by tony1679
05/24/16 05:45 AM
Akebono ProACT ceramic pads
by dlundblad
05/24/16 04:37 AM
3D printed plastic lower receiver
by Merkava_4
05/24/16 04:19 AM
WeekendWarrior, emily, lex73, showstopr30, any_user
57966 Registered Users
82 registered (AirgunSavant, 87sammy, 2004tdigls, Andrei, abycat, 2009Edge, 6 invisible), 1524 Guests and 115 Spiders online.
57966 Members
66 Forums
249333 Topics
Page 1 of 3 1 2 3 >
#2750854 - 09/21/12 06:54 PM How far can I drive without a serpentine belt?
tgferg67 Offline
Loc: Michigan
Hi
How far is it safe to drive, when a vehicle is cold, without a serpentine belt? I am planning on driving a short distance without a sepentine belt(water pump) to diagnose an engine noise(maybe belt tensioner).
The vehicle is a 2003 Pontiac Vibe with the 1zz base engine.
2003 Pontiac Vibe (1ZZ-FE auto) 200k
Pennzoil dino
#2750859 - 09/21/12 06:57 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
Drew99GT Offline
Loc: Colorado Springs
Probably 5 miles or so I'd say. Watch the temp gauge, and you'll likely kill the battery in the process.
#2750860 - 09/21/12 06:58 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
stephen9666 Offline
Loc: USA
Not very far, I would guess. I would think it will overheat pretty fast without the water moving at all.
Can you just let it run without the belt while you listen? I've done that before.
#2750869 - 09/21/12 07:02 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
Rock_Hudstone Offline
Loc: New Jersey
You can drive to the point where either the engine overheats or the battery dies, the former will likely happen first which can be catastrophic with aluminum engine blocks and heads.
I wouldn't go far (like around the block) and watch the temp gauge carefully.
#2750871 - 09/21/12 07:03 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
tig1 Offline
Loc: Illinois
Don't do it!
2007 Ford Fusion 180,000 miles
M1 0-20 AFE
2007 Ford Focus 154,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2750880 - 09/21/12 07:09 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
92saturnsl2 Offline
Loc: Colorado Springs, CO
You'll get about 5 minutes of warm-up before the temperature gets out of hand.
Once it reads "normal" it only takes a short time before it gets too hot.
The battery on the other hand, will happily run the car and accessories on average around 70-90 minutes without the alternator, provided you don't have headlights or anything high-drain on.
1985 Ford F-250HD Supercab 4x4 460 (7.5L) V8 - T19 4sp
102k mi
2000 Land Rover Disco II - 4.0L V8 100k miles
Castrol Edge 5w-50 w/ AC Delco UPF2 Filter
#2750889 - 09/21/12 07:14 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
tinmanSC Offline
Loc: Oswego, IL
You can probably get it out and around the block. I once drove about a mile and a half with a non-circulating water pump and I was ok. I did this by turning the engine off every time I was slowing down or stopped. I probably restarted that car about 10-12 times in that mile or so, battery was on the way out by the time I stopped.
Does it need to be driven to diagnose the noise? Can you just run it for a few seconds in the garage?
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 [email protected], 2000 [email protected] both VML Full Syn+Purolator PSL20195(soon to be Wix)
#2750907 - 09/21/12 07:27 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
JHZR2 Offline
Loc: New Jersey
None. No way I'd drive anywhere on an aluminum engine without water flow.
#2750915 - 09/21/12 07:29 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
Donald Offline
Loc: Upstate NY
The colder the radiator and the temp outside the better. I went maybe 5 miles. But remember no PS. On my 1993 Suburban the loss of PS is a BIG deal.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2750920 - 09/21/12 07:33 PM Re: How far can I drive without a serpentine belt? [Re: tinmanSC]
tgferg67 Offline
Loc: Michigan
The engine makes noise when cold under load, up to 2500 rpm's. The noise goes away after a few miles.
Pennzoil dino
#2750927 - 09/21/12 07:36 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
dave123 Offline
Loc: wi
As far as you want depends how big of a bill you want when you get their.
#2750936 - 09/21/12 07:43 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
AandPDan Offline
Loc: MA
Don't rely on the temperature gauge at all. Without water circulating you are going to have localized hot spots that might get hot enough to boil while other parts remains cold.
#2750938 - 09/21/12 07:44 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
KB2008X Offline
Loc: St. Louis, MO.
There really should be no need to drive the vehicle to diagnose anything that is driven by the serpentine belt. Running the engine for maybe a minute or two, at an idle, with the vehicle stationary, may be OK. The second you begin driving it you are increasing the heat output exponentially.
Remember, what an engine does, it converts fuel into heat and then, secondarily, that heat is converted into power. These days, an engine running with a completely non-functional cooling system quickly results in a popped head gasket, warped cylinder head and/or an engine block, as well as ruined pistons...and there is room for things to get even worse, if needed.
Back when engines were still cast-iron, both the heads and block, intake and exhaust manifolds, etc., we could get away with continuing to drive a vehicle without the water pump belt for a while befor engine damage occurred, but not anymore.
You need to come up with another diagnostic strategy other than driving the car without the belt.
Keith
Edited by KB2008X (09/21/12 07:50 PM)
04 Town Car 4.6 5w20 FL820S
92 Ram D150 3.9 10w30 MO-090
03 S-10 4.3 5w30 Puro L10111
above on TropArtic Synthetic Blend
10 Toyota Camry - undecided
#2750951 - 09/21/12 08:02 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
tgferg67 Offline
Loc: Michigan
Wouldn't driving without the belt be the same condition as driving "x" distance before the thermostat opens?
Pennzoil dino
#2750962 - 09/21/12 08:09 PM Re: How far can I drive without a serpentine belt? [Re: tgferg67]
KB2008X Offline
Loc: St. Louis, MO.
NO.
Have you tried running the engine, without the belt, in park and at the rpm you normally hear the noise ?
Whenever I have an under-the-hood noise to diagnose the last thing I want to do is go out on the road to try to hear it and figure out what may be causing it, because the road noise just confuses the issue, if not drowning out the noise I want to hear altogether.
You need to be under the hood if at all possible. Is there a rack available to put the vehicle on for diagnosing the noise ?
Keith
Edited by KB2008X (09/21/12 08:23 PM)
Page 1 of 3 1 2 3 >
