Half Price GTX 15W-40 @ REPCO in Oz
by SR5
05/27/16 03:27 AM
1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
05/26/16 10:13 PM
If you liked the Fram AirHog Filters
by rrounds
05/26/16 10:07 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
22 registered (cobra7279, bbhero, chrisri, Bandito440, 3 invisible), 474 Guests and 331 Spiders online.
57996 Members
66 Forums
249469 Topics
Page 1 of 3 1 2 3 >
#2746014 - 09/17/12 12:33 AM how often change PCV valve?
cathy Offline
Loc: usa
I hear all kind of recommendations. I have toyota camry
97 camry.
#2746021 - 09/17/12 01:01 AM Re: how often change PCV valve? [Re: cathy]
HTSS_TR Offline
Loc: Lake Forest, CA
There is no schedule in replacing PCV. Check and clean if needed, if that didn't work then replace.
I bought a replacement for my then 14-15 years old PCV of my '94 LS400 (200+k miles then). The original PCV was in excellent shape without any sign of failing, but I already had a new one so I put it in.
My S2000 has original PCV after almost 9 years.
Edited by HTSS_TR (09/17/12 01:01 AM)
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2746028 - 09/17/12 01:22 AM Re: how often change PCV valve? [Re: cathy]
robshelton Offline
Loc: Winston-Salem, NC
It's kind of a toss up on when to replace them. I take mine out and clean it every other oil change. It's metal and the replacements are plastic, so I'm sticking with what I know works. AFAIK it's the original valve.
Newer ones are plastic and can be harder to clean, so I'd just replace it, maybe every 30 or 40k miles. I would pull it out and shake it to make sure it rattles at each oil change, tho. If it doesn't rattle of course replace it. And probably give the throttle body a little cleaning too.
1993 Camry 2.2 AT 425k - How far will it go?
1999 F150 4.2
2000 Camry 2.2 AT
#2746040 - 09/17/12 02:38 AM Re: how often change PCV valve? [Re: cathy]
INDYMAC Offline
Loc: Magnolia, TX
On my 2000 Tundra I learned that paying attention to this little, inexpensive maintenance item is worth your time. You can clean it, or replace it. I just replace them every 30K miles now. I prefer OEM replacements. If it's a screw in type, it's easy. If it has a grommet, it's more of a PITA. The grommets tend to become hard and brittle. Changing the grommet every other PCV valve change is a good idea to avoid having it crumble and fall through the valve cover.
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
#2746043 - 09/17/12 03:45 AM Re: how often change PCV valve? [Re: cathy]
oilmaven Offline
Loc: Northern Michigan
I bought a new PCV for my 1999 Mercury Villager. The valve is located behind the engine and involves removing a bunch of parts to replace...a real PITA. I haven't tackled it yet and my mechanic said it was an hour worth of labor for him to do it. My understanding is that if the oil was changed frequently the valve usually holds up a long time (previous owner changed the oil every 3,000 miles or less). I'm putting off replacing it for now.
2010 Suzuki Kizashi-Pennzoil Platinum Pureplus 5W30
2013 Toyota Prius-Pennzoil Platinum 0W20
#2746102 - 09/17/12 06:25 AM Re: how often change PCV valve? [Re: cathy]
CourierDriver Offline
Loc: USA
they will last longer then u will own the car. just u wait and see.
Thank goodness for YouTube or I could not work on my car....
#2746318 - 09/17/12 10:38 AM Re: how often change PCV valve? [Re: cathy]
cutter Offline
Loc: Philadelphia, PA
Naphtha bath for my oem PCV if I see any crud on it. No way am I ever using a 3rd party pcv.
#2746350 - 09/17/12 11:13 AM Re: how often change PCV valve? [Re: cathy]
surfstar Offline
Loc: Santa Barbara, CA
Kinda of like spark plug wires or fuel filters - I read replace every 60k or 90k miles online and blindly did so. Now I'm just inspecting and testing and will replace wires and PCV valve when it actually needs it.
#2746406 - 09/17/12 12:14 PM Re: how often change PCV valve? [Re: cathy]
TFB1 Offline
Loc: VA
another clean & reinstall, 99% of the time they don't need replacement...
#2746448 - 09/17/12 12:41 PM Re: how often change PCV valve? [Re: cathy]
VicVinegar Offline
Loc: Northern Virginia
Mine is 13 years old and original. I was going to buy an OEM replacement just to get a fresh one in there, but there were some posts on Civic forums talking about them breaking on removal and causing a bigger headache. Plus it is also in the back of the motor and a bit of a pain to access.
Edited by VicVinegar (09/17/12 12:42 PM)
#2746516 - 09/17/12 01:47 PM Re: how often change PCV valve? [Re: cathy]
Vikas Offline
Loc: NorthEast
I had purchased a replacement PCV for my 99 Odyssey few years ago but never could figure out how to replace it. Couple weekends ago, I had to take the plenum off and finally I had access to the PCV. It was clogged but I used carburetor cleaner to clean it up and put it back. The replacement was an aftermarket plastic one bought at NAPA. I decided to stick with the original metal one after cleaning it.
Suggestion:- Either purchase a new one from the dealer or re-use the existing one after cleaning it.
#2746727 - 09/17/12 05:27 PM Re: how often change PCV valve? [Re: cathy]
Burny Offline
Loc: Chesapeake
If you keep your oil changed regularly it will never need replaced. I have a 1991 4runner I bought new and have never replaced it. Same with fuel filter.
#2746836 - 09/17/12 07:41 PM Re: how often change PCV valve? [Re: cathy]
Whimsey Offline
Loc: The Garden State
I suspect if you don't burn oil during OCI's then you PCV should not plug up. My wife's bought new 2005 Explorer w/the 4.6 has over 125,000 miles on it and still has the original PCV valve. It uses no measurable amount of oil in it's 8,500 mile OCI's. I suspect if you burn oil then your PCV valve will clog up eventually and increase your oil usage.
Whimsey
#2747084 - 09/18/12 03:40 AM Re: how often change PCV valve? [Re: cathy]
INDYMAC Offline
Loc: Magnolia, TX
"The function of a PCV valve is to control the flow of crankcase gases. Start your engine, then remove the oil filler cap (watch your clothes; you might get some oil splatters). Place your hand just above the opening. Feel the strong jet of air? That's "blowby", combustion gases that squirt past the piston rings into the crankcase below the pistons. Even new engines in good condition generate lots of blowby (but it's still a small
fraction of what passes through the throttle body).That jet of air has to be vented somewhere, otherwise it will quickly build up pressure inside the engine, and cause those aforementioned very bad things to happen. If the PCV valve gets plugged, blowby pressure has no proper place to go.
The primary reason for plugged PCV valves is neglected oil changes, which causes sludge. Secondarily, it also happens to engines that are primarily used for short trips, where moisture, fuel, and acids build up in the oil, emulsifying it into sludge, which is related to the neglect thing mentioned earlier. 3 months between changes might be too long depending on how you drive.
Also, an engine with worn compression rings will have massive amounts of blowby, which will overwhelm the PCV valve's ability to pass air and cause the excess vapors (and oil) to be pumped into the intake before the throttle plate.
Since the air inside the crankcase also contains contaminants like unburned fuel, water, acids and other things that your engine and its oil do not like, venting the excess pressure also helps to vent those contaminants out of the engine before they settle into the oil in the first place, so your oil stays a bit cleaner longer."
http://www.tegger.com/hondafaq/pcv-replace/
2004 Honda S2000
#2747408 - 09/18/12 01:04 PM Re: how often change PCV valve? [Re: HTSS_TR]
NJC Offline
Loc: Vancouver BC
That's why I did on my 2004 Sienna ... left it overnight on side filled with Pblaster. Drained, rinsed out with garden hose and reinstalled after drying.
Page 1 of 3 1 2 3 >
