Wiha screwdrivers
by Donald
8 minutes 2 seconds ago
How Can I Print 755 Mailing Labels For Post Cards?
by crazyoildude
56 minutes 0 seconds ago
Valvoline Full Synthetic High Mileage and Blend HM
by mctmatt
Today at 03:59 PM
Delo 400 Severe Duty?
by 333jeffery
Today at 03:56 PM
2016 Civic sedan is selling very well
by HTSS_TR
Today at 03:24 PM
Oil suggestion for 2013 Honda CR-V
by Mar57
Today at 03:02 PM
STOP CALLING ME!!!!
by NHHEMI
Today at 02:33 PM
Need oil suggestion for high mileage 2003 WRX
by xmakeafistx
Today at 01:09 PM
09 VW Passat Wagon 2.0TSI 4900mi Castrol 0w40 Euro
by gerkin85
Today at 12:48 PM
Oil/filter recommendation for short trips
by DrRoughneck
Today at 12:46 PM
Auto Zone brand oil on clearance (YMMV)
by blupupher
Today at 11:20 AM
M1 5w30 HM / 5512 Miles / Turbo with Towing
by Astro_Guy
Today at 11:10 AM
slewman, lithium1189, Monktana, djh3, Compignite
56850 Registered Users
103 registered (87sammy, 69GTX, 901Memphis, 2oldtommy, 2010Civic, 10 invisible), 1606 Guests and 229 Spiders online.
56850 Members
66 Forums
244413 Topics
#2741120 - 09/11/12 07:53 PM Creaking front end
coopns Offline
Loc: Scituate MA
02 Grand Caravan, the old girl is showing her age. On the right side, she kind of creaks (sounds like a matress spring) when I go over bumps. Not awful but creaky.
I tried using a grease gun but I don't think I did it right. I had it loaded up, put the end on the nipple of the sway bar and thought the grease would on right in but it just kind of smeared all over. Am I applying it wrong?
Think that is it, sway bar?
Edited by coopns (09/11/12 07:54 PM)
Coop
#2741123 - 09/11/12 07:57 PM Re: Creaking front end [Re: coopns]
Astro14 Offline
Loc: Virginia Beach
So many possibilities...bushings, strut mounts, struts themselves...but I would start with the rest of the bushings...squirt some WD-40 on each one and see if you lose the squeak.
When you find it, replace it...
32 Packard 15W40
90 4Runner 5W30 Edge
92 300E 5W40 LiquiMoly
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W30 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
#2741125 - 09/11/12 07:57 PM Re: Creaking front end [Re: coopns]
simple_gifts Offline
Loc: Middlesex County CT
I found the source of my creaking in my Toyota; it was worn out steering stabilizer links. Having the car lifted aggravated the situation; just something to consider.
2003 Echo >385K miles; Pennzoil Ultra 0w-40; TY AZ
2006 B2300;101K;ALM
Less Melissa McCarthy and more Jenny McCarthy
#2741133 - 09/11/12 08:05 PM Re: Creaking front end [Re: Astro14]
Topo Offline
Loc: Norwalk, Ohio
I had the same issue on my Chrysler 300. Few things happened. The struts where shot, riding on springs to much( springy sound). Also outer tie rod end(clucking/rubbing noise), in addition has some minor clucking sound, that was sway bar bushings(clunking sound).
2010 Chrysler 300 Tour.Sig 3.5L
165,000 Miles On Engine and Climbing
Current: Napa Syn. 5W30/Napa Gold
10,000 OCI
#2741230 - 09/11/12 10:11 PM Re: Creaking front end [Re: coopns]
bigjl Offline
Loc: London, England
The times I have had creaks from.the front I have cured it by either replacing the anti roll bar drop links or the lower suspension arms.
Though the tip of spraying wd40 would work. I have a mate that does the same but with silicon spray.
10 BMW 116D SE 110k miles Full BMW Hx
12 Jaguar XJL 3.0 D Luxury 132k 5w30 Shell AF-L
#2741237 - 09/11/12 10:16 PM Re: Creaking front end [Re: coopns]
Thax Offline
Loc: VA
It is most likely the sway bar bushings and or links that require replacement. Take some silicon based lubricant and spray directly on the bushings. If it stops the noise you have found the culprit. However it is not advisable to use a petroleum based product such as wd-40 on bushings as it will harm the rubber in the bushings themselves.
00 Dodge Durango 4.7L
99 Jeep Cherokee 4.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
#2741330 - 09/12/12 03:21 AM Re: Creaking front end [Re: coopns]
eljefino Offline
Loc: ME
^ yup the end links are junk on those vans they are like a girdle on a fat chick they have their work cut out for them. New ones are only around $12 and the little ball joints just snap; no grease will help at this point.
When they go the van will tip over in modest turns and remind you of a sailboat.
#2741348 - 09/12/12 05:23 AM Re: Creaking front end [Re: coopns]
rszappa1 Offline
Loc: louisville ky
Check the sway bar bushings. My 1999 Dodge Caravan did the same and that was the problem... Also very easy to change...
#2741765 - 09/12/12 01:44 PM Re: Creaking front end [Re: coopns]
mechtech2 Offline
Loc: Chicago Area
Any spray lube should mask the noise for a day.
Judiciously apply it in isolated spots to determine which is the offender. If you do all at once , how will you know?
A arm bushings are #1, and sway bars or links #2.
