mixing gear oil for manual tran
by ntoxicator
06/28/16 11:04 AM
Transmission shudder/and an honest mechanic
by gman2304
06/28/16 10:57 AM
M1 0w40, 13,011 miles, 2010 BMW 328i
by Patman
06/28/16 10:32 AM
VW to pay owners up to $10K...
by Quattro Pete
06/28/16 10:19 AM
Lawnmower Won't Start When Engine Hot
by jkon
06/28/16 10:09 AM
Rheology of Viscosity Modifiers and ULV Lubricants
by Solarent
06/28/16 10:09 AM
Block heater leaks, Use sealant on expansion plug?
by Colt45ws
06/28/16 10:02 AM
85 octane... Wth?
by horse123
06/28/16 09:39 AM
Fram XG2 Bypass Valve
by Canadastang
06/28/16 09:22 AM
'02 VW Cabrio -- Pros & cons?
by Benzadmiral
06/28/16 08:27 AM
Early review on 2015 Chrysler T&C
by badtlc
06/28/16 07:25 AM
New car storage
by JoelB
06/28/16 07:17 AM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
96 registered (adamrc, Alfred_B, AirgunSavant, b1amgm47, Bandito440, ARCOgraphite, 9 invisible), 1980 Guests and 12 Spiders online.
58295 Members
66 Forums
250930 Topics
#2733348 - 09/03/12 10:14 AM Can you mix Valvoline ATF and Castrol in Hyundai?
zerosoma Offline
Loc: Omaha, NE
My santa fe will need an atf change before winter hits. I noticed castrol was on sale. I believe valvoline is in there from the last time the owner before me changed it.
will they mix?
2004 Hyundai Santa Fe LX 3.5L V6 (125k) [Valvoline Max Life Next Gen 5w30]
#2733377 - 09/03/12 10:39 AM Re: Can you mix Valvoline ATF and Castrol in Hyundai? [Re: zerosoma]
MolaKule Offline
Loc: Iowegia - USA
I have yet to see any ATF or PCMO NOT mix (chemically).
Edited by MolaKule (09/03/12 10:54 AM)
I got up this morning and ran around the block. Then I got tired so I put the block back in the Toy Box. smile
#2733382 - 09/03/12 10:41 AM Re: Can you mix Valvoline ATF and Castrol in Hyundai? [Re: zerosoma]
zerosoma Offline
Loc: Omaha, NE
i've just heard so many stories of the wrong atf being mixed in, and the trans being ruined. is this just scare tactic or is this true?
#2733390 - 09/03/12 10:52 AM Re: Can you mix Valvoline ATF and Castrol in Hyundai? [Re: zerosoma]
MolaKule Offline
Loc: Iowegia - USA
Check the product labelling and Product Specification Document for vehicle application coverage.
I think what most people mean is that not all ATF fluids cover all vehicles, and that is true.
For example, you would not want to use a Chrysler spec ATF+4 in a Kia. However, they will all MIX chemically, but that does not mean that ATF+4 should be used in a Kia's tranny.
#2733397 - 09/03/12 10:56 AM Re: Can you mix Valvoline ATF and Castrol in Hyundai? [Re: zerosoma]
MolaKule Offline
Loc: Iowegia - USA
I have heard via testimony that the import versions of Castrol and Valvoline multi-vehicle fluids do work.
#2733409 - 09/03/12 11:06 AM Re: Can you mix Valvoline ATF and Castrol in Hyundai? [Re: MolaKule]
JC1 Offline
Loc: Oshawa, Ontario Canada
It would probably work if you mixed them. Is the Castrol rated for SP-3?
#2733704 - 09/03/12 05:33 PM Re: Can you mix Valvoline ATF and Castrol in Hyundai? [Re: zerosoma]
JTK Offline
Loc: Buffalo, NY
will they mix?
Having owned a 2008 Santa Fe and been involved over at HyundaiForums for some time, I can tell you both Castol Multi-Import and Valvoline Maxlife ATF both work perfectly in the Hyundai F4A51 trans that you have. I've never read where mixing them is an issue. Any ATF recommended for use where Hyundai/Kia SPIII is specd can be mixed.
Any time you do an initial drain/fill, you're mixing ATFs. It's not a problem provided it's spec'd for your vehicle.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
