Superbowl and Willie Woods
by Donald
39 minutes 9 seconds ago
Rural King Synthetic
by MarkM66
39 minutes 25 seconds ago
Lesson learned from rebuilding updraft carb
by Donald
58 minutes 58 seconds ago
UOA on QSUD 0W20 coming soon!!!
by thorromig
Today at 08:05 AM
Which 0w-20 would you pick? (Based on specs)
by tam92
Today at 07:48 AM
Kohler Courage SV735-0013
by Mavigraph
Today at 07:46 AM
nearly 20k miles of research gone ....
by meborder
Today at 06:46 AM
New - smoke detectors for house.
by bmwjohn
Today at 03:45 AM
ProGauge PGO-4612 Oil Filter??
by andrewp1998
Today at 01:11 AM
Filter efficiency and diminishing returns
by ToadU
Today at 12:19 AM
Change PP after 1000 mi 6 month Short Winter Trips
by WillsYoda
Today at 12:00 AM
Tread Life & Curvy Roads
by Nick1994
Yesterday at 11:46 PM
Nazmorgul, bhans, truthtracer, Recreator, 18LateModelFan
56842 Registered Users
83 registered (1989outlaw, 77GrandPrix, 90crvtec, 901Memphis, A1O, 6 invisible), 1322 Guests and 195 Spiders online.
56842 Members
66 Forums
244355 Topics
Page 1 of 2 1 2 >
#2728167 - 08/28/12 08:15 PM Loose positive battery terminal cable
Chuck1986 Offline
Loc: Scottsdale, AZ
My positive battery terminal cable has been loose even though I have tightened the bolts the best I can. This insecure connection has caused occasional issues with providing power to start my car. Are there any suggestions to get a tighter connection without buying a whole new cable? (It is a dealer-only item and costs $250).
I was thinking about putting aluminum foil around the terminal to make the connection tighter but I imagine this is a horrible conductor and will cause more issues than it will solve.
Edited by Chuck1986 (08/28/12 08:17 PM)
2001 Mitsu Eclipse GT 120k miles
2011 Nissan Altima SR coupe 50k miles
#2728174 - 08/28/12 08:25 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
JHZR2 Offline
Loc: New Jersey
If I was trying something like that, it would be copper sheet formed to fit.
They do make replacement terminals if you have cable slack.
#2728177 - 08/28/12 08:26 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
GumbyJarvis Offline
Loc: Fort Hood, TX
can you not cut the wire end and buy a new terminal clamp?
my Ex's focus was one of those clamp+wire in one deals with a "Permanent clamp"
well in florida, clamps go bad
her uncle and I just cut the wire instead of buying a 30$ wiring set, and slapped on a new clamp Autocraft from AAP,
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_top-post-battery-terminals-autocraft_6280781-p?navigationPath=L1*14920%7CL2*15001
with the 2 nuts on top, multiple wires arent a problem, she had 4 wires, 2 were the main, one was lights, one was radio i guess, anyway the 2 main were mounted normal, the 2 smaller ones were clamped with electrical hooks (round thingy for screwing down ground wires) and mounted to the nuts on top.
If you can buy the marine ones if theyll fit or the rust/corrosion ones, they last longer and are better built.
I use easy access marine ones that have a lever on them so theyre tool free.
13 Dodge Dart SXT 2.0L 40k MI
Castrol Edge 0w40 + Ultra
05 Ford Ranger 2.3L 225K MI
Havoline 10W40 + Purflux
M1A2 SEPV2 6k MI
Royco 560 + Purolator
#2728184 - 08/28/12 08:31 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
abycat Offline
Loc: grande prairie AB
Actually aluminum is a great conductor. Go to a parts store and get lead post shims. Done!
2004 f350 6.0
2011 nissan versa hb
#2728188 - 08/28/12 08:37 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
GumbyJarvis Offline
Loc: Fort Hood, TX
IMHO i would risk my safety on Aluminum foil.
Keep the foil in the kitchen, keep the tools in the garage.
M1A2 SEPV2 6k MI
#2728197 - 08/28/12 08:43 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
Chris142 Offline
Loc: apple valley, ca
Bend a penny around the terminal for a shim or do the old Sheetmetal screw trick.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2728207 - 08/28/12 08:51 PM Re: Loose positive battery terminal cable [Re: GumbyJarvis]
djb Offline
Loc: Maryland
Keep the foil for a hat that blocks the mind control rays, and use a metal that won't have a problem with oxidation and melting.
Is this a bolt tightened clamp around a projecting post, or a screw holding a ring terminal onto a side terminal battery?
Is there a single thick cable coming out of the terminal, or a few additional wires?
#2728215 - 08/28/12 08:55 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
vssjim Offline
Loc: McLean, Va.
we cut off the cable end and put on a copper cable lug with an eyelet that fits in to a marine battery cable end the Standard motor products part number for the terminal is BP22U the cable lugs are in the catalog for wire and cable from Standard as well.
#2728224 - 08/28/12 09:04 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
Errtt Offline
Loc: California
In a pinch, I've cut a sheet from an aluminum can, wrapped it around a post, melted fishing sinkers and poured to the level of the post. Have the aluminum a tad loose around the post to help make it's diameter a little bigger.
No time - I've wrapped a few turns of thin solder around the post squeezed it a bit with pliers.
add - oh yeah, the old penny and nail trick in a pinch too.
Edited by Errtt (08/28/12 09:05 PM)
#2728228 - 08/28/12 09:07 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
yonyon Offline
Loc: NJ, USA
Loosen the clamp as far as possible and slip in a shim. Use something shaped like a nail, but not a nail. Use something made of glass, ceramic, or lead: whatever junk you can find. Clamp it down tight and call it good.
#2728233 - 08/28/12 09:13 PM Re: Loose positive battery terminal cable [Re: Errtt]
yonyon Offline
Loc: NJ, USA
The penny may work for a while but will grow green fur that has high resistance.
#2728249 - 08/28/12 09:29 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
SIXSPEED Offline
Loc: Arizona
Do you have one of those felt washers under the terminal? Sometimes they raise the terminal enough so they can't clamp the tapered post securely.
#2728281 - 08/28/12 09:56 PM Re: Loose positive battery terminal cable [Re: Errtt]
johnachak Offline
Loc: L.I. NY USA
What a waste of fine fishing tackle....
06 Ford Freestyle, PP syn 5w20 MC filter
09 CTS 3.6 D.I. AWD, M1 5w30 Delco filter
Daughters Jeep Compass 2011, 2.4 AWD, 4WD switchable on the fly.
JMH
#2728299 - 08/28/12 10:12 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
lead shims...AutoZone
Lynx/Battery post shim
Part Number: 07769
CHECK AVAILABILITY AND
PRICING INFORMATION
Eligible for FREE 2-Day Shipping
learn more | sign in
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#2728304 - 08/28/12 10:16 PM Re: Loose positive battery terminal cable [Re: Chuck1986]
Carbon Offline
Loc: near Chicago
Is this one of the big tapered lead battery posts? It may be if you spread the terminal clamp apart, you can push the terminal farther down onto the tapered post before tightening.
For a replacement terminal, put battery terminal into the search box of an auto parts place. Here is such a search: http://www.autozone.com/autozone/accesso...omString=search
Note that the results are on more than one page.
Ooooh! Ooooh! look at this one: http://www.autozone.com/autozone/accesso...ier=257147_0_0_
http://contentinfo.autozone.com/znetcs/product-info/en/US/epm/07769/image/2/
Edited by Carbon (08/28/12 10:18 PM)
Page 1 of 2 1 2 >
