2013 6.7 F350 LE 5w40 4276mi
by BeerCan
05/24/13 04:04 PM
Another K-mart commericial.
by simple_gifts
05/24/13 03:58 PM
Super Amazon Prime Deal on M1 plus M1 Filters
by BerndV
05/24/13 03:27 PM
S2000 vs rx8 R3
by donnyj08
05/24/13 03:22 PM
Oil filter capacity and oversizing thoughts...
by KCJeep
05/24/13 03:17 PM
Pump shotgun or Taurus Judge for home defense?
by TaterandNoodles
05/24/13 03:12 PM
Mobil 1 EP vs Amsoil Signature Series 5W-30
by BerndV
05/24/13 02:10 PM
Toyota Canada vs Toyota USA and OCI -Rant ahead
by pennzoil_guru
05/24/13 01:53 PM
END OF THE ROAD
by Mark72
05/24/13 01:15 PM
Buick Transmission Fluid Change
by actionstan
05/24/13 01:01 PM
TCW3 as oil additive for cleaning?
by Youthanasia
05/24/13 12:51 PM
Clean drain SLOT on 90s GE room air conditioner ?
by antiqueshell
05/24/13 11:50 AM
Kenber, eage8, macattictom, Miggz10, stevesnj
45545 Registered Users
109 registered (901Memphis, 99Saturn, 05LGTLtd, AmishFury, 666stars, 2000RX300, 14 invisible), 1624 Guests and 241 Spiders online.
45545 Members
64 Forums
193883 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 2 1 2 >
#2727186 - 08/27/12 10:33 PM 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M
irontom Offline
Loc: ca
Code:
LAB NUMBER: F14287 UNIT ID: 03 VIBE
OIL REPORT DATE: 8/7/2012 CLIENT ID:
REPORT
Toyota 1.8L 4-cyl (1ZZ-FE)MAKE/MODEL: OIL TYPE & GRADE: Mobil 1 10W/30
Gasoline (Unleaded)FUEL TYPE: OIL USE INTERVAL: 27,920 Miles
ADDITIONAL INFO:
COMMENTS TOM: The only thing highlighted last time was
aluminum, and that dropped back a tick this time around,
leaving your Vibe with a clean report. Iron and silicon are
still above average for this type of engine, but silicon has
been reading at this level for quite a while now, so it's not
a problem, and the excess iron is due to the long oil run.
Universal averages show 8 ppm iron is normal after ~5,600
miles of oil use, but you ran nearly five times as long on the
oil, so three times the iron isn't bad! The TBN was down to
0.8, so we wouldn't run longer for now, but this is a nice
report!
ELEMENTS
IN
PARTS
PER
MILLION
MI/HR on Oil 27,920 29,895 8,407 11,778 9,948 7,849 UNIVERSAL AVERAGES
MI/HR on Unit 201,249 UNIT / 173,329 128,943 76,628 64,850 54,902
Sample Date 07/24/12 AVERAGES LOCATION 08/22/11 01/13/10 09/07/07 02/02/07 04/17/06
Make Up Oil Added 1.5 qts 4 qts 0.5 qts 0 qts 0 qts 0 qts
ALUMINUM 5 4 6 4 4 2 2 3
CHROMIUM 1 0 1 0 0 0 0 0
IRON 24 16 21 16 16 14 7 8
COPPER 1 1 1 1 2 1 0 2
LEAD 1 1 1 1 3 2 0 1
TIN 0 0 0 0 0 0 0 1
MOLYBDENUM 75 89 113 99 89 81 74 77
NICKEL 0 0 0 0 1 0 0 0
MANGANESE 1 2 2 2 3 2 0 1
SILVER 0 0 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0 0 1
POTASSIUM 5 3 3 4 3 1 2 1
BORON 39 49 59 46 40 40 68 40
SILICON 23 19 22 21 21 16 12 14
SODIUM 6 86 17 8 6 6 39
CALCIUM 1340 2336 2506 2625 2837 2317 2388 2195
MAGNESIUM 875 209 182 69 59 48 18 113
PHOSPHORUS 748 695 761 699 669 659 636 713
ZINC 997 881 1001 883 866 784 754 840
BARIUM 0 1 0 0 1 1 1 0
Values
Should Be*
PROPERTIES
SUS Viscosity @ 210°F 64.3 58-68 67.3 61.8 57.9 57.7 59.2
cSt Viscosity @ 100°C 11.41 9.7-12.7 12.23 10.73 9.63 9.55 9.98
Flashpoint in °F 375 >365 405 370 375 385 395
Fuel % <0.5 <2.0 <0.5 <0.5 <0.5 <0.5 <0.5
Antifreeze % 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Water % 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Insolubles % 0.3 <0.6 0.3 0.3 0.3 0.4 0.2
TBN 0.8 >1.0 2.2 2.0 4.1 1.8 2.9
TAN
ISO Code
* THIS COLUMN APPLIES ONLY TO THE CURRENT SAMPLE
416 E. PETTIT AVE. FORT WAYNE, IN 46806 (260) 744-2380 www.blackstone-labs.com
©COPYRIGHT BLACKSTONE LABORATORIES 2012 LIABILITY LIMITED TO COST OF ANALYSIS
This has been run at 15,000 miles OCI until the last 2 which where 27,920 and 29,895. Always using Toyota Oil Filter Part # 90915 yzzF1 which is larger then stock.
#2727217 - 08/27/12 11:50 PM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
tinmanSC Offline
Loc: Oswego, IL
Did I read this correctly? You're doing almost 30K OCI? shocked2
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300@200K PP, 2000 GS300@90K VNG both with Purolator PSL20195 (oversized)
#2727278 - 08/28/12 05:44 AM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
Falken Offline
Loc: Montreal, QC, Canada
Wow, I don't see a point in running oil this long, but it is nice and informative for the rest of us.
This is probably the longest oil run I have ever seen on BITOG.
And, it is a good report at that. I am surprised that you still have any TBN left after 30,000 KM!!
Falken - Apprentice Auto Mechanic
2010 Honda Fit DX-A in Black
Current Fill: Pennzoil Ultra 5W20 SM, Wix 57356 Oil Filter, ATF DW-1 Full Synthetic
#2727299 - 08/28/12 06:23 AM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
Falken Offline
Oops, meant to say 30,000 Miles, not KM.
I'm blown away. Is this the SN version?
I may start using Mobil 1...
#2727309 - 08/28/12 06:50 AM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
Thax Offline
Loc: VA
I sure as [censored] wouldnt run a oci like this nor do I recommend it , but it is working for ya. Impressive , cant deny XOM makes a quality lube.
00 Dodge Durango 4.7L
99 Jeep Cherokee 4.0L
01 Mazda Tribute 3.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
#2727310 - 08/28/12 06:51 AM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
LeakySeals Offline
Loc: MA
Would reconsider using a end-capless Toyota OEM standard interval filter. A synthetic extended interval filter may be a better fit for your OCI.
08 Pontiac GP 3800 Series III 80k PU 5w30 OLM OCI
02 Camry XLE 2AZ-FE 268k M1 HM 5w30, 9k OCI
Both: FRAM ULTRA, RMI-25
#2727335 - 08/28/12 07:42 AM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
buster Offline
Loc: NJ
Kind of proves what XOM has said all along in that the Tbn will hang on for quite some time. This is the SN stuff too.
They test all Mobil 1 grades out to 25,000 miles.
Notice how oxidation resitant M1 is. You can see from this report that it's still a 30 grade, but slowly creeping up.
#2727343 - 08/28/12 07:54 AM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: buster]
LeakySeals Offline
Loc: MA
Buster,
When you say creeping up do you mean thickening?
#2727346 - 08/28/12 07:58 AM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
buster Offline
Loc: NJ
Yeah if I'm reading it correctly the viscosity is 11.4, which is still a solid 30 grade. It stade in grade.
#2727361 - 08/28/12 08:11 AM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: Thax]
buster Offline
Loc: NJ
+1
I would never suggest going this far either. 15k is a lot, 30k is really pushing it LOL. Held up well though in this application.
No bypass filter either.
#2727548 - 08/28/12 11:10 AM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
FZ1 Offline
Loc: Texas
Good report relative to the miles. How many months was the oil in use. What type of driving highway/city mix?
#2727606 - 08/28/12 12:05 PM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
tinmanSC Offline
Loc: Oswego, IL
I'm interested to know what kind of driving this engine saw during this run.
Cost of Hobby=2L
#2727773 - 08/28/12 02:03 PM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
irontom Offline
Loc: ca
This is mostly highway driving. 15 mile trip mornings, and after noon daily. With 5 or 6 trips 50 to 80 mile plus return every week, Occasional short shopping trips also.
Had always run 15,000 Then the wife took over driving this car and ignored the stickers. Drats! I plan on going 20,000 now.
Oil was in use for about 10 months I also used the wrong info this is 5W/30 not sure tat matters. maybe moderator could fix the subject line?
#2727796 - 08/28/12 02:27 PM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
buster Offline
Loc: NJ
These are great results. One of the more impressive long drain UOA's I've seen.
Stick with it and use the Mobil 1 Extended Performance 5w30 oil.
#2727816 - 08/28/12 02:50 PM Re: 2003 Pontiac Vibe 201,294 Mobil 1 10W/30 27,900 M [Re: irontom]
cutter Offline
Loc: Philadelphia, PA
Very nice 1zz. A million mile engine after the oil-burning revision.
Page 1 of 2 1 2 >
