For Sale: 2004 Ram 1500
by RamFan
Today at 02:10 PM
2005 Volvo S40 2.4i - Optimal Oil Choice?
by mgm7890
Today at 12:58 PM
Something for a quiet Saturday, vapors...
by OneEyeJack
Today at 12:33 PM
Ford guys: Crown Vic windshield washer not working
by Jimmy9190
Today at 12:08 PM
Very cold outside, vehicle sitting for a few day's
by 07titan
Today at 11:26 AM
compression fittings and fuel starvation
by eljefino
Today at 10:47 AM
Anyone here make a homemade jump starter pack?
by skyactiv
Today at 10:31 AM
API *SL* Oil Still on Shelf
by CrackyWainwright
Today at 10:17 AM
Jeep "shudders" at 35-40 mph
by Joe_Power
Today at 09:27 AM
How Often to Drain and Refill AT's?
by Gebo
Today at 09:18 AM
Gas water heaters
by spasm3
Today at 08:59 AM
Woman killed by flying manhole cover in Boston
by Mr Nice
Today at 08:56 AM
Formula413, Cruzingoose, klob, beaglefet, bsmith3
56907 Registered Users
94 registered (901Memphis, Andy636, 3800Series, 1989outlaw, Abakev, amerendino, 6 invisible), 1819 Guests and 109 Spiders online.
56907 Members
66 Forums
244646 Topics
#2725617 - 08/26/12 12:10 PM Fuel pressure regulator, if bad, what symptoms?
wolf_06 Offline
Loc: Atlantic, Canada
I wonder if fuel pressure regulator can have the same symtpoms as a bad fuel pump. And where is the fuel regulator location?
2011 Chevy Cruze 1.8L 6AT
Castrol Edge Syntec w/ Titanium 5w30 - OEM filter
#2725662 - 08/26/12 01:27 PM Re: Fuel pressure regulator, if bad, what symptoms? [Re: wolf_06]
Warstud Online   content
Loc: MIchigan
Hard starting...stalling and the smell of raw gas are symptoms of a bad FPR. May be along the fuel rail.
#2725779 - 08/26/12 04:40 PM Re: Fuel pressure regulator, if bad, what symptoms? [Re: wolf_06]
TFB1 Offline
Loc: VA
Most systems in approx the last 10 years don't have a fuel pressure regulator but instead have a fuel pressure sensor... These systems regulate pressure by varying the voltage to the pump, vs having a mechanical regulator and constantly running the pump at battery voltage... Plus is there is no fuel return line to the tank and pump supposedly lasts longer as it's only pumping what's necessary, instead of constantly circulating the fuel...
#2725804 - 08/26/12 05:03 PM Re: Fuel pressure regulator, if bad, what symptoms? [Re: TFB1]
Tegger Offline
Loc: Canada
My understanding is that returnless systems are an answer to recent EVAP regulations: Returnless systems lack a return line, which eliminates a line and lot of connections, all of which are potential sources of fuel/vapor leaks.
As for the OP's question, I'd expect that most fuel-pressure problems would be very likely to be flagged by the OBD-II system before any symptoms would be felt. I'd be expecting an illuminated MIL with a P01xx DTC.
2013 Toyota RAV4 - 47,000 miles - Toyota 0W-20, Toyota filter
#2726062 - 08/26/12 09:21 PM Re: Fuel pressure regulator, if bad, what symptoms? [Re: wolf_06]
ltslimjim Offline
Loc: WatUpDoc
Easy check on vehicles with external FPR mounted to the fuel rail is to remove the vacuum line that is used to work the diaphragm open. If the fuel pressure does not raise once the vacuum line is removed, the pressure regulator is bad.
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2726226 - 08/27/12 06:45 AM Re: Fuel pressure regulator, if bad, what symptoms? [Re: ltslimjim]
The_Eric Offline
Loc: Iowa
Or if there's raw fuel in the vacuum line, it's bad.
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#2726898 - 08/27/12 06:25 PM Re: Fuel pressure regulator, if bad, what symptoms? [Re: wolf_06]
mechtech2 Offline
Loc: Chicago Area
Right, Eric. It's the first thing to check.
#2728048 - 08/28/12 06:40 PM Re: Fuel pressure regulator, if bad, what symptoms? [Re: wolf_06]
ltslimjim Offline
Loc: WatUpDoc
Oh, yeah. That too! lol
