The room that I want to cool has windows that necessitate a portable unit. I have never owned one before, only window-mounted units or central air.
I purchased this model of LG portable AC about a month ago.
The unit worked perfectly for about two weeks. Then one day after running for about an hour, the display read error message "E4". According to the manual, that means the coils are icing over...which is odd because the room air temp was around 77 degrees, and the unit had barely started to cool it down. In the past, I had run the AC all night with the room down to 68 degrees, and it never displayed an error. I emptied the water reservoir (it had about an ounce in there) and cleaned the filter, but that did not make a difference. The unit continues to go into "E4" error mode after running for a short time.
Does anyone have any ideas on what else I can check?
