Latest UOA from my BMW - one track day at Barber motorsports Park last October, using a Mahle filter this time. Last UOA on the left hand column (you may have to scroll)
I added a half quart of Red Line 5w-40 at Barber, viscosity should have been raised to about 12.0 or so.
Changed oil and used 4 quarts of red Line 0w-30 and 4 quarts of red Line 0w-40. Should have a 100C viscosity of about 12.5 and a HTHS of about 3.6.
The UOAs with lower copper were without track days for the most part. I must get a little more bearing wear on the track ???
Blackstone comments:
You noted the viscosity should have come in around 11.1 Centistokes on the Kinematic scale, and
your guess was close. The viscosity came back a little high at 12.36, which is up in the 5W/40-grade range.
Wear accumulation continued tracking along normally after running the oil out to 9,004 miles and no
contamination was present, so the high viscosity isn't a serious problem. Maybe some excess heat was to
blame? The TBN dropped down to a low 0.3, so you might want to stick with no more than 9,000 miles on
the next sample. No new problems found.
We did have several days of 100+ heat back in July. A long string of 90+ days throughout the month.
Code:
2003 BMW 330 Ci
Miles on oil 5011 5000 4300 5958 4514 5347 5017 3839 7,250 5,100 7786 7400 5643 8119 7858 9004
Total miles 21130 26100 31407 37365 41879 47226 52245 56084 63,334 68,400 71120 78494 84137 92256 100109 109113
Date 05/05 10/05 03/06 06/06 03/07 06/07 03/08 09/08 10/08 06/09 06/09 12/13/09 8/17/10 4/12/11 11/7/11 8/3/12
Make up oil 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.5 0.0 0.0 0.0 0.5 0.5
Oil Brand BMW Castrol Castrol BMW Castrol Castrol Castrol Castrol RedLine RedLine RedLine RedLine RedLine RedLine RedLine RedLine
Weight 5w-30 0w-30 0w-30G 5w-30 0w-30Gr 0w-30 0w-30 0w-30 5w-40 5w-40 5w-40 5w-40 5w-40 5w-40 5w-30/40 5w-30/40
Filter BMW Mann BMW BMW Mann Mann Mann Mann Mann Mann Mann Mann Mann Mann Mann Mhale
ALUMINUM 4 2 2 2 2 2 4 2 2 4 2 3 3 5 4 3
CHROMIUM 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
IRON 9 7 6 4 8 6 11 9 7 7 9 8 7 10 13 15
COPPER 28 22 15 18 22 8 15 9 5 17 21 15 17 19 20 20
LEAD 2 2 2 1 1 1 1 0 0 0 1 4 1 1 0 2
TIN 0 1 0 0 1 1 0 0 0 0 1 0 0 2 0 0
MOLYBDENUM 124 19 4 104 16 4 3 2 3 149 207 33 14 9 584 526
NICKEL 1 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1
MANGANESE 3 1 1 1 1 1 2 1 1 1 3 2 1 1 3 12
SILVER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
TITANIUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
POTASSIUM 9 1 6 1 2 0 8 3 2 3 5 2 4 5 4 7
BORON 38 9 3 21 4 2 3 2 1 4 5 2 3 3 42 33
SILICON 5 3 3 3 3 2 4 3 4 6 7 5 4 4 13 12
SODIUM 2 4 3 5 3 3 4 2 3 9 12 7 5 13 14 19
CALCIUM 3446 2125 1704 2463 2702 2985 1864 1891 2452 2142 2574 2530 2677 2388 2657 2624
MAGNESIUM 18 311 455 83 129 147 448 551 86 30 36 17 16 14 10 12
PHOSPHORUS 853 748 781 662 737 782 872 885 988 1032 1134 1076 1182 985 1189 1181
ZINC 1050 889 964 847 878 1001 1115 1087 1282 1228 1446 1345 1363 1056 1371 1481
BARIUM 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
SUS @ 210F 65.6 62.5 63.2 64.1 63.8 65.8 64.2 65.5 73.9 78.2 78.4 77.6 75.7 78.6 68.4 67.8
cSt @ 100C 11.76 10.91 11.11 11.35 11.27 11.82 11.38 11.75 13.97 15.08 15.11 14.92 14.43 15.16 12.53 12.36
Flashpoint F 375 375 325 415 360 395 380 400 440 385 410 420 410 390 385 380
Fuel %
Antifreeze % 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 0 0 0 0
Water % 0.0 0.0 tr 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0 0 0 0 0 0
Insolubles % 0.3 0.3 0.2 0.3 0.2 0.2 0.2 0.3 0.3 0.3 0.3 0.3 0.3 0.3 0.3 0.2
TBN 1.8 4.0 4.7 3.2 2.9 2.6 2.9 4.9 4.0 1.7 1.3 2.7 3.2 2.5 1.9 0.3
Code:
2003 BMW 330 Ci
Fuel %
