Decent Wireless Computer Headset?
by 99Saturn
06/25/16 11:41 PM
Need Fuel Pump Assembly for Camry
by Nick1994
06/25/16 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
06/25/16 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
06/25/16 10:00 PM
Fram TG 7317 6k miles
by bbhero
06/25/16 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
06/25/16 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
06/25/16 08:56 PM
Second lawn mower blade
by greasegunn
06/25/16 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
06/25/16 07:13 PM
Reviving Old Hard Rubber Experiment
by sleddriver
06/25/16 04:47 PM
Where do pets go?
by Whitewolf
06/25/16 04:47 PM
Help reading Bosch 3330 date code
by beavis87
06/25/16 04:11 PM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
28 registered (bdcardinal, 2015_PSD, asand1, Andy636, chryslerconcorde, 6 invisible), 955 Guests and 11 Spiders online.
58272 Members
66 Forums
250818 Topics
#2703075 - 08/02/12 04:46 PM Shell Formula & PYB 10w-40 SM vs SN
tstep Offline
Loc: PA
With all the emphasis for resource conserving (understood that 10w-40 is not exactly resource conserving), why would SOPUS 10w-40 class oils get thicker when transition from SM to SN? Was SM perhaps too light w/ observable consequences being reported? Were the SL oils as light as SM, but with higher levels of plating additives? Are the SN formulations are nearly in the 15w-40 range to compensate for lower levels plating metals relying more on film thickness? Couple of comparisons below:
PYB SM ..............PYB SN
KV40 = 96.9 .........KV40 = 104.7
KV100 = 14.0 ........KV100 = 15.5
HTHS = 3.7 ..........HTHS = 3.8
Pour Point = -30 ....Pour Point = -42
Shell Formula has a similar viscosity increase in the 10% range along with the same 10-15 degree lowering of the pour point. Values are nearly identical to PYB. Quaker State however, looks as though they did not change the formuation from SM to SN.
#2703109 - 08/02/12 05:26 PM Re: Shell Formula & PYB 10w-40 SM vs SN [Re: tstep]
JRed Offline
Loc: Virginia
It's probably due to the use of higher quality base stocks to meet the requirements of API SN.
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2703111 - 08/02/12 05:28 PM Re: Shell Formula & PYB 10w-40 SM vs SN [Re: tstep]
dave1251 Offline
Loc: Maricopa, AZ
HTHS is about the same but pour point is improved. It is not that much "thicker" at operating temperature this looks improved overall to me.
don't use.
#2703119 - 08/02/12 05:35 PM Re: Shell Formula & PYB 10w-40 SM vs SN [Re: tstep]
tstep Offline
Loc: PA
I thought maybe the pour point would be an indicator of a better base. Just seems odd to have a 10% increase in KV and also odd to have Shell follow suit (unless it is the same oil repackaged) when the market trend is toward thinner oils.
But as stated, the HTHS is very similar.
Edited by tstep (08/02/12 05:36 PM)
#2703125 - 08/02/12 05:42 PM Re: Shell Formula & PYB 10w-40 SM vs SN [Re: tstep]
dave1251 Offline
Loc: Maricopa, AZ
It makes since because of the oils are provided by Shell.
don't use.
#2703357 - 08/02/12 09:31 PM Re: Shell Formula & PYB 10w-40 SM vs SN [Re: tstep]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Where did you find this data sheet? When I look here, I find substantially different numbers for the SN, in line with what you posted for the SM numbers.
Perhaps you have a newer sheet than I do. The SN sheet I linked above is dated November of 2010.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#2703358 - 08/02/12 09:36 PM Re: Shell Formula & PYB 10w-40 SM vs SN [Re: Garak]
dave1251 Offline
Loc: Maricopa, AZ
http://www.epc.shell.com/Docs/GPCDOC_X_cbe_24855_key_140007054913_201202271120.pdf
don't use.
#2703569 - 08/03/12 05:31 AM Re: Shell Formula & PYB 10w-40 SM vs SN [Re: dave1251]
Garak Offline
Thanks for the link. That's definitely a newer sheet than the one I was looking at. The one I was looking at was probably an "edit" where they just changed SM/GF-4 references to SN/GF-5 and left everything else alone. wink
Now, to see if I can find it myself on the Shell site without digging up something ancient again....
Bingo. If I want to find it, I have to set my country to the U.S. If I set it to Canada, I have the choice of SM/GF-4 Pennzoil or the old SN/GF-5 sheet (the one I referenced). If I choose the U.S., I get the old SM/GF-4 sheet or the one you showed me.
It might aid people if they put a reference date in the columns for these products, especially if they're keeping out of date spec sheets online. There are valid reasons for keeping old sheets out there, but it would be nice if there were a way to more easily filter them.
#2703638 - 08/03/12 07:51 AM Re: Shell Formula & PYB 10w-40 SM vs SN [Re: tstep]
dparm Offline
Loc: Chicago, IL
Shell is not consistent with updating spec sheets. This is a bit of a turn off as I look for my next oil to try...
2011 BMW M3 sedan ZCP
#2704134 - 08/03/12 05:32 PM Re: Shell Formula & PYB 10w-40 SM vs SN [Re: dparm]
Garak Offline
Agreed. It's not bad for me, who just needs something SM/GF-4 or better in a 5w-30. Anyone needing European specifications, like yourself, has a chore on his hands.
