Is Legalizing Marijuana Safe????
by qwerty1234
05/30/16 03:44 AM
Why it's a bad idea to ignore wheel-bearing noises
by Tegger
05/30/16 03:29 AM
Water decarbonization, does it work?
by FordCapriDriver
05/30/16 01:56 AM
Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
05/29/16 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
05/29/16 10:41 PM
Oil in air breather tubing
by Nissan101
05/29/16 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
kevinstoyhauler, jimx1169, W9HDG, LloydChristmass, dodge96
58019 Registered Users
18 registered (bernau, ASW338, bubbatime, asand1, bbhero, 2 invisible), 560 Guests and 310 Spiders online.
58019 Members
66 Forums
249584 Topics
Page 1 of 2 1 2 >
#2701357 - 07/31/12 10:37 PM STP High Mileage Oil Treatment VOA
Texan4Life Offline
Loc: Texas
http://i46.tinypic.com/esrxb5.jpg
wow that sucks. Basically an oil thickner, with I assume a seal conditioner since it is "High Mileage".
frown
Edited by Texan4Life (07/31/12 10:39 PM)
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
#2701365 - 07/31/12 10:44 PM Re: STP High Mileage Oil Treatment VOA [Re: Texan4Life]
spasm3 Offline
Loc: out there
It has less zinc than the oil you are adding it to!
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#2701367 - 07/31/12 10:47 PM Re: STP High Mileage Oil Treatment VOA [Re: spasm3]
Texan4Life Offline
Loc: Texas
lol that was my thought... more of a oil detractor than additive.
you can go get a qt supertech HM oil and come out better for cheaper.
#2701408 - 07/31/12 11:24 PM Re: STP High Mileage Oil Treatment VOA [Re: Texan4Life]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Oh yes. Less zinc and less detergents than the original oil. The only oils this stuff could improve are those on the PQIA's warning lists, or perhaps a non-detergent oil being used in an ICE.
If you ask me, it looks like something that might be good to add to a non-detergent oil about 60 or 70 years ago, with a formulation that has not been updated since.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#2701471 - 08/01/12 01:49 AM Re: STP High Mileage Oil Treatment VOA [Re: Texan4Life]
Mackelroy Offline
Loc: Florida /Texas
When I was in Automotive school, we took apart an engine full of sludge.Instructor said, that's what happens with STP oil treatment, all that zinc doubles what you already got, and creates deposits. Which goes along with oils that use excessive additives, can do the same thing. But most on the Board, think double the additives the better the oil.
Too much of a Good thing
#2701474 - 08/01/12 01:53 AM Re: STP High Mileage Oil Treatment VOA [Re: Texan4Life]
dave1251 Offline
Loc: Maricopa, AZ
I believe this qualifies as snake oil.
don't use.
#2701488 - 08/01/12 03:54 AM Re: STP High Mileage Oil Treatment VOA [Re: Texan4Life]
tstep Offline
Loc: PA
Speaking of viscosity only, when an oil this overly thick is added to say a 5w-30, does it evenly mix into a homogeneous mixture creating a uniformly thicker oil or does it tend to remain separate?
#2701493 - 08/01/12 04:20 AM Re: STP High Mileage Oil Treatment VOA [Re: dave1251]
Turk Offline
Loc: MN
...and look at all that Moly!!!
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#2701507 - 08/01/12 05:28 AM Re: STP High Mileage Oil Treatment VOA [Re: Mackelroy]
Garak Offline
Well, by using this ZDDP additive, the only way you could double the level already in the sump is if one were using something that wasn't even close to current API specifications, much less the older, higher ZDDP ones.
In just about any current oil on the market (or even within the last fifty or sixty years), this additive would DECREASE the ZDDP concentration. What a terrible, useless product. If my oil isn't thick enough, I'll buy a thicker grade, like an HDEO. If my oil doesn't have enough ZDDP, I'll buy an HDEO, or at least a proper additive.
The only conceivable use for this product in my view is if someone had a totally messed up carb that was just washing the cylinders, causing huge fuel dilution, and one had a container of this handy and couldn't do an oil change. Rolling it off a cliff would probably be kinder than using this stuff, though. wink
#2701513 - 08/01/12 06:01 AM Re: STP High Mileage Oil Treatment VOA [Re: Mackelroy]
demarpaint Offline
Loc: NY
It isn't the zinc that's the problem, its the thickening of the oil. Remove the zinc and I'll bet the sludge will still form over time with the addition of the STP. Don't forget some engines are more prone to sludge than others so it will occur even faster in them.
God Bless Our Troops
#2701678 - 08/01/12 09:42 AM Re: STP High Mileage Oil Treatment VOA [Re: demarpaint]
chainblu Offline
Loc: Florida
I wonder if some of you are forgetting that STP usually comes in pint jugs. Here's how I see it:
Let's say someone was running 4 qts of PYB 5w30 and is now a half quart low. They add the pint of STP to top off. According to PQIA, PYB has 868 ppm Zinc. If the pint of STP has 569, we now average 901 Zinc after adjusting for the loss of a half qt of PYB. So it would actually be an increase of about 4% along with a slight increase in viscosity.
Granted you'd probably be better off topping off with 20w50 to achieve similar results.
#2702166 - 08/01/12 06:02 PM Re: STP High Mileage Oil Treatment VOA [Re: chainblu]
Garak Offline
I don't think it works that way. The ZDDP content in the remaining 4 quarts would still be, let's say, 868 ppm, assuming that the loss of oil (consumption or leakage) took away all the ZDDP from that quart. My math shows the new ZDDP ppm would be 830.625 ppm. You made the mistake of averaging in the current sump load in quarts, while dealing with the STP in pints, or vice versa. You must use the same units in calculating this, be it pints or quarts or gallons.
(868 ppm * 7 pints + 569 ppm * 1 pint)/8 pints = 830.625 ppm ~ 831 ppm.
If you mix units, you get the exact answer you presented.
#2727734 - 08/28/12 01:35 PM Re: STP High Mileage Oil Treatment VOA [Re: Texan4Life]
ahoier Offline
Loc: Cocoa, FL
hmmm....just noticed....the "Capacity" they have "gallon".....surely the OP didn't send in a GALLON of STP Oil Thickener to be tested....? Or would the numbers not make a difference?
Edited by ahoier (08/28/12 01:36 PM)
#2727974 - 08/28/12 05:25 PM Re: STP High Mileage Oil Treatment VOA [Re: Texan4Life]
ltslimjim Offline
Loc: WatUpDoc
IIRC, it takes an additive not originally in an oil formulation somewhere around 4,000-5,000 ppm to increase the post-oil sample reading 100 ppm. Just an estimate. grin2
That's a guess but it's not that far off, so I'd imagine this product might increase the UOA by 5 ppm or so. ? lol
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2729112 - 08/29/12 08:01 PM Re: STP High Mileage Oil Treatment VOA [Re: Texan4Life]
MolaKule Offline
Loc: Iowegia - USA
It's mainly an oil thickener. The dispersants in the oil and additive will allow it to mix with the host oil, and depending on how much you add, it simply thickens the oil.
It is better to simply use a higher viscosity oil than try and thickening the oil with this stuff.
My BIL gave some to anaylize (although I need not do it now thanks to this analysis), and I did find one use for it. I needed to put a PVC bushing through a floor sill for some Amateur Radio cabling.
I drilled the hole out but it was still too tight for the PVC bushing so I put some of this stuff on the PVC and with one hammer blow, it went in. LOL
"You are free to choose, but you are not free from the Consequences of your choice." Dr. Laura. smile
Page 1 of 2 1 2 >
