0W20 in the US but 5W30 outside US for Mazda
by perryg114
02/05/16 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
02/05/16 08:48 PM
why would someone want to pay with a phone?
by turtlevette
02/05/16 08:16 PM
The connection was reset problem
by Triple_Se7en
02/05/16 08:14 PM
BIG PROBLEM!
by Avery4
02/05/16 08:03 PM
11,000 miles on a BMW
by BigJohn
02/05/16 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
02/05/16 07:20 PM
Anyone else have "See Cashier" issues with Shell?
by SLO_Town
02/05/16 07:16 PM
Shear rates in engine components...
by Shannow
02/05/16 06:32 PM
Windows Live Mail Question
by Wingman
02/05/16 06:21 PM
Royal Enfield Himalayan....Giddy Up!
by BigJohn
02/05/16 06:17 PM
clear no tint 1994 dakota windshield?
by bmwjohn
02/05/16 06:14 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
92 registered (AMC, 2015_PSD, Astro14, 77GrandPrix, aquariuscsm, 20 invisible), 1315 Guests and 129 Spiders online.
56834 Members
66 Forums
244290 Topics
#2696561 - 07/26/12 08:36 PM 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles
jetman Offline
Loc: TX
Lab: Oil Analyzers Inc
Vehicle: Diesel Pusher Motorhome
Engine: 2000 Cummins ISM w/86,000 miles since new
Oil: Amsoil AMO 10-40w changed 3000 miles and 14 mths ago. No make-up oil added.
Oil Filters: Full Flow position - Fleetguard# LF9080; Bypass - Fleetguard# LF3542, both filters changed 3000 miles and 14 mths ago.
Air Filter: Fram CA7230 changed 3000 miles and 15 mths ago
Lab Comments: Data indicates no abnormal findings. Resample at normal interval. Oil is suitable for continued use.
WEAR METALS(ppm)
Iron 6
Chromium 0
Copper 0
Tin 0
Lead 0
Nickel 0
Alum 0
Tin 0
Silver 0
Cadmium 0
Vanadium 0
CONTAMINANT METALS(ppm)
Silicon 5
Sodium 1
Potassium 0
MULTI SOURCE METALS(ppm)
Magne 0
Titan 0
Molybdenum 0
Antim 0
Mang 0
Lith 0
Boron 3
ADDITIVE METALS(ppm)
Magnes 9
Calcium 3666
Barium 0
Phosph 1199
Zinc 1376
CONTAMINANTS
Fuel Dilution <1%
Soot Vol <.1%
Water <.1%
FLUID PROPERTIES
V100C(cSt) - 14.5
Oxidation(abs/cm) - 58
Nitration(abs/0.1 mm) - 6
TBN(mg KOH/g) - 9.40
We plan to leave the oil, air & oil filters in place and resample in March of 2013.
Comments?
Don
#2696584 - 07/26/12 09:08 PM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
2James1 Offline
Loc: Union County, PA
Very impressive...almost 0 wear
2005 Chevrolet Malibu V6
Pennzoil Platinum HM 5w-30/ Bosch Premium oil filter
#2696599 - 07/26/12 09:28 PM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
Donald Offline
Loc: Upstate NY
With a TBN of over 9 you have better TBN than many virgin oil. No wear to speak of. But it is only 3000 miles, and you have a bypass oil filter and its a Cummins.
The Cummins would probably outlast you even if you used dino oil.
The oxidation seems a little high. So does the fuel. Maybe related. The fuel should be more like < .1%.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#2696614 - 07/26/12 09:40 PM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Don't bother sampling again until March 2014, unless you start driving the beast!! grin2
#2696620 - 07/26/12 09:47 PM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
lt1man Offline
Loc: Florida
Glad you didn't change the oil, good call! :P Good wear results though, impressive.
Edited by lt1man (07/26/12 09:50 PM)
#2696750 - 07/27/12 05:09 AM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
dnewton3 Offline
Loc: Indianapolis, IN
Are you sure that's a UOA?
It's so near pure, it could almost pass for a VOA!
I would easily agree that you should UOA only annually, unless your mileage would see a huge increase unexpectedly in the RV. OCI will probably not be warranted anytime soon if this is any indication.
In this case, UOAs are far cheaper than OCIs, so I'd keep that load in as long as possible. I see that 4 years, perhaps more, would not be inconcieveable? You will need to extend this OCI way out to meet the ROI, but if this wear rate is any indication, it is well on it's way to being able to do so!
Excellent showing for the rig and the Amsoil!
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#2696817 - 07/27/12 08:17 AM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: dnewton3]
jetman Offline
Loc: TX
Fleetguard says to change their oil filters annually?
What say you.
#2697445 - 07/27/12 07:51 PM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
jdean Offline
Loc: swpa
Looks like a voa, to me. I would send sample to another lab.
#2697465 - 07/27/12 08:07 PM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
Pablo Offline
What say you.
Actually I would ask Fleetguard, with UOA and your conditions in hand, so to speak.
Why?
#2697490 - 07/27/12 08:28 PM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
jdean Offline
Loc: swpa
With copper, tin, alum. and lead @0 ppm with 86,000 miles on engine
with the same oil in the engine for 14 months?
#2697974 - 07/28/12 12:58 PM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
sdan27 Offline
Loc: Michigan
I think every OEM says to at least change the oil and/or filters annually. I wouldn't worry about it. Do you know how an LF3542 bypass filter compares to an LF777?
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#2698730 - 07/29/12 10:02 AM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
jetman Offline
Loc: TX
TBN of virgin AMO is 12.1.
Rumor has it, the LF3542 is 99% efficent @ 10 microns while the LF777 is 98%.
#2735196 - 09/05/12 08:07 AM Re: 2000 Cummins ISM, Amsoil AMO 10-40w, 3000 miles [Re: jetman]
Sebastian Offline
Loc: Montevideo, Uruguay
Nice results, I guess you can extend your OCI with no problems.
Sometimes the oil companies recommend to change the oil every year regardless of the mileage it has because of natural oxidation of the oil in contact with air, even if the engine hasn't run. So, if you change the oil you should change the filters too.
Best regards,
Sebastian
