2014 Cruz LT loaner..
by dblshock
05/26/16 09:21 PM
Am I cheap or? Oil and filters...
by sw99
05/26/16 09:14 PM
Bought a New Sentra Today!
by mcgophers
05/26/16 09:12 PM
Texas Refinery Corp V. Lubrication Engineers
by Hullthumper
05/26/16 09:06 PM
Motor mount troubles...
by buck91
05/26/16 08:58 PM
need some methods of burping ait out
by snake123
05/26/16 08:54 PM
2010 Mini Cooper, Castrol Edge 0W-30 GC 5153 miles
by nicrfe1370
05/26/16 07:26 PM
Toro (Homelite) string trimmer diaphragm needed
by trouts2
05/26/16 07:26 PM
Wix : 10k miles? (also comparison question)
by Kuato
05/26/16 07:14 PM
Witnessed accident and driver running from scene
by stranger706
05/26/16 07:06 PM
Initial Vehicle UOAs
by GumbyJarvis
05/26/16 06:20 PM
04 C1500 1/2 Ton; P/S Fluid Disappearing
by TexasTea
05/26/16 05:52 PM
watergate528, iamtheanimal, 1991300sl, Rdyno, Darsahn
57993 Registered Users
108 registered (addyguy, 2015_PSD, AirgunSavant, abycat, Atlantis, austinlunsford, 10 invisible), 1683 Guests and 202 Spiders online.
57993 Members
66 Forums
249456 Topics
Page 1 of 2 1 2 >
#2691003 - 07/21/12 05:25 PM When and where to use gasket sealer
terry5732 Offline
Loc: ohio
Hi people, this my first post. I am going to change the transaxle fluid and filter on my 1996 Dodge Caravan 3.3L. It is the 4 spd automatic transaxle (I think). The pan gasket is a rubber gasket. I have searched the web to see if I should use a sealer. Some people say yes and some say no. I don't want to do it twice, so I figured this was the very best site to ask. If you tell me yes, could you please tell me what type to use.
Almost every time I decide on my own to use a sealer I find out later that either, I was not supposed to, or I used the wrong one. Thank you very much in advance for any help you can give me. Terry
#2691007 - 07/21/12 05:30 PM Re: When and where to use gasket sealer [Re: terry5732]
AVB Offline
Loc: Georgia
No sealer for a transmission pan.
#2691029 - 07/21/12 05:53 PM Re: When and where to use gasket sealer [Re: terry5732]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
get some spray adhesive. its made to hold the gasket in place to make installing it easier. or a few very small dabs of gasket maker to help you keep the gasket from sliding around. but thats it. otherwise the next time you do it if you use sealer all over it will be a miserable job.
o BTW welcome
2004 Honda civic vp -m1 5w30
1998 Saturn sl2 -mobil super 5000 5w30
#2691035 - 07/21/12 05:56 PM Re: When and where to use gasket sealer [Re: terry5732]
AVB Offline
Loc: Georgia
Don't use anything on the rubber gasket. If you need something to hold it in place use a dab of grease. If you are worried about it leaking get a new gasket.
Don't over torque the bolts.
#2691052 - 07/21/12 06:23 PM Re: When and where to use gasket sealer [Re: terry5732]
beast3300 Offline
Loc: Ohio
On that application throw away the rubber gasket and use RTV on the pan. Let it "set up" by drying for approx 15 minutes before reinstalling it on the transmission. Otherwise on this application the pan will leak shortly after service.
edit: Ultra black RTV would work for this. Any parts store should have it.
Edited by beast3300 (07/21/12 06:24 PM)
'03 Regal GS L67 3.29 GR:, PUP 5w30/TG3980, Filtermag
'99 Grand Prix L36: QS Defy 5w30/TG3387A, Filtermag
#2691069 - 07/21/12 06:49 PM Re: When and where to use gasket sealer [Re: terry5732]
KB2008X Offline
Loc: St. Louis, MO.
DO NOT use gasket sealer or a gasket maker.
Only use the gasket that came with the filter kit.
If there is any old gasket stuck to the trans or the pan use a razor blade to scrape the old gasket off.
There should be at least a few holes in the gasket, maybe more, that are smaller than the others that will hold a few bolts to start with. Putting the pan back on is a very simple task, you won't need any kind of assistance.
If there are magnets in the pan pull them, clean them and put them back right where they were.
Keith
Edited by KB2008X (07/21/12 06:50 PM)
04 Town Car 4.6 5w20 FL820S
92 Ram D150 3.9 10w30 MO-090
03 S-10 4.3 5w30 Puro L10111
above on TropArtic Synthetic Blend
10 Toyota Camry - undecided
#2691071 - 07/21/12 06:51 PM Re: When and where to use gasket sealer [Re: terry5732]
NHGUY Offline
Loc: USA
I use Right Stuff RTV by Permatex.Doesnt leak a drop.
#2691076 - 07/21/12 06:54 PM Re: When and where to use gasket sealer [Re: terry5732]
terry5732 Offline
Loc: ohio
I just want to say thank you to everyone, Terry
#2691128 - 07/21/12 07:59 PM Re: When and where to use gasket sealer [Re: terry5732]
KB2008X Offline
Loc: St. Louis, MO.
What is with this chicken little fear of leaks ?
The gasket is there to seal the pan to the trans body. It's sole purpose is to seal the two parts together so there are no leaks. It's a foolproof, time proven method of sealing the two parts together. It works so well that the vehicle manufacturers use gaskets. Oh the horror !
Many years ago Fram and others were including a cork gasket with their filter kits. Those were troublesome, but I haven't seen one of those in a long time.
The rubber gasket is what you want to use, by itself. There will not be a leak unless there is a hole in the pan, you didn't scrape off the old gasket, didn't tighten the bolts properly or somehow succeeded in botching a simple task some other way.
Gasket maker on a transmission pan is wholly unnecessary and in the hands of weekend warriors and pros alike, is asking for trouble.
Keith
#2691469 - 07/22/12 06:26 AM Re: When and where to use gasket sealer [Re: terry5732]
SteveSRT8 Offline
Loc: Sunny Florida
^^^been there, done that!
if factory equipped with the reusable rubber gasket just use it. Typically the aftermarket filter kits are garbage.
No sealers needed if everything is clean and undamaged.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2692290 - 07/22/12 10:26 PM Re: When and where to use gasket sealer [Re: KB2008X]
paulo57509 Offline
Loc: Tracy, CA
And it makes removal of the pan a PITA the next time.
1987 Chevrolet Camaro IROC-Z 5.0L
1987 Acura Legend L Coupe 2.7L (5-Speed)
1992 Lumina Euro Coupe 3.1L
1998 Lexus LS400
2003 GMC Safari
#2692400 - 07/23/12 03:11 AM Re: When and where to use gasket sealer [Re: terry5732]
tommygunn Offline
Loc: usa
When and where to use RTV?
When the next person dropping the pan is someone you hate.
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
#2692443 - 07/23/12 06:01 AM Re: When and where to use gasket sealer [Re: terry5732]
yonyon Offline
Loc: NJ, USA
Any of the gray stuff from ThreeBond should work well if you want to be able to take the bolts back out and use them for something else but continue to drive the van. Don't count on being able to reuse the pan again after that though.
#2692644 - 07/23/12 10:17 AM Re: When and where to use gasket sealer [Re: terry5732]
tightwad Offline
Loc: Texas
Well, I am OCD, so I use a sealer. I use the ATP felt type gasket on vehicles that don't have the reusable factory gasket. I put a small bead of silicon on the outer half of the gasket so that it gets squeezed out, rather than in. Peels right off next time around.
I put 3M weatherstrip adhesive all over a cork Powerglide gasket years ago, when I was young and stupid. ( I know, I know, now I'm old and stupid.) Anyway, I was shocked to see that goo dissolved and running down the sides of the pan. So, when in doubt, more is not better.
2007 Caddy DTS/Havoline Synth 5w-30/Mobil-1 O/F
1983 El Camino/Havoline 5w-30/ACDelco(non-E-core)
1956 Packard/Delo 15w-40/Wix
#2692981 - 07/23/12 03:15 PM Re: When and where to use gasket sealer [Re: terry5732]
mechtech2 Offline
Loc: Chicago Area
In this case, the factory or GOOD replacement gasket should work great.
Are there leaks/seepage now?
The surfaces must be FLAT and CLEAN.
A wipe of RTV on the gasket may be a good thing if you see seepage now.
Let it cure before refilling.
Page 1 of 2 1 2 >
