Purolator PureONE PL14610 - 6k Miles
by ThirdeYe
07/23/16 07:47 AM
'06 Kia Sportage weird issue
by CincyDavid
07/23/16 07:33 AM
Dented Again
by AirgunSavant
07/23/16 06:42 AM
Does EGR blocking increase diesel consumption?
by berniedd
07/23/16 06:20 AM
Has BP left the gas retailing market?
by Vern_in_IL
07/23/16 05:45 AM
Commentary on Gate's Commentary on Electricity.
by Shannow
07/23/16 05:14 AM
techron article
by Joe1
07/23/16 05:08 AM
Lighter or heavier o-20 oils
by shDK
07/23/16 04:53 AM
Nice Gun Store Find
by bobbob
07/23/16 01:57 AM
Gun Prices
by bobbob
07/23/16 01:55 AM
Nissan Maxima pre-cats common problem
by Rohan
07/23/16 12:43 AM
License Plate Lights Quit
by Nick1994
07/23/16 12:39 AM
Omaid, Bwayne, krellmk, Annette, bimmergeek
58567 Registered Users
65 registered (4WD, Alex D, Astro14, 41 Plymouth, b1amgm47, Axe Man, 6 invisible), 1467 Guests and 9 Spiders online.
58567 Members
66 Forums
252136 Topics
#2686944 - 07/17/12 04:41 PM door knob lockset dead latch and latch plunger
mechanicx Offline
Loc: Ohio
I had a Schlage locking door knob on my front door. The dead latch froze up. I took it apart and was going to just replace the dead latch, but found that I could get the same type of Schlage door knob that was nonlocking for about the same price. I didn't want a locking door knob anyway since I have a deadbolt.
I installed it and it worked well except the door didn't latch far enough in to be perfectly even with my deadbolt. The only difference between locking and nonlocking besides the cylinder is that the latch on the nonlocking doesn't have a separate latch plunger. The old door knob's latch plunger was closing the door tighter and inline with the deadbolt. I fixed that problem by bending the tab inside the striker plate out more (luckily my original stiker plate had a slot on the inside tab to easily adjust with a flatblade screw driver, while the new striker inside tab did not) this link shows the parts I'm referring to http://www.thisoldhouse.com/toh/photos/0,,20297849,00.html .
Now here's my question about the latch plunger. As I explained originally my latch plunger was latching into the striker and holding the door in more. But according to Schlage's instructions the latch plunger is not suppose to enter the striker plate hole. See step 7 here http://consumer.schlage.com/Project%20Documents/P515-302-SH2-c.pdf.
That doesn't make much sense. I thought the purpose of the latch plunger was to engage latch bolt to prevent it from being pried open from outside. How is it going to do that if it installed so that it is pushed down level with the striker plate? And also my door was a pre-hung with the door jamb striker and deadbolt mortise precut if I recall and everything lined up pefectly with the bolt plunger going into the striker hole and with no adjustments.
#2686971 - 07/17/12 05:11 PM Re: door knob lockset dead latch and latch plunger [Re: mechanicx]
doitmyself Offline
Loc: MI
The half moon dead latch plunger is to prevent moving back the door plunger with a screwdriver, credit card, etc. (someone breaking in). This is achieved when the half moon plunger is pushed in and against the striker plate.
Since you bought a non locking door set, this is a moot point, correct?
If your metal bending trick on the striker plate doesn't work, you can buy an adjustable one.
This page explains the same thing: http://keylessentrylocks.com/index.php?main_page=product_info&cPath=56_57&products_id=29
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#2686981 - 07/17/12 05:17 PM Re: door knob lockset dead latch and latch plunger [Re: mechanicx]
mechanicx Offline
Loc: Ohio
Actually I don't understand the purpose of the latch plunger all together. As far as I can tell when you lock a door knob you really are only lock the knob from from being turned. The latch can still be pushed in since the door can be locked while open and then shut.
I guess you're saying the plate or striker pressing the latch plunger in locks the entire latch?
Edited by mechanicx (07/17/12 05:25 PM)
#2686984 - 07/17/12 05:21 PM Re: door knob lockset dead latch and latch plunger [Re: mechanicx]
doitmyself Offline
Loc: MI
Originally Posted By: mechanicx
Actually I don't understand the purpose of the latch plunger all together. As far as I can tell when you lock a door knob you really are only lock the knob from from being turned. The latch can still can still be pushed since the door can be locked and then shut.
Yes, you can lock the door while open, and then push it shut because the door plunger will still push in. Once that half moon dead latch plunger is pushed in AND held in via contact with the striker plate, then the main door plunger is locked in place and will not move.....thus preventing a burglar from using a tool to push it in.
From my link added above: "When the door is closed, the strike plate presses in the plunger and prevents the latchbolt from opening independently of the handle. When properly installed, dead-locking latchbolts cannot be opened by sliding a credit card between the door and the door frame."
YES, to your edited question.
Edited by doitmyself (07/17/12 05:29 PM)
#2686992 - 07/17/12 05:30 PM Re: door knob lockset dead latch and latch plunger [Re: doitmyself]
mechanicx Offline
Loc: Ohio
OK it all makes sense now if that's the way the plunger works.
I was almost going to install a dead latch with plunger into my non locking door knob set just to get the door to close tight and inline with my deadbolt, until I saw/remember I could easily bend the inner tab of the existing striker plate.
Edited by mechanicx (07/17/12 05:31 PM)
#2687014 - 07/17/12 05:53 PM Re: door knob lockset dead latch and latch plunger [Re: mechanicx]
mechanicx Offline
Loc: Ohio
This short video explains the dead latch and plunger function pretty clearly
#2687909 - 07/18/12 04:05 PM Re: door knob lockset dead latch and latch plunger [Re: doitmyself]
mechtech2 Offline
Loc: Chicago Area
Ha! doitmyself nailed it again!
But for locks without this feature, we can only hope the thieves have lousy credit.
