I bought two Purolator PSL14610's. The only store that had them was 15 miles away or so, but I wanted to try them out so I made the drive and picked them up. I did not inspect them at the store (my mistake).
The first one I opened had blue overspray on the base plate like the old days with the P1's so I installed the second filter which looked good on the base plate. I figured I would return it next time I went to get the next set if I liked the way they performed.
I recently changed the oil on our 05 Odyssey which had been running this filter on a big trip to Florida. Tonight I got around to opening it up and was not happy with what I saw. Since I had the second filter still in the box (but with paint splatter on the base plate), I figured I would crack it open to compare since I will most likely not be purchasing any more of these.
The filter looks like it was split at the seam. The glue was also very sloppy on the end caps. The new filter looked better in comparison but like I said, had that rough textured paint on the base plate. I am not sure if the filter media would was split when it was built, or if it split during use. Either way I was not happy with the split, the sloppy job with the glue and the paint on the base plate of filter number 2. Two big thumbs down on this filter.
The filter on the Odyssey is currently a Fram Xtended Guard with a Napa Platinum on deck for either the Odyssey or my Titan.
