Any experience with 98-02 corolla?
by barkingspider
02/05/16 04:11 PM
nice video
by raaizin
02/05/16 03:36 PM
Dumbest thing you have been told at a parts store
by tojo1968
02/05/16 03:30 PM
Our cars are due for oil, any recommendations?
by MilesToEmpty
02/05/16 02:30 PM
roof shingles- come from oil?
by edwardh1
02/05/16 02:28 PM
2015 Honda Accord FF UOA 8350 miles
by dieselworld
02/05/16 02:09 PM
Mobil 1 has highest film strength
by DrRoughneck
02/05/16 01:10 PM
A guy at the gym.....
by Doog
02/05/16 12:26 PM
Fram xg3976a or wix 57620 for 5.9l cummins?
by monster1
02/05/16 11:52 AM
Fram XG2 vs Motorcraft 820s
by doolah02
02/05/16 10:57 AM
06 Elantra rough start up
by dan765
02/05/16 10:52 AM
Grand old ship...new life?
by andrewg
02/05/16 10:29 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
106 registered (2015_PSD, 97K15004WD, 05LGTLtd, 90crvtec, 2oldtommy, 1989outlaw, 12 invisible), 1695 Guests and 126 Spiders online.
56834 Members
66 Forums
244270 Topics
Page 1 of 2 1 2 >
#2672975 - 07/03/12 07:10 PM Does a portable generator need to be grounded?
Tdbo Offline
Loc: Ohio
After reading about the HF 2 cycle generators here, I picked up one last fall during a parking lot sale for $79. Got it out of the shed today and broke it out of the box and swapped out the spark plug as has been suggested. In reading the directions, it mentions grounding the unit, which would obviously impact the portability and convenience of the unit. As I have never owned a portable generator before, are any of you using this unit grounding it?
2012 Honda Accord LX-P 77K
2008 Ford Mustang Pony Package Convertible 13K
2006 Honda Odyssey EX-L 72K
2003 Ford Ranger 3.0 Supercab 88K
#2672982 - 07/03/12 07:12 PM Re: Does a portable generator need to be grounded? [Re: Tdbo]
JHZR2 Offline
Loc: New Jersey
How does it impact the portability? Id imagine you could ground it reasonably well with a metal tent stake or a 3' pipe.
#2672995 - 07/03/12 07:24 PM Re: Does a portable generator need to be grounded? [Re: Tdbo]
Donald Offline
Loc: Upstate NY
Its best to ground it to the ground rod that your electric service is grounded to.
I would say almost no one does however. I would not really worry about it too much. But a roll of stranded wire (say #10 or #12) is pretty cheap also. You could install the wire to near where you are going to use the generator and then its only one screw to connect it when you roll out the generator. Probably more important if you are going to connect it through a transfer switch (don't backfeed).
I have a 5000W LP gas Winco I bought used. The previous owner grounded it, to the negative of the 12V battery (in addition to the negative battery cable). Obviously the prior owner was not a member of Mensa.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#2672999 - 07/03/12 07:26 PM Re: Does a portable generator need to be grounded? [Re: JHZR2]
Tdbo Offline
Loc: Ohio
My purpose for the generator is to move it around my yard to use electric yard tools (such as hedge trimmer,etc) to save the hassle of running extension cords. I thought that I could ground the unit by running an 8 gauge wire off the unit, and use some sort of spike to attach to the ground, as you had mentioned. However,in doing a Google search, I found that proper grounding is a 8'rod and that using a spike is actually against code. If I have to go to all that hassle, may as well just use the extension cords and forget the generator.
#2673002 - 07/03/12 07:29 PM Re: Does a portable generator need to be grounded? [Re: Tdbo]
Dave Sherman Offline
Loc: Ohio
It's not overly critical, but without it there's the possibility to have something plugged into it float to some unknown voltage. Floating grounds can "bite" if you touch the appliance. As an example, RVs with broken ground wires have been known to have their chassis shock people who were standing on the ground when they touched it, because a little bit of leakage current caused the chassis to float to a high voltage.
That said, I've never grounded my generator.
Edit: Even if you had a short metal rod that wasn't up to code, it would still be better than nothing at all, since it would still have a ground connection, even though it may not be a perfect one.
Edited by Dave Sherman (07/03/12 07:36 PM)
'10 Chevrolet Traverse LS AWD Valvoline Synpower 5W-30 Bosch filter
'77 MG Midget Shell Rotella T6 5W-40 Bosch filter
#2673011 - 07/03/12 07:40 PM Re: Does a portable generator need to be grounded? [Re: Tdbo]
tom slick Offline
Loc: Central Coast, Calif.
The main reason for grounding is lightning protection.
You get what you pay for...
So keep in mind how much you paid for this advice.
#2673037 - 07/03/12 07:59 PM Re: Does a portable generator need to be grounded? [Re: tom slick]
RF Overlord Offline
Loc: Cape Cod, MA
How many portable generators get struck by lightning?
The main purpose of grounding is to prevent an insulation fault or wiring issue from causing the chassis to become electrically hot and posing a shock hazard. Grounding will cause the breaker to trip in that case.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
Y2K Grand Marquis GS - daily driver
QSUD 5W-20 / MC FL820S
#2673041 - 07/03/12 07:59 PM Re: Does a portable generator need to be grounded? [Re: tom slick]
Rand Offline
Loc: NE,Ohio
i wouldnt worry about it for using tools in your yard.
2015 Forester I-Premium 6MT
#2673064 - 07/03/12 08:28 PM Re: Does a portable generator need to be grounded? [Re: RF Overlord]
tig1 Online   content
Loc: Illinois
+1, all generators should be grounded.
Edited by tig1 (07/03/12 08:28 PM)
2007 Ford Fusion 173,000 miles
M1 0-20 AFE
2007 Ford Focus 150,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2673081 - 07/03/12 08:44 PM Re: Does a portable generator need to be grounded? [Re: Tdbo]
eljefino Offline
Loc: ME
Get a GFCI adaptor like this one. "They" let you use a GFCI outlet in an old house without a grounding wire, this is the same premise.
#2673082 - 07/03/12 08:45 PM Re: Does a portable generator need to be grounded? [Re: Tdbo]
brianl703 Offline
Loc: Manassas, VA
If it's being connected to building wiring, then it needs to be grounded. If it's being used with an extension cord to operate power tools (for example), there's no point to grounding it, and a fault will trip the breaker/GFCI regardless of whether it's connected to a ground rod or not.
#2673083 - 07/03/12 08:46 PM Re: Does a portable generator need to be grounded? [Re: tig1]
chad8 Offline
Loc: michigan
If you have a metal fence in your yard , ground it to that just to say you did. Impress the wife.. By code portable generators do not have to be grounded. Tell me again how a cut wire is going to touch the frame and electrify it without the ground fault plug (now required) from tripping.
Its almost impossible.
#2673411 - 07/04/12 08:20 AM Re: Does a portable generator need to be grounded? [Re: Donald]
JHZR2 Offline
Loc: New Jersey
But the ground that is bonded in the main panel should be usable, if convenient, right?
In our panel, we have heavy solid copper going out of the house to a long rod in the ground.
#2673628 - 07/04/12 12:18 PM Re: Does a portable generator need to be grounded? [Re: chad8]
RF Overlord Offline
Loc: Cape Cod, MA
I was speaking generically. Certainly if a working GFCI is in place then the point is moot.
#2673634 - 07/04/12 12:28 PM Re: Does a portable generator need to be grounded? [Re: chad8]
user52165 Offline
Loc: CA
Are you saying a ground fault plug (I think you meant outlet) is now required on a generator? So all new ones will have this?
Page 1 of 2 1 2 >
