out with the subaru and in with a new Fusion
by stygz
08/27/16 04:33 PM
Brand perception
by OldEuroCarLover
08/27/16 04:16 PM
Looking for a super economical car, accent ?
by sirgerman
08/27/16 04:00 PM
Cooling system hoses. Old but not brittle.
by Martin10
08/27/16 03:52 PM
CHEVRON DELO Reveals their line up of CK-4/FA-4
by Powerstroke
08/27/16 03:07 PM
New belt or new belt tensioner?
by Parlay_Slow
08/27/16 02:53 PM
PP 5w-30 Amazon subscribe and save
by buck91
08/27/16 01:52 PM
My parents took my nissan s13 silvia
by Nissan101
08/27/16 01:21 PM
New Hyundia Santa Cruz pickup with extendable bed
by gfh77665
08/27/16 01:12 PM
Pro Line PPL 14610 4,000 miles CUT OPEN
by car51
08/27/16 01:00 PM
STP S-10590 6,000 miles CUT OPEN
by car51
08/27/16 12:47 PM
Store Kerosense in Non-Vented Container?
by ET16
08/27/16 12:16 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
65 registered (andrewp1998, 2cool, barkingspider, 4WD, AirgunSavant, Astro14, 7 invisible), 1647 Guests and 35 Spiders online.
58935 Members
66 Forums
253634 Topics
#2667448 - 06/28/12 06:57 AM PAG oil hygroscopic-ness
exranger06 Offline
Loc: Guilford, CT
What you're seeing is where my accumulator used to be. It's been left like this for about a week. It's not air tight, but it's sealed up pretty well. I just put fresh PAG oil in the compressor last weekend. My question is, did the PAG oil absorb a ton of moisture in the past week by leaving it like this? Should I drain and refill the compressor again? Or would vacuuming it down be enough to get rid of any moisture?
2006 Ford Ranger Sport
1992 Honda Accord EX
1994 Ford Bronco XLT (project)
2014 Subaru XV Crosstrek (wife's)
1999 Ford Explorer XLS
#2667519 - 06/28/12 08:08 AM Re: PAG oil hygroscopic-ness [Re: exranger06]
LeakySeals Offline
Loc: MA
Yeah drain and fill. Compressors like new oil too. You will find less engine chugging sitting at a stoplight w/AC on with new PAG. Just like the engine, fill accuracy is important.
02 Camry XLE 2AZ-FE 352k M1 HM 5w30 (RIP, broke pist rod 7/2/2016)
06 Escalade 135k. M1 5w30
#2667909 - 06/28/12 02:23 PM Re: PAG oil hygroscopic-ness [Re: exranger06]
exranger06 Offline
Loc: Guilford, CT
It does have new oil in it, I'm just worried about it absorbing moisture over the past week. Would like some more opinions before I start tearing it apart (again) in a few hours.
#2668010 - 06/28/12 03:38 PM Re: PAG oil hygroscopic-ness [Re: exranger06]
mechtech2 Offline
Loc: Chicago Area
How did you get all the old stuff out and know how much to put back it?
That is a TOUGH one.
#2668120 - 06/28/12 05:09 PM Re: PAG oil hygroscopic-ness [Re: exranger06]
exranger06 Offline
Loc: Guilford, CT
I removed the compressor and drained it out. I put the same amount back in.
#2668137 - 06/28/12 05:26 PM Re: PAG oil hygroscopic-ness [Re: exranger06]
mechanicx Offline
Loc: Ohio
I'm going to say since it's only been a week, sealed it off and I assume you installed a new drier and will pull a vaccuum on it that the oil will be OK to go with.
#2668329 - 06/28/12 09:04 PM Re: PAG oil hygroscopic-ness [Re: exranger06]
Rock_Hudstone Offline
Loc: New Jersey
I taped off the hoses most of last winter on the GF's car when a temporary bypass pulley was on there. When the new compressor was installed I evacuated/charged the system and it worked as well as before. However, I had it sealed up super tight with electrical tape.
Did your system absorb some moisture, probably, but not enough to justify tearing it apart to replace the oil, which you won't get all of anyway and will expose the system to the atmosphere even further.
I would add whatever oil is necessary, then evacuate the system for at least 45 minutes.
#2668338 - 06/28/12 09:12 PM Re: PAG oil hygroscopic-ness [Re: exranger06]
RH+G Offline
Loc: NY
Depends on which PAG oil was used. DOuble End Capped PAG oil doesnt asorb moisture. If that was used then dont worry bout it.
#2668343 - 06/28/12 09:17 PM Re: PAG oil hygroscopic-ness [Re: RH+G]
mechanicx Offline
Loc: Ohio
Good point. I think double end cap PAG is really common now and I think it is blue and the other stuff is green, but I'm not 100% sure.
#2668558 - 06/29/12 06:43 AM Re: PAG oil hygroscopic-ness [Re: exranger06]
exranger06 Offline
Loc: Guilford, CT
What is "double end capped" oil? Never heard of it. I used PAG 46 with UV dye in it.
#2668959 - 06/29/12 02:57 PM Re: PAG oil hygroscopic-ness [Re: exranger06]
mechtech2 Offline
Loc: Chicago Area
There is oil in other parts of the rest of the system - all the oil is not in the compressor.
#2669069 - 06/29/12 05:30 PM Re: PAG oil hygroscopic-ness [Re: exranger06]
wtd Offline
Loc: southwest Mo.
PAG oil will absorb moisture pretty easy if it is exposed to air so it all depends on how tightly you have those ends wrapped off and how porus the material used is.
Vacuuming down the system will remove moisture from the system so you may be ok since the lines are not totally exposed and you have not have the ends taped off for that long. The safest bet of course is to replace the compressor oil with new that way you don't have to guess how much moisture might have gotten into the oil.
Wayne
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
#2669353 - 06/29/12 10:45 PM Re: PAG oil hygroscopic-ness [Re: exranger06]
RH+G Offline
Loc: NY
Double end capped is the second generation of PAG oil. They dont absorb moisture like the original PAG do.
If u stil have the bottle it should say it on the bottle.
Edited by RH+G (06/29/12 10:46 PM)
