Originally Posted By: WMSmotorhead
Usually the engine is pretty close to operating temp when I drain them... Thus it may just be physics at work. I do oil the seals when I put the filter on initially.
Just to add detail I may have missed....
The oil filter I put on by hand a few months before... and then drove a full OCI on... doesn't like to come off without a wrench.
When you put the filter on engine was cool, when you tried to take it off engine was hot..
I don't think its the seals but I do think there is minor expansion of the thin metal can when its hot. Some more than others depending on
composition and thickness. Maybe the filter housing too. Depending on what you consider hand tight it could be just enough to not to be able to get it off without a wrench.
I understand why you change the oil when its warm. I do that too. But not scalding operating temps hot. I don't think I'm getting any less out because its a little cooler. Oil still has to drain back to the sump over a period of time, watching it drip for an hour, or waiting for the engine too cool for 20 mins makes no diff IMO.
Try letting it cool down more then try removing the filter, see if that helps.
